Home » Modeling » GMF (Graphical Modeling Framework) » Add parent element while adding child
Add parent element while adding child [message #8150] Mon, 07 August 2006 02:31 Go to next message
Originally posted by: vikas.goyal.hp.com
I am trying to use GMF to create a model for CCXML.
My structure is something like this.
<CCXML>
<AssignType>
</AssignType>
<EventProcessor>
<TransitionType>
<AssignType>
</AssignType>
</TransitionType>
</EventProcessor>
</CCXML>
In this AssignType can come directly within root element i.e CCXML or it
can come under TransitionType.
I was wondering if I try to drop AssignType from the palette within
Eventprocessor can I create its parent node also i.e TransitionType .
I have tried to modify
CCXMLItemSemanticEditPolicy->CreateAssignTypeCommand, but could not able
to proceed.
Please suggest me some example to implement this.
Thanks in Advance
-Vikas
Re: Add parent element while adding child [message #10032 is a reply to message #8150] Tue, 08 August 2006 13:34 Go to previous message
Hello Vikas,
I don't think that we have an example that demonstrates creating the
container element at the same time as creating the new element. But all
you would need to do is return a command that (in its
#doExecuteWithResult) first creates the container element, and then
creates its child.
Linda
Previous Topic:The overwrited method setFocus nerver be called, why? a bug?
Next Topic:Development Guidelines moved to Wiki
Current Time: Sat May 10 02:51:49 EDT 2025
Powered by FUDForum. Page generated in 0.02814 seconds
