Home » Newcomers » Newcomers » Install eclipse failed with "Could not find framework" error
Install eclipse failed with "Could not find framework" error [message #90417] Fri, 29 July 2005 10:27
Originally posted by: hanmeng1979.yahoo.com
Hi, all,
I have downloaded "" and try to install it, but got some errors
complaining about the "java.lang.RuntimeException: Could not find
framework", can someone help me out ? what can I do ? I run it in
WindownXP and even change the unzip location before installation, but
always got same error message.
Here are my system setting:
---------JRE is ok---------
E:\Software>java -version
java version "1.4.2_08"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_08-b03)
Java HotSpot(TM) Client VM (build 1.4.2_08-b03, mixed mode)
---------PATH is ok---------
E:\Software>path
PATH=C:\Program Files\Java\j2re1.4.2_08\bin;D:\oracle\ora81\bin;C:\Program
Files\Oracle\jre\1.1.7\bin;C:\WINDOWS\sy
stem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Rational\clearcase\bin;C:\Program Files\Rational\common
;C:\Program Files\Hummingbird\Connectivity\8.00\Accessories\;C:\Program
Files\Hummingbird\Connectivity\8.00\NFSClie
nt;C:\Program
Files\Java\j2re1.4.2_08\bin;C:\WINDOWS\system32;C:\WINDOWS;C :\WINDOWS\System32\Wbem;C:\ntutils;C:\Scr
ipts
---------downloaded package is ok---------
E:\Software>md5sum.exe -c eclipse-SDK-3.1-win32.zip.md5
eclipse-SDK-3.1-win32.zip: OK
Here is the error message:
!SESSION Fri Jul 29 13:20:00 SGT 2005 -------------------
!ENTRY org.eclipse.core.launcher 4 0 2005-07-29 13:20:00.754
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Previous Topic:Sun is bashing Eclipse contributors!
Next Topic:install eclipse failed with "Could not find framework" error
Current Time: Sat Aug 30 20:22:26 EDT 2025
Powered by FUDForum. Page generated in 0.05809 seconds
