Home » Archived » Test and Performance Tools Platform (TPTP) » HTTP recording doesn't work
HTTP recording doesn't work [message #90388] Fri, 15 December 2006 02:09 Go to next message
Originally posted by: sanlyfang.gmail.com
When I want to create HTTP recording, the eclipse workbench seems hung up.
the message displayed in process view is: connecting to agent controller
on localhost/port 10006, after waiting for a long time, I have to shutdown
eclipse workbench, the thread seems blocked, I guess if the operation is
successful, a browser window should be opened.
I don't know why it blocks when connecting to the new agent controller,
which is already started.
I did the followings to setup my environment.
1) download TPTP 4.3 all-in-one bundle
2) download new agent controller and new java profiler, install new agent
controller as windows service.
3) download jvmti client and extract it to eclipse install folder
4) change settings in eclipse preference, for example, disable integrated
agent controller, change all local port from 10002 to 10006
The environment is clean and I have repeated several times but the error
still occurs, what's wrong with my settings?
Thanks!
Re: HTTP recording doesn't work [message #90553 is a reply to message #90388] Tue, 19 December 2006 11:38 Go to previous message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 005B760485257249_=
Content-Type: text/plain; charset="US-ASCII"
Did you follow all the instructions in the Getting Started guide of the
Agent Controller:
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&revision= 1.3
Are you sure you have the agent controller set up on port 10006? The
default port is 10002.
Note that you don't need the JVMTI agent to work with the HTTP recorder so
downloading that from the technology preview section was unnecessary.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi,</font>
<br>
<br><font size=2 face="sans-serif">Did you follow all the instructions
in the Getting Started guide of the Agent Controller: http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&amp;revision=1.3</font>
<br>
<br><font size=2 face="sans-serif">Are you sure you have the agent controller
set up on port 10006? &nbsp;The default port is 10002.</font>
<br>
<br><font size=2 face="sans-serif">Note that you don't need the JVMTI agent
to work with the HTTP recorder so downloading that from the technology
preview section was unnecessary.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 005B760485257249_=--
Previous Topic:Problems with installation of TPTP 4.3 on Windows
Next Topic:Using Probekit with Eclipse Plugins
Current Time: Mon Sep 01 05:19:29 EDT 2025
Powered by FUDForum. Page generated in 0.03651 seconds
