Home » Archived » Visual Editor (VE) » "org.eclipse.ve.beaninfo/cache"
"org.eclipse.ve.beaninfo/cache" [message #90209] Mon, 09 May 2005 07:26 Go to next message
I have read in the tutorial that there is a problem with automatically
refreshing in VE/Eclipse.
You are writing it is necessary to use "Project | Clean" and manually
remove the directory "org.eclipse.ve.beaninfo/cache". I have searched the
whole eclipse and didn't find this directory. The only directory with name
"cache" is in the "org.eclipse.xsd_2.0.1".
> The Visual Editor caches information about a class and under some builds
> prior to VE 1.1 there are some issues with the cache going stale and not
> being automatically refreshed. If this occurs you can manually recycle the
> cache by selecting Project > Clean and also manually removing the directory
> org.eclipse.ve.beaninfo/cache from the workbench directory.
What directory did you mean and where ?
Thanks in advance :o)
Elena
Re: "org.eclipse.ve.beaninfo/cache" [message #90223 is a reply to message #90209] Mon, 09 May 2005 09:38 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
You don't need to do both. The Project->Clean All will clear this
directory for you. Erasing the directory manually is only a fall-back
position if and only if the clean of all projects had failed.
It is under .metadata/.plugins and it will only be there if the VE had
been used. It would create this cache then.
Rich Kulp
Re: "org.eclipse.ve.beaninfo/cache" [message #90238 is a reply to message #90223] Mon, 09 May 2005 10:10 Go to previous message
Elena
Re: "org.eclipse.ve.beaninfo/cache" [message #607371 is a reply to message #90209] Mon, 09 May 2005 09:38 Go to previous message
Rich Kulp
Re: "org.eclipse.ve.beaninfo/cache" [message #607372 is a reply to message #90223] Mon, 09 May 2005 10:10 Go to previous message
Elena
Previous Topic:"org.eclipse.ve.beaninfo/cache"
Next Topic:Edit handwritten Java Code in the VE
Current Time: Fri Oct 03 15:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.27160 seconds
