Re: [EMF Compare] Compares as Text compare [message #90230 is a reply to message #90215] |
Tue, 17 July 2007 20:10 |
Alain Picard Messages: 266 Registered: July 2009 |
Stéphane,
Thanks for bringing this option to my attention, but in looking at it it
already has *.ecore,*.emfdiff and *.uml as locked and preset already.
Any other idea here?
Merci,Thanks
Alain
Stéphane LACRAMPE wrote:
> When you say that you see the preference page, did you actually add the
> file extension in
> the "Model File" content-type.
> You can do that with the preference panel in "General" then "Content
> types".
> Cheers,
> Stephane LACRAMPE
> Alain Picard a écrit :
>> I just installed the emft-compare-SDK-0.7.0RC2 to do model compare
>> (.ecore) and I can't seem to get it working (that is against an Europa
>> configuration)/
>> I see it installed in configuration and see its 7 plugin in the about
>> plugin lists.
>> I also see the preference page for it, but when I do a compare of
>> ecore models, it comes up as a Text compare.
>> Am I missing a configuration setting here or what?
>> BTW, I did run Eclipse with a -clean start.
>> Also the only possibly related error that I see in the log is the
>> following:
>> !ENTRY org.eclipse.help 4 0 2007-07-17 14:19:22.406
>> !MESSAGE Error reading help table of contents file
>> /"org.eclipse.emf.compare.doc/tocconcepts.xml" (skipping file)
>> !STACK 0
>> java.io.FileNotFoundException
>> at
>> org.eclipse.help.internal.toc.TocFileParser.parse(TocFilePar ser.java:45)
>> Thanks
>> Alain
Re: [EMF Compare] Compares as Text compare [message #90274 is a reply to message #90245] |
Wed, 18 July 2007 06:18 |
Stephane LACRAMPE Messages: 217 Registered: July 2009 |
--------------050101080709000909060304
Thanks for the info Alain. Let us know if there is anything that we should do
Stephane LACRAMPE
Obeo
Alain Picard a
Stephane LACRAMPE
Obeo Canada
Re: [EMF Compare] Compares as Text compare [message #608775 is a reply to message #90198] |
Tue, 17 July 2007 19:53 |
--------------070701030608060900000505
When you say that you see the preference page, did you actually add the file extension in
You can do that with the preference panel in "General" then "Content types".
Stephane LACRAMPE
Alain Picard a
Stephane LACRAMPE
Obeo Canada
Re: [EMF Compare] Compares as Text compare [message #608776 is a reply to message #90215] |
Stéphane,
Merci,Thanks
Alain
> file extension in
> types".
> Cheers,
> Stephane LACRAMPE
>> configuration)/
>> plugin lists.
>> following:
>> !STACK 0
>> at
>> Thanks
>> Alain
Re: [EMF Compare] Compares as Text compare [message #608779 is a reply to message #90245] |
Stephane LACRAMPE
Obeo
Alain Picard a
Stephane LACRAMPE
Obeo Canada
FUDForum. Page generated in 0.03697 seconds
