Home » Eclipse Projects » Equinox » New Feature Not Detected
New Feature Not Detected [message #90190] Mon, 11 June 2007 18:41
Originally posted by: mark_melvin.amis.com
Hi There,
I have a problem which is driving me insane. I'm not sure if this belongs
here or if I should be posting this to the platform newsgroup, but here
goes.
This is a question about a problem with a product based on a full platform
runtime (3.3RC3), but I need help tracing through the OSGI stuff. I have
a weird bug that is only reproducible on one machine (it is not
reproducible on many other machines that I have tried). It involves new
features installed into an Eclipse site not being noticed. The features
and plugins are there in the features and plugins folders - but Eclipse
ignores them. I am running a "shared install" where the features and
plugins were installed by an administrator (using the Eclipse command line
update mechanism - called from our installer), but when I log in as a
regular user these features are not noticed and my user-specific
configuration area goes unmodified.
On every other machine I have tried this on, when I log in as a regular
user after performing the "update", my user-specific configuration area is
regenerated with the new information and the features are there. I cannot
for the life of me figure out what the heck is going on here. The failing
machine is a ghosted test machine that is basically completely clean
install of WinXP SP2. Why it works on every other machine is beyond me.
The only possible difference I can see is that this old machine is
FAT-based and all of the others I have tried are NTFS-based. The only
reason I mention this detail is because the act of updating (installing
the new feature) seems to create a lot of junk in the Local Settings\Temp
folder of the admin account (cached versions of the .JAR files), and the
configuration area of the administrator is also modified. But - this
should not matter as far as I understand things. When I fire up Eclipse
the next time as a restricted user - shouldn't it do some sort of
lightweight scan to determine if the configuration area needs to be
refreshed?
Oh, an important note. If I execute Eclipse with -clean, the feature is
detected. But this should not be necessary in my opinion. Although now
that I think about it...if you do not execute Eclipse with -clean, how
does Eclipse *ever* know you have installed additional features when you
are running in a "shared install" scenario? It looks to me like the
install information goes into the configuration area of the user that
installed the features - in this case the administrator. But this
doesn't make sense. How the heck would you *ever* be able to install new
features into a shared installation so they were accessible without doing
a -clean? And why the heck does it work for all of my machines except
one? I'm very confused... ;o)
I guess what I was hoping to find was:
1) More knowledge on exactly how the configuration areas know when
something has been added to the shared install, and thus need to refresh
themselves (in particular, regenerate platform.xml).
2) A way to further diagnose this problem - perhaps enabling some sort of
logging or secret console trick to show me why a feature may not have been
loaded.
I mention point #2 because if I do into Manage Configuration, and show
disabled features - it shows me the feature that it is failing to find and
it says it is disabled. However, I assume this may be a red herring
because it looks like the manage configuration tool scans the features and
plugins directories and then tries to match what it found to active
bundles.
Anyway, any enlightenment would be most welcome. I have spent over 2 days
on this so far.
Mark.
Previous Topic:Spring-OSGI and Equinox
Next Topic:Questions about contexts
Current Time: Sun Aug 31 04:28:16 EDT 2025
Powered by FUDForum. Page generated in 0.03184 seconds
