Home » Archived » M2M (model-to-model transformation) » Re: Model instance transformation framework
Re: Model instance transformation framework [message #90187] Thu, 18 September 2008 09:21 Go to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Christian,
The Eclipse Modeling Project's M2M sub-project has a number of options
available for model-to-model transformations, including ATL, QVT, and
oAW. You might browse their website and Wiki at eclipse.org and follow
up with questions on their newsgroup (which I have included in this reply).
HTH,
Christian
Christian Schršder wrote:
> I'm looking for a framework capable of transforming/merging EMF model
> instances.
> So far, I came across the GMT subproject "Epsilon" and the "Tiger" EMF
> Transformation Project.
> Epsilon does not seem to support model instance transformations at
> present but the project description promises "supports model management
> tasks for any kind of metamodel and model instances" in the future.
> As far as the metamodel tool support goes "Tiger" did not make a very
> reliable impression to me. Does anybody have experience with it's model
> instance transformation features?
> Are there any other suitable frameworks I could not find?
Re: Model instance transformation framework [message #90201 is a reply to message #90187] Thu, 18 September 2008 09:29 Go to previous message
Hi Christian,
Epsilon does support model transformation and in fact it also provides a
language (superset of the transformation language) that directly
addresses model merging.
Two examples of model transformation and merging using Epsilon are
available in http://www.eclipse.org/gmt/epsilon/doc/examples.php
("Transforming an Object Oriented model into a Relational Database
model" and "Merging two Object Oriented models" respectively).
Please feel free to ask any further questions about Epsilon in the
eclipse.epsilon newsgroup which I've included in this reply.
Dimitrios
Christian W. Damus wrote:
> Hi, Christian,
> HTH,
> Christian
>> instances.
>> management tasks for any kind of metamodel and model instances" in the
>> future.
>> model instance transformation features?
Previous Topic:[ATL] How to use UML with profile as input to a transformation
Next Topic:[ATL] Programmatically loading meta-models where one references the other
Current Time: Tue Jul 15 00:46:16 EDT 2025
Powered by FUDForum. Page generated in 0.05331 seconds
