Home » Archived » M2M (model-to-model transformation) » [ATL] load a model from plugins
[ATL] load a model from plugins [message #90111] |
Tue, 16 September 2008 09:24  |
I'm launching a transformation by code and I have an static model that it
is in plugins. I load this model,
catalogModel = emfamh.loadModel("IN", catalogMM,
URI.createPlatformPluginURI(pluginName + "/models/My.rulescatalog", true));
and then I launch ATL transformation, it throws an error.
If I load this model from workspace,
URI.createPlatformResourceURI("/proves/My.rulescatalog", true));
transformation is correct !!!
Question is, can I execute an ATL transformation and load a model that it
is in eclipse plugins ?¿?
Thanks!
Re: [ATL] load a model from plugins [message #90158 is a reply to message #90111] |
Thu, 18 September 2008 02:21   |
Originally posted by: Christos.Sofronis.parades.rm.cnr.it
Hello, the answer is yes (I'm using it lately).
I have the following
String PLATFORM_RESOURCE = "platform:/plugin/";
String rootAtlPath = PLATFORM_RESOURCE + Activator.PLUGIN_ID+"/";
String atlTransformationPath = rootAtlPath + "atl/transformation.asm";
// the above will create a string like this
// "platform:/plugin/plugin_id/atl/transformation.asm"
// which you load as follows
ASMModel model = emfamh.loadModel("modelName", metamodel, (new URL(atlTransformationPath)).openStream());
take care the metamodel to be the model of the model that you want to load and if in turn is a metamodel then use the
following:
metamodel = emfamh.getMof()
this works fine to me.
regards,
christos...
Miguel Llácer wrote:
> it is in plugins. I load this model,
> it is in eclipse plugins ?¿?
> Thanks!
Re: [ATL] load a model from plugins [message #90250 is a reply to message #90158] |
Mon, 22 September 2008 03:28   |
I don't know if you have understood me.
What I want to load is an input model to transformation that I have into
plugins, not in workspace.
I have tried it with an input uml model and it works correctly but, when I
try to do this with another model, transformation is executed but it
throws an error:
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: feature name does not exist on CATALOG!EObject
GRAVE: A.main() : ??#28 null
GRAVE: local variables = {self=catalog2configuration : ASMModule}
GRAVE: local stack = []
GRAVE: A.__exec__() : ??#28 null
GRAVE: local variables = {e=TransientLink {rule =
'ConfigurationPattern2ConfiguredPattern', sourceElements = {i =
IN!<unnamed>}, targetElements = {}, variables = {}},
GRAVE: A.__applyConfigurationPattern2ConfiguredPattern(1 :
NTransientLink;) : ??#31 299:4-299:30
GRAVE: local variables = {i=IN!<unnamed>, link=TransientLink {rule =
GRAVE: A.morePatterns(1 : MCATALOG!ConfigurationPattern;) : ??#1
307:7-307:34
GRAVE: local variables = {i=IN!<unnamed>, self=catalog2configuration :
ASMModule}
GRAVE: MCATALOG!ConfigurationPattern;.isGeneralizationPattern() : ??#26
99:5-99:19
GRAVE: local variables = {elem=IN!specificClass, self=IN!<unnamed>}
GRAVE: local stack = [false]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
GRAVE: feature name does not exist on CATALOG!EObject
java.lang.RuntimeException: feature name does not exist on CATALOG!EObject
What could be happening ?¿?
Thanks!!!
Re: [ATL] load a model from plugins [message #90503 is a reply to message #90446] |
Thu, 25 September 2008 06:13   |
Hello Miguel,
As Christos told you, yes it is possible.
His example show you how to load a model from a plugin (so this model
cannot be in workspace).
And in your first message, you initialized correctly your URI.
URI.createPlatformPluginURI(<plugin id>/<resourcePath>, false)
Here is an example of what I did :
String kdmMMpath ="org.omg.kdm/model/kdm.ecore";
// plugin id = org.omg.kdm, and resource path = /model/kdm.ecore
// load metamodel
ASMModel kdmMM = modelHandler.loadModel(
"KDM", modelHandler.getMof(),
URI.createPlatformPluginURI(this.kdmMMpath, false));
//Load model instances
ASMModel kdmModel = modelHandler.loadModel("input_kdm", kdmMM,
kdm_Model.getURI());
It is not so far from what you did, yet your stack trace show another
error (your model seems to be correctly loaded) :
==> your metamodel is perhaps not correctly loaded. ATL did not find
attribute name in your Catalog element.
--> Hi,
-->My question is:
-->Can I load input models in ATL if they are not in workspace ?¿?
-->Thanks.
Re: [ATL] load a model from plugins [message #90588 is a reply to message #90503] |
Fri, 26 September 2008 06:56   |
But, what you are loading with URI.createPlatformPluginURI() is not an
instance model, it is the metamodel !!!!!
----------------- YOUR EXAMPLE ------------------------
// load metamodel
----------------- MY EXAMPLE --------------------------
// load metamodel
ASMModel catalogMM = modelHandler.loadModel(
"CATALOG", modelHandler.getMof(),
CATALOGnsUri);
// load model instance
ASMModel catalogModel = modelHandler.loadModel("IN", catalogMM,
URI.createPlatformPluginURI(plugin + "/models/UML2DB.rulescatalog",
true));
As you can see, what I do it is to load the instance model from plugin and
not the metamodel.
Problem is not in loading the model, it is when I launch transformation.
Re: [ATL] load a model from plugins [message #90648 is a reply to message #90588] |
Mon, 29 September 2008 05:16  |
Hello Miguel,
I've tried to load a model (and not a meta model :-)).
And it seems that you have perhaps found a bug :
It works if model is in an other plugin. Yet if the model is located in
plugin where you write your code : it fails !
To have the good behavior when code and model are located in same plugin,
instead of using URI.createPlatformPluginURI, you can use :
Bundle bundle = Platform.getBundle("your plugin id");
URL fullPathString = bundle.getEntry("path of your model");
URI inputUri = URI.createURI(fullPathString.toString());
I hope it will help.
// load metamodel
// load metamodel
CATALOGnsUri);
true));
not the metamodel.
Current Time: Sun Aug 31 21:12:14 EDT 2025
Powered by FUDForum. Page generated in 0.05859 seconds
