Home » Language IDEs » ServerTools (WTP) » Web Service wizard
Web Service wizard [message #90030] Mon, 04 April 2005 07:18 Go to next message
Hi all
I'm using the web service wizard and when i click Next on the 'Service
Deployment Configuration' page I get the error IWAB0514E Unable to get URL
for project {0} - cab someone tell me what this means and how I go about
fixing it
Thanks in advance
Re: Web Service wizard [message #90760 is a reply to message #90030] Thu, 07 April 2005 14:03 Go to previous messageGo to next message
This error happens when the Web services wizard is unable to determine the
context root URL to the Web project you are trying to deploy your Web service
to, and is usually the result of an incorrectly configured Tomcat server. Did
you create the Web project yourself before running the Web service wizard, or
did you let the wizard create the project for you?
Cheers - CB.
plork123 wrote:
> Hi all
> fixing it
> Thanks in advance
Re: Web Service wizard [message #90865 is a reply to message #90760] Thu, 07 April 2005 18:46 Go to previous messageGo to next message
Originally posted by: lompafb.lompa.it
hallo,
i encountered the same problem: i created the dynamic web prject by myself
following following the instructiond i found in the "bottom up web service
tutorial". i installed tomcat before running the service (my version is
5.5.7), but i didn't start it. i also installed the server following the
instrucions in the same document.
in the "server" menu item, in project properties, the "target runtime"
value is "apache tomcat v5.0" and in the default server list box only the
items "none" and "tomcat v5.0 server @ localhost" are present. I cannot
find a way to configure this default server.
if i try to change the target runtime to "Apache tomcat v5.5" (the only
other available menu) the web service wizard tells me it cannot start the
server
thanx in advance, too
Michele Lombardi
Re: Web Service wizard [message #90895 is a reply to message #90865] Thu, 07 April 2005 19:29 Go to previous message
I solved the problem: it was only a server misconfiguration
thanx anyway
Previous Topic:error in web service deploying
Next Topic:Tutorial contribution
Current Time: Wed Aug 13 12:19:15 EDT 2025
Powered by FUDForum. Page generated in 0.03186 seconds
