Home » Archived » M2M (model-to-model transformation) » How to get the elements of a chain(list) in a Collection
How to get the elements of a chain(list) in a Collection [message #89985] Tue, 09 September 2008 11:35 Go to next message
I have the following problem, I would like to write a helper to get me all
the elements in a chain. The metamodel is that I have a process element
that can relate to other process. So it is possible to have a chain in the
model like process1 relates to proces2 which relates to process3 and so
on, so I would like to have all the processes in the chain as a
Collection, so that I can later on pass it as a parameter in a rule. I
tried the following code, but it only returns me the last element in the
chain ...
helper context processmap!Process def : getAllProcesses() :
OrderedSet(processmap!Process) =
self.relatesTo->iterate(process ; processes: OrderedSet(processmap!Process) =
OrderedSet {} |
if not(process.relatesTo->isEmpty()) then
(processes.append(process.getAllProcessesHelp()))
else processes.append(process)
endif
and my code I know for sure does not append also the first element in the
chain, meaning the self itself. I also know that probably my approach is
wrong as a process relates to only one other process, meaning that
self.relates to is not a Collection, so iteration over this is not a good
idea, but how otherwise to define a collection and to put the elements in
it?
Could somebody help me?
Thank you! Greets, Petko
Re: How to get the elements of a chain(list) in a Collection [message #90004 is a reply to message #89985] Tue, 09 September 2008 14:03 Go to previous messageGo to next message
Your approach to try to define a recursive helper is a good, like you
already noted the iterator is not a good idea:
if self.relatesTo.oclIsUndefined() then
self.relatesTo.getAllProcesses().including(self)
else
OrderedSet{self}
endif;
Alfons
OrderedSet {} |
endif
" Petko" <petko_iv@abv.bg> schreef in bericht
news:1fd920dacac8c48827855146565c0dbd$1@www.eclipse.org...
> chain ...
> OrderedSet(processmap!Process) = OrderedSet {} |
> endif
> it?
Re: How to get the elements of a chain(list) in a Collection [message #90019 is a reply to message #90004] Wed, 10 September 2008 05:40 Go to previous message
Thank you for the answer!!! It really helped, just a small thing, one
"not" has to be added :
if not(self.relatesTo.oclIsUndefined()) then ....
the recursive call has to be done only if there are further references
defined, meaning if they are not undefined.
10x once again for the answer,
Regards, Petko
Previous Topic:[ATL] Problems using UML2 models
Next Topic:[ATL] refininig and parameters passing
Current Time: Fri Jul 25 21:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.04280 seconds
