Creating web service [message #89969] |
Mon, 04 April 2005 05:54  |
Hi all,
I'm trying to create a web service using eclipse 3.1 and tomcat 5.o, but
keep getting am error - because I'm new to this I don't know how to fix
it.
Please can someone help me out
Thanks in advance
The error :
IWAB0213E Error in starting server.
org.eclipse.core.runtime.CoreException: Several ports (8005, 8080,
8009) required by Tomcat v5.0 Server @ localhost are already in use. The
server may already be running in another process, or a system process may
be using the port. To start this server you will need to stop the other
process or change the port number(s).
org.eclipse.jst.server.tomcat.core.internal.TomcatServerBeha viour.setupLaunch(TomcatServerBehaviour.java:281)
org.eclipse.jst.server.tomcat.core.internal.TomcatLaunchConf igurationDelegate.launch(TomcatLaunchConfigurationDelegate.j ava:43)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:152)
at org.eclipse.wst.server.core.internal.Server.start(Server.jav a:1231)
org.eclipse.wst.server.core.internal.Server.synchronousStart (Server.java:1458)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.startProject(AbstractStartServer.java:110)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.StartServer(AbstractStartServer.java:81)
org.eclipse.jst.ws.internal.consumption.command.common.Start ProjectCommand.execute(StartProjectCommand.java:106)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager.runForwardToNextStop(SimpleCommandEngineManager.java:1 75)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:69)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:91)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:123)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:741)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:338)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:123)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:244)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:421)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Creating web service [message #90000 is a reply to message #89969] |
Mon, 04 April 2005 06:24  |
Originally posted by: antoni.alatalo.kolumbus.fi
you are trying to start server, but there is some process that allready
use ports Tomcat needs. Check if Tomcat allready running or do you have
some other server running on you machine and stop it. Aftrer that you
are able to sart Tomcat from Eclipse.
Antoni
plork123 wrote:
> Hi all,
> it.
> Thanks in advance
> The error :
> may be using the port. To start this server you will need to stop the
> other process or change the port number(s).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.05275 seconds
