Home » Modeling » GMF (Graphical Modeling Framework) » Custom Figures in different plugin
Custom Figures in different plugin [message #89882] Fri, 05 January 2007 17:16 Go to next message
Originally posted by: martin.tauber.t-online.de
It's me again :-)
I have greated custom figures which I packed into a seperate plugin. Now
when I create the figures code I always have to modify the MANIFEST.MF
file. (BTW also for the generated diagram code). Is there a way to avoid
this?
Martin
Re: Custom Figures in different plugin [message #90320 is a reply to message #89882] Mon, 08 January 2007 05:34 Go to previous messageGo to next message
Originally posted by: tobk.gmx.de
Martin wrote:
> It's me again :-)
> this?
> Regards
> Martin
You can use the gmfgraph-file's "Generate Figures Plugin" action to change
all figures to custom figures being implemented in a seperate plugin
instead of in the edit parts. If you do not want to have this done
automatically try setting the attributes
name="GeneratedGallery"
implementationBundle="BASEPACKAGENAME.figures"
in the first figures-element in the gmfgraph's xml code (that one containing
all the other figures).
Hope this helps.
tobias
Re: Custom Figures in different plugin [message #90525 is a reply to message #90320] Mon, 08 January 2007 11:31 Go to previous messageGo to next message
Thanks Tobias,
this was exactly what I was looking for! Is this documented somewhere?
And here comes another question: When I use .gmfgraph's Create Figure
plugin action I always have to type in the plugin name (even though
what a surprice it didn't change). Is there a way to avoid this?
Thanks people of the eclipse
Martin
tobias schrieb:
> Martin wrote:
>> It's me again :-)
>> this?
>> Regards
>> Martin
> Hope this helps.
> tobias
Re: Custom Figures in different plugin [message #90787 is a reply to message #90525] Tue, 09 January 2007 05:08 Go to previous messageGo to next message
Martin Tauber wrote:
> Thanks Tobias,
> Martin
Why "always"? Basically you create the figures plugin once you have declared
all the figures you need and then continue handcoding the figures (which
gives you far more freedom in design than the gmfgraph).
tobias
> tobias schrieb:
>> Martin wrote:
>>> It's me again :-)
>>> this?
>>> Regards
>>> Martin
>> change all figures to custom figures being implemented in a seperate
>> plugin instead of in the edit parts. If you do not want to have this done
>> containing all the other figures).
>> Hope this helps.
>> tobias
Re: Custom Figures in different plugin [message #90818 is a reply to message #90787] Tue, 09 January 2007 06:20 Go to previous messageGo to next message
The point is I am not creating all figures at once. I add figures one
after the other. (Also I'm still playing around and I tend to delete the
created plugins just to make sure I still know what I'm doing ...)
>> Thanks Tobias,
>> Martin
> tobias
>> tobias schrieb:
>>> Martin wrote:
>>>> It's me again :-)
>>>> this?
>>>> Regards
>>>> Martin
>>> Hope this helps.
>>> tobias
Re: Custom Figures in different plugin [message #90907 is a reply to message #90818] Tue, 09 January 2007 09:48 Go to previous messageGo to next message
In this case you could Copypaste an existing Figure to a new File used by
the new Figure, creating a new CustomFigure in the gmfgraph and setting the
reference accordingly.
If you want to play around with the figure-creating capabilities of GMF I'd
recommend not to export the figures at all.
BTW, why _do_ you pack them in a different plugin? For me, I had to delete
and recreate the editor quite often to undo my "playing around" with
customizing and enhancing the editor, etc, and did not want to backup my
highly customized figures each time i did so.
Tobias
>>> Thanks Tobias,
>>> Martin
>> declared all the figures you need and then continue handcoding the
>> figures (which gives you far more freedom in design than the gmfgraph).
>> tobias
>>> tobias schrieb:
>>>> Martin wrote:
>>>>> It's me again :-)
>>>>> Now when I create the figures code I always have to modify the
>>>>> MANIFEST.MF file. (BTW also for the generated diagram code). Is there
>>>>> Regards
>>>>> Martin
>>>> done automatically try setting the attributes
>>>> Hope this helps.
>>>> tobias
Re: Custom Figures in different plugin [message #91772 is a reply to message #90907] Fri, 12 January 2007 02:25 Go to previous messageGo to next message
Well this is why I put the custom figures into a seperate plugin, so
that I just can delete them without effecting the generated figures.
This works quite fine, well except that I have to type in the plugin
name everytime I generate the non custom figures.
Martin
> Tobias
>>>> Thanks Tobias,
>>>> Martin
>>> tobias
>>>> tobias schrieb:
>>>>> Martin wrote:
>>>>>> It's me again :-)
>>>>>> Regards
>>>>>> Martin
>>>>> Hope this helps.
>>>>> tobias
Re: Custom Figures in different plugin [message #92559 is a reply to message #90320] Mon, 15 January 2007 04:15 Go to previous messageGo to next message
Originally posted by: fbfd.NOSPAMarcor.de
I also have a question regarding the Figures plug-in.
Using the described action I generated a plug-in that contains all the
figures. However, when I generate the editor code, it still creates
EditParts that contain internal Figure subclasses and the figures of
the Figures plug-in are not used.
I also changed the "implementation bundle" property of the Figures
gallery so that it matches the name of the Figures plug-in.
What am I doing wrong?
Any hints to documentation that I may have missed are also welcome.
Kind regards,
Fabian
On Mon, 08 Jan 2007 11:34:14 +0100, tobias <tobk@gmx.de> wrote:
>Martin wrote:
>> It's me again :-)
>> this?
>> Regards
>> Martin
>Hope this helps.
>tobias
Re: Custom Figures in different plugin [message #92724 is a reply to message #92559] Mon, 15 January 2007 08:44 Go to previous message
Ok, I had to recreate the GMF Generator Model.
Lot's of magic involved as usual..
On Mon, 15 Jan 2007 10:15:31 +0100, Fabian <fbfd@NOSPAMarcor.de>
wrote:
>Hi,
>Kind regards,
>Fabian
>>Martin wrote:
>>> It's me again :-)
>>> this?
>>> Regards
>>> Martin
>>Hope this helps.
>>tobias
Previous Topic:Difference between GEF and GMF
Next Topic:Status of M4?
Current Time: Mon Jul 14 08:31:23 EDT 2025
Powered by FUDForum. Page generated in 0.07638 seconds
