Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Lazy loading exception
[Teneo] Lazy loading exception [message #89737] |
Fri, 13 July 2007 07:03  |
We have number of emf models and nearly all have lazy initialization.
The problem is due to number of threads working asynchronously due to
user's action leaving GUI active. When one thread is accessing a model
class and if it is first time then list gets loaded (e.g.
obj.getChildren() ) and that works fine. But if at the same time another
thread tries to access the same when objects are being loaded because of
another thread then it throws error:
org.hibernate.LazyInitializationException: illegal access to loading
collection
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
org.hibernate.collection.AbstractPersistentCollection.readSi ze(AbstractPersistentCollection.java:109)
at org.hibernate.collection.PersistentList.size(PersistentList. java:91)
org.eclipse.emf.common.util.DelegatingEList.delegateSize(Del egatingEList.java:223)
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:401)
org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:214)
org.eclipse.emf.common.util.DelegatingEList$EIterator.hasNex t(DelegatingEList.java:1000)
So I am just wondering if there is some solution/suggestion for this
problem.
Thanks.
PS: Using emf 2.2, teneo 0.7.5
Re: [Teneo] Lazy loading exception [message #89782 is a reply to message #89753] |
Fri, 13 July 2007 09:37   |
Hi Martin,
Thanks for feedback.
Yes, any hints/suggestions will be appreciated.
At the moment, as a fix and to check, at one place what I did is, put
that code in a loop and comes out when it doesn't throw that particular
error or otherwise. And that worked. But I don't want to go to that
route as it is not clean and another thing that this way it is not
possible to cover everything until unless we put such ugly code everywhere.
Synchronizing generated model will be difficult, again too much code.
So another thought is if some of teneo methods (relevant to lazy loading
concept) can be synchronized then that should fix, will it? like
Thanks.
Martin Taal wrote:
> It is a complex issue because hibernate session are not multi-threaded.
> In the ideal world only one thread at the time has access to a model
> object (tree). So if you can synchronize access to 'uninitialized' model
> objects then that would help.
> What could help for this case is to ensure that when a persistable list
> is loading that no one else can access it (make it synchronized it in
> specific places). If you want to go down this road then let me know I
> can give you some hints on how to do this.
> However, fighting this symptom does not guarantee that no other issues
> will arise (because a hb session is not multi-threaded).
> gr. Martin
> PC wrote:
>> another thread tries to access the same when objects are being loaded
>> because of another thread then it throws error:
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> this problem.
>> Thanks.
Re: [Teneo] Lazy loading exception [message #89796 is a reply to message #89782] |
Fri, 13 July 2007 10:12   |
In the new version this is easier to do but for the 0.7.5 version the following needs to be done:
1) Create a subclass of HibernatePersistableEList, override only the getDelegate method and
synchronize it.
2) Create a subclass of EListPropertyHandler and override the createPersistableList method. Instead
of creating the standard HibernatePeristableEList in this method create your elist (step 1)
3) Create a subclass of HbContextImpl and override the method createEListAccessor which should
return an instance of the class you created in step 2
4) Create a subclass of HbDataStore and override the getHbContext method, return an instance of the
HbContextImpl class you created in step 3.
There are a number of classes to override but the override step is very simple (only one method)
each time.
gr. Martin
PC wrote:
> Hi Martin,
> Thanks.
> Martin Taal wrote:
>> multi-threaded. In the ideal world only one thread at the time has
>> access to a model object (tree). So if you can synchronize access to
>> 'uninitialized' model objects then that would help.
>> list is loading that no one else can access it (make it synchronized
>> it in specific places). If you want to go down this road then let me
>> know I can give you some hints on how to do this.
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> model class and if it is first time then list gets loaded (e.g.
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> this problem.
>>> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Lazy loading exception [message #89837 is a reply to message #89796] |
Mon, 16 July 2007 05:32  |
That’s great Martin, thanks.
This month we are intending to upgrade to eclipse 3.3 and so we will
also use new version of emf and teneo. So I guess I will do this fix as
per new version of teneo. Hopefully, I think it will be easy to figure
out the same for the new version of teneo as per your comments. But if
there are some specifics which I should do for new version of teneo then
please do let me know. And again as always help much appreciated.
- Parvez
> getDelegate method and synchronize it.
> createPersistableList method. Instead of creating the standard
> createEListAccessor which should return an instance of the class you
> created in step 2
> method, return an instance of the HbContextImpl class you created in
> step 3.
> simple (only one method) each time.
> gr. Martin
> PC wrote:
>> Hi Martin,
>> particular error or otherwise. And that worked. But I don't want to go
>> to that route as it is not clean and another thing that this way it is
>> not possible to cover everything until unless we put such ugly code
>> everywhere.
>> loading concept) can be synchronized then that should fix, will it?
>> like
>> Thanks.
>> Martin Taal wrote:
>>> Hi,
>>> issues will arise (because a hb session is not multi-threaded).
>>> gr. Martin
>>> PC wrote:
>>>> Hi,
>>>> to user's action leaving GUI active. When one thread is accessing a
>>>> loaded because of another thread then it throws error:
>>>> collection
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> this problem.
>>>> Thanks.
Re: [Teneo] Lazy loading exception [message #608745 is a reply to message #89737] |
Fri, 13 July 2007 07:37  |
It is a complex issue because hibernate session are not multi-threaded. In the ideal world only one
thread at the time has access to a model object (tree). So if you can synchronize access to
What could help for this case is to ensure that when a persistable list is loading that no one else
can access it (make it synchronized it in specific places). If you want to go down this road then
let me know I can give you some hints on how to do this.
However, fighting this symptom does not guarantee that no other issues will arise (because a hb
gr. Martin
PC wrote:
> collection
> at
> at
> at
> at
> at
> at
> at
> problem.
> Thanks.
The Netherlands
Re: [Teneo] Lazy loading exception [message #608747 is a reply to message #89753] |
Hi Martin,
Thanks.
Martin Taal wrote:
> gr. Martin
> PC wrote:
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> this problem.
>> Thanks.
Re: [Teneo] Lazy loading exception [message #608748 is a reply to message #89782] |
synchronize it.
each time.
gr. Martin
PC wrote:
> Hi Martin,
> Thanks.
> Martin Taal wrote:
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> this problem.
>>> Thanks.
The Netherlands
Re: [Teneo] Lazy loading exception [message #608751 is a reply to message #89796] |
- Parvez
> created in step 2
> step 3.
> gr. Martin
> PC wrote:
>> Hi Martin,
>> everywhere.
>> like
>> Thanks.
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>> PC wrote:
>>>> Hi,
>>>> collection
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> this problem.
>>>> Thanks.
Current Time: Tue Jul 22 14:48:49 EDT 2025
Powered by FUDForum. Page generated in 0.06292 seconds
