Home » Language IDEs » Java Development Tools (JDT) » How can I run or debug my project
How can I run or debug my project [message #89568] |
Wed, 27 August 2003 09:18  |
Originally posted by: llchen.nortelnetworks.com
Hi, I used have the run or debug window pops out when I clicks the run...
or debug... menu. But for some how, it stops poping out the window
recently, when Iclicks the run... or debug... menu. I can still run/debug
the project by selecting run as or debug as. But without the run or debug
dialog box poping out, I can't change the settings for the runtime
environment. It's quite anoying. I tried to reinstall the eclipse but it
does not help. I badly need your help. I just can't figure out what's
wrong.
Re: How can I run or debug my project [message #89693 is a reply to message #89656] |
Wed, 27 August 2003 13:20   |
The problem I have is that I can't get the launch configuration window
poping out. If I clicks the run... or debug... menu, nothing happens.
Louis
Darin Wright wrote:
> The first time you press run or debug in a new workspace, the launch
> configuration dialog opens to allow you to create a launch configuration to
> run or debug. After that, the run and debug buttons simply re-launch the
> previously launched configuration. I.e. re-run or re-debug the last thing
> you ran or debugged. You can also use the drop down history in the run/debug
> menus to launch previously launched configs.
> You can create new configs by using the "run/debug as" menus, or by opening
> the launch dialog (Run...., or Debug...).
> Darin
> "Louis Chen" <llchen@nortelnetworks.com> wrote in message
> news:biib34$fbb$1@eclipse.org...
> > wrong.
Re: How can I run or debug my project [message #89814 is a reply to message #89693] |
Wed, 27 August 2003 17:22   |
Is there an error in the .log? Sounds like a bug.
Darin
news:biip92$1g3$1@eclipse.org...
> Louis
to
thing
run/debug
opening
> > Darin
run...
run/debug
debug
it
> > > wrong.
Re: How can I run or debug my project [message #90009 is a reply to message #89814] |
Thu, 28 August 2003 08:59   |
Do you know if there is a log file at some where for eclipse? I just can't
find it. Yesterday I got the launch screen for some time, but failed to
launch it later. And no luck this morning as well.
Louis
> Darin
> > Louis
> to
> thing
> run/debug
> opening
> > > Darin
> run...
> run/debug
> debug
> it
> > > > wrong.
Re: How can I run or debug my project [message #90885 is a reply to message #90423] |
Fri, 29 August 2003 16:16   |
I did a clean install and I got the launch window back. But this time I
got the unexpected Ant error as the following:
[junit] BUILD FAILED:
file:M:/llchen_FWK.r3_3_Server_Side_Security/mft_security/ba se/policy_eval/test/build.xml:432:
Could not create task or type of type: junit.
Ant could not find the task or a class this task relies upon.
This is common and has a number of causes; the usual
solutions are to read the manual pages then download and
install needed JAR files, or fix the build file:
- You have misspelt 'junit'.
Fix: check your spelling.
- The task needs an external JAR file to execute
and this is not found at the right place in the classpath.
Fix: check the documentation for dependencies.
Fix: declare the task.
- The task is an Ant optional task and optional.jar is absent
Fix: look for optional.jar in ANT_HOME/lib, download if needed
- The task was not built into optional.jar as dependent
libraries were not found at build time.
Fix: look in the JAR to verify, then rebuild with the needed
libraries, or download a release version from apache.org
- The build file was written for a later version of Ant
Fix: upgrade to at least the latest release version of Ant
- The task is not an Ant core or optional task
and needs to be declared using <taskdef>.
Remember that for JAR files to be visible to Ant tasks implemented
in ANT_HOME/lib, the files must be in the same directory or on the
classpath
Please neither file bug reports on this problem, nor email the
Ant mailing lists, until all of these causes have been explored,
as this is not an Ant bug.
The same build.xml runs fine before I re-install the eclipse.
I don't have any clue what's going on.
Louis
Darin Wright wrote:
> I would try to a clean install of Eclipse (but keep your workspace) -
> something looks messed up.
> Darin
> news:bil9ud$igj$1@eclipse.org...
> > Hi,
> > I got the full stack trace from the .log file ss the following. It seems
> > it failed to load text color for the launch window, and then got the null
> > pointer exception. I just can't fingure out what's wrong.
> > Louis
> > *** Stack trace of contained exception ***
> > !ENTRY org.eclipse.ui 4 0 Aug 28, 2003 12:14:16.501
> > !MESSAGE org/eclipse/jface/text/source/ISharedTextColors
> > !STACK 0
> > java.lang.NoClassDefFoundError:
> > at java.lang.ClassLoader.defineClass0(Native Method)
> > at java.lang.ClassLoader.defineClass(Unknown Source)
> > at java.security.SecureClassLoader.defineClass(Unknown Source)
> > at java.net.URLClassLoader.defineClass(Unknown Source)
> > at java.net.URLClassLoader.access$100(Unknown Source)
> > at java.net.URLClassLoader$1.run(Unknown Source)
> > at java.security.AccessController.doPrivileged(Native Method)
> > at java.net.URLClassLoader.findClass(Unknown Source)
> > at
> org.eclipse.core.internal.boot.DelegatingURLClassLoader.find Class(Delegating
> URLClassLoader.java:922)
> > at
> org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParents
> Self(PluginClassLoader.java:166)
> > at
> org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf
> (DelegatingURLClassLoader.java:490)
> > at
> org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
> URLClassLoader.java:882)
> > at
> URLClassLoader.java:862)
> > at java.lang.ClassLoader.loadClass(Unknown Source)
> > at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> > at
> org.eclipse.ui.externaltools.internal.model.ExternalToolsPlu gin.getPreferenc
> eColor(ExternalToolsPlugin.java:225)
> > at
> org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntConsoleCol
> orProvider.getColor(AntConsoleColorProvider.java:30)
> > at
> org.eclipse.debug.internal.ui.views.console.ConsoleViewer.li neGetStyle(Conso
> leViewer.java:451)
> > at
> org.eclipse.swt.custom.StyledTextListener.handleEvent(Styled TextListener.jav
> a:49)
> > at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
> > at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
> > at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:865)
> > at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:849)
> > at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 56)
> > at org.eclipse.swt.custom.StyledText.sendLineEvent(StyledText.j ava:3944)
> > at
> > org.eclipse.swt.custom.StyledText.getLineStyleData(StyledTex t.java:3996)
> > at
> org.eclipse.swt.custom.DisplayRenderer.getLineStyleData(Disp layRenderer.java
> :217)
> > at
> org.eclipse.swt.custom.StyledText$ContentWidthCache.contentW idth(StyledText.
> java:1258)
> > at
> org.eclipse.swt.custom.StyledText$ContentWidthCache.calculat e(StyledText.jav
> a:1212)
> > at
> org.eclipse.swt.custom.StyledText.calculateContentWidth(Styl edText.java:1915
> > at org.eclipse.swt.custom.StyledText.reset(StyledText.java:6635 )
> > at org.eclipse.swt.custom.StyledText.handleTextSet(StyledText.j ava:5434)
> > at org.eclipse.swt.custom.StyledText$6.textSet(StyledText.java: 4925)
> > at
> org.eclipse.jface.text.DocumentAdapter.fireTextSet(DocumentA dapter.java:293)
> > at
> org.eclipse.jface.text.DocumentAdapter.documentChanged(Docum entAdapter.java:
> 226)
> > at
> org.eclipse.jface.text.AbstractDocument.fireDocumentChanged( AbstractDocument
> ..java:543)
> > at
> > org.eclipse.jface.text.AbstractDocument.replace(AbstractDocu ment.java:845)
> > at
> org.eclipse.debug.internal.ui.views.console.ConsoleDocumentP artitioner$2.run
> (ConsoleDocumentPartitioner.java:644)
> > at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> > at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
> > at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1815)
> > at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1549)
> > at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
> > at org.eclipse.jface.window.Window.open(Window.java:563)
> > at org.eclipse.jface.dialogs.ErrorDialog.open(ErrorDialog.java: 303)
> > at org.eclipse.jface.dialogs.ErrorDialog.openError(ErrorDialog. java:366)
> > at org.eclipse.jface.dialogs.ErrorDialog.openError(ErrorDialog. java:329)
> > at
> org.eclipse.debug.internal.ui.DebugUIPlugin.errorDialog(Debu gUIPlugin.java:3
> 91)
> > at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:5 12)
> > at org.eclipse.debug.ui.actions.LaunchAction.run(LaunchAction.j ava:66)
> > at
> org.eclipse.debug.ui.actions.LaunchAction.runWithEvent(Launc hAction.java:81)
> > at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
> ContributionItem.java:456)
> > at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
> ributionItem.java:403)
> > at
> org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
> tem.java:397)
> > at
> org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
> ctionContributionItem.java:72)
> > at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
> > at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
> > at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
> > at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
> > at
> org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
> a:858)
> > at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
> > at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
> > at java.lang.reflect.Method.invoke(Unknown Source)
> > at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
> > at org.eclipse.core.launcher.Main.run(Main.java:703)
> > at org.eclipse.core.launcher.Main.main(Main.java:539)
> > !ENTRY org.eclipse.ui 4 4 Aug 28, 2003 12:14:26.696
> > !MESSAGE Unhandled exception caught in event loop.
> > !ENTRY org.eclipse.ui 4 0 Aug 28, 2003 12:14:26.716
> > !MESSAGE java.lang.NullPointerException
> > !STACK 0
> > at
> org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialo
> g.doInitialTreeSelection(LaunchConfigurationsDialog.java:401 )
> > at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:35 9)
> > at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> > at
> org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(Debug
> UITools.java:373)
> > at
> UITools.java:315)
> > at
> org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogActi
> on.java:70)
> > at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
> > at
> > at
> > at
> tem.java:397)
> > at
> > at
> a:858)
> > !ENTRY org.eclipse.ui 4 4 Aug 28, 2003 12:14:26.746
> > !ENTRY org.eclipse.ui 4 0 Aug 28, 2003 12:14:26.766
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> leViewer.java:451)
> > at
> a:49)
> > at
> > at
> :217)
> > at
> org.eclipse.swt.custom.StyledTextRenderer.drawLine(StyledTex tRenderer.java:1
> 03)
> > at org.eclipse.swt.custom.StyledText.performPaint(StyledText.ja va:5914)
> > at org.eclipse.swt.custom.StyledText.handlePaint(StyledText.jav a:5288)
> > at org.eclipse.swt.custom.StyledText$13.handleEvent(StyledText. java:4988)
> > at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:73 0)
> > at org.eclipse.swt.widgets.Control.windowProc(Control.java:2817 )
> > at org.eclipse.swt.widgets.Display.windowProc(Display.java:2361 )
> > at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
> > at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:13 03)
> > at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1543)
> > at
> a:858)
> > Eric Rizzo wrote:
> can't
> > > > find it.
> > > workspace/.metadata/.log
> > > HTH,
> > > Eric
Re: How can I run or debug my project [message #90901 is a reply to message #90885] |
Fri, 29 August 2003 16:25   |
It would appear that the Ant runtime classpath has been changed to not
include the junit.jar.
Darins
news:biocao$hf2$1@eclipse.org...
est/build.xml:432:
> classpath
> Louis
> > Darin
> > > Hi,
seems
null
> > > Louis
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > leViewer.java:451)
> > > at
> > a:49)
> > > at
> > > at
> > > at
> > :217)
> > > at
> > java:1258)
> > > at
> > a:1212)
> > > at
> > > at
> > > at
> > > at
> > 226)
> > > at
> > ..java:543)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > 91)
> > > at
> > > at
> > > at
> > > at
> > tem.java:397)
> > > at
> > > at
> > > at
> > a:858)
> > > !STACK 0
> > > at
> > > at
> > > at
> > UITools.java:373)
> > > at
> > UITools.java:315)
> > > at
> > on.java:70)
> > > at
> > > at
> > > at
> > tem.java:397)
> > > at
> > > at
> > > at
> > a:858)
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > leViewer.java:451)
> > > at
> > a:49)
> > > at
> > > at
> > > at
> > :217)
> > > at
> > 03)
> > > at
> > > at
> > > at
> > a:858)
> > > Eric Rizzo wrote:
just
> > can't
> > > > > find it.
> > > > HTH,
> > > > Eric
Re: How can I run or debug my project [message #94529 is a reply to message #90901] |
Thu, 11 September 2003 09:18  |
Hi, Darin:
I still fail to get the launch window from time to time. If that happens,
I have to launch the property view of the project, select some properties
and then click Ok to close the property view. After that then I can get
the launch window back. I don't know why it behaves like that on my
machine. I noticed that after I click the Ok button to close the project
property view, it writes some data back to the disk to update the project
settings. Maybe the io blocks the launch window poping up?
Another question: my project is in the version control system, the
ClearCase. I check out all the project related files out and modify all
the settings. Most of the settings are local to my machine and will be
changed by others. If I want to preserve my own settings for the project,
is there a way for me to import/export all the project settings?
Louis
> Darins
> est/build.xml:432:
> > classpath
> > Louis
> > > Darin
> > > > Hi,
> seems
> null
> > > > Louis
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > leViewer.java:451)
> > > > at
> > > a:49)
> > > > at
> > > > at
> > > > at
> > > :217)
> > > > at
> > > java:1258)
> > > > at
> > > a:1212)
> > > > at
> > > > at
> > > > at
> > > > at
> > > 226)
> > > > at
> > > ..java:543)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > 91)
> > > > at
> > > > at
> > > > at
> > > > at
> > > tem.java:397)
> > > > at
> > > > at
> > > > at
> > > a:858)
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > UITools.java:373)
> > > > at
> > > UITools.java:315)
> > > > at
> > > on.java:70)
> > > > at
> > > > at
> > > > at
> > > tem.java:397)
> > > > at
> > > > at
> > > > at
> > > a:858)
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > leViewer.java:451)
> > > > at
> > > a:49)
> > > > at
> > > > at
> > > > at
> > > :217)
> > > > at
> > > 03)
> > > > at
> > > > at
> > > > at
> > > a:858)
> > > > Eric Rizzo wrote:
> just
> > > can't
> > > > > > find it.
> > > > > HTH,
> > > > > Eric
Current Time: Mon Jul 21 21:02:08 EDT 2025
Powered by FUDForum. Page generated in 0.09283 seconds
