Home » Archived » M2M (model-to-model transformation) » [ATL] EMF Resource
[ATL] EMF Resource [message #89397] Fri, 29 August 2008 15:14 Go to next message
Hi all,
I'm trying to load objects using a EMF Resource into a model. I use the
Model class from EMF-VM. My problem is that when i try to instantiate a
Model via the constructor Model(metamodel, resource) and use it in an ATL
transformation, this latter seems to see the model as empty.
But when i create a Model by loading a file from the filesystem, the
transformation goes well. So what is the best way for loading a Model from
an EMF Resource ?
Guillaume
Re: [ATL] EMF Resource [message #89442 is a reply to message #89397] Sat, 30 August 2008 16:18 Go to previous message
You should use the ASMModelHandler to load models, it does allot more things
than only loading the model. It comes in EMF and MDR flavor.
Alfons
"Guillaume Hillairet" <g.hillairet@gmail.com> schreef in bericht
news:457d750a6096dd9ed117b947870e97b7$1@www.eclipse.org...
> Hi all,
> transformation, this latter seems to see the model as empty. But when i
> create a Model by loading a file from the filesystem, the transformation
> goes well. So what is the best way for loading a Model from an EMF
> Resource ?
> Guillaume
Previous Topic:[ATL] Transformation in xmi format?
Next Topic:[ATL] Use Case - Rational Rose to UML2 Tools
Current Time: Sun Aug 31 23:26:49 EDT 2025
Powered by FUDForum. Page generated in 0.03643 seconds
