Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] another problems: my datas are modified by Teneo
[Teneo] another problems: my datas are modified by Teneo [message #89396] |
Thu, 12 July 2007 11:11  |
Originally posted by: doux.guil.gmail.com
--------------050800070506060004000300
Hi again,
I'm sorry to have another question but I have a second problem with Teneo.
I use Teneo to store EPackage contained in .ecore files.
My problem is that when I want to get an EPackage from Teneo, this
package has been modified.
When I export it into another .ecore file I see that the "eType" and the
"instanceClassName" attributes of the "eClassifiers" elements have been
deleted...
Can you explain me why and how to avoid it ?
Thanks for your help,
Guillaume
PS : I joined my in ecore file (deb.ecore), my out ecore file
(resulting_deb.ecore) and the class which make them (addget.java).
Content-Type: text/xml;
name="deb.ecore"
Content-Disposition: inline;
filename="deb.ecore"
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<ecore:EPackage name="PrimitiveTypes" nsURI="atl.primitive.type" nsPrefix="ptyp">
<eClassifiers xsi:type="ecore:EDataType" name="Boolean" instanceClassName="boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer" instanceClassName="int"/>
<eClassifiers xsi:type="ecore:EDataType" name="String" instanceClassName="java.lang.String"/>
</ecore:EPackage>
<ecore:EPackage name="deb" nsURI="my.model.of.debian.package" nsPrefix="deb">
<eClassifiers xsi:type="ecore:EClass" name="Deb">
<eStructuralFeatures xsi:type="ecore:EReference" name="metadata" ordered="false"
lowerBound="1" eType="#/1/Databin" containment="true" eOpposite="#/1/Databin/debpm"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="control" ordered="false"
lowerBound="1" eType="#/1/Archcontrol" containment="true" eOpposite="#/1/Archcontrol/debc"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="data" ordered="false"
lowerBound="1" eType="#/1/Archdata" containment="true" eOpposite="#/1/Archdata/debd"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" ordered="false"
unique="false" lowerBound="1" eType="#/0/String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Databin">
<eStructuralFeatures xsi:type="ecore:EReference" name="debpm" ordered="false"
lowerBound="1" eType="#/1/Deb" eOpposite="#/1/Deb/metadata"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="blocs" ordered="false"
upperBound="-1" eType="#/1/Bloc" containment="true" eOpposite="#/1/Bloc/meta"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Bloc">
<eStructuralFeatures xsi:type="ecore:EReference" name="meta" ordered="false"
lowerBound="1" eType="#/1/Databin" eOpposite="#/1/Databin/blocs"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="field" ordered="false"
upperBound="-1" eType="#/1/Field" containment="true" eOpposite="#/1/Field/blocs"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Field" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="val" ordered="false"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" ordered="false"
lowerBound="1" eType="#/1/Bloc" eOpposite="#/1/Bloc/field"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Version" eSuperTypes="#/1/Field"/>
<eClassifiers xsi:type="ecore:EClass" name="package_name" eSuperTypes="#/1/Field"/>
<eClassifiers xsi:type="ecore:EClass" name="Dependancy" eSuperTypes="#/1/Field"/>
<eClassifiers xsi:type="ecore:EClass" name="package_descriptions" eSuperTypes="#/1/Field"/>
<eClassifiers xsi:type="ecore:EClass" name="Script_descriptions" eSuperTypes="#/1/Field"/>
<eClassifiers xsi:type="ecore:EClass" name="Archcontrol">
<eStructuralFeatures xsi:type="ecore:EReference" name="debc" ordered="false"
lowerBound="1" eType="#/1/Deb" eOpposite="#/1/Deb/control"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="scripts" ordered="false"
upperBound="-1" eType="#/1/Script" containment="true" eOpposite="#/1/Script/archscript"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Script">
<eStructuralFeatures xsi:type="ecore:EReference" name="archscript" ordered="false"
lowerBound="1" eType="#/1/Archcontrol" eOpposite="#/1/Archcontrol/scripts"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="script_name" ordered="false"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="code" ordered="false"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Archdata">
<eStructuralFeatures xsi:type="ecore:EReference" name="debd" ordered="false"
lowerBound="1" eType="#/1/Deb" eOpposite="#/1/Deb/data"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="fil" ordered="false"
upperBound="-1" eType="#/1/File" containment="true" eOpposite="#/1/File/data"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="File">
lowerBound="1" eType="#/1/Archdata" eOpposite="#/1/Archdata/fil"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="filename" ordered="false"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="location" ordered="false"
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
name="resulting_deb.ecore"
filename="resulting_deb.ecore"
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer"/>
<eClassifiers xsi:type="ecore:EDataType" name="String"/>
</ecore:EPackage>
lowerBound="1" containment="true" eOpposite="#/1/Databin/debpm"/>
lowerBound="1" containment="true" eOpposite="#/1/Archcontrol/debc"/>
lowerBound="1" containment="true" eOpposite="#/1/Archdata/debd"/>
unique="false" lowerBound="1"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Deb/metadata"/>
upperBound="-1" containment="true" eOpposite="#/1/Bloc/meta"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Databin/blocs"/>
upperBound="-1" containment="true" eOpposite="#/1/Field/blocs"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Bloc/field"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Version">
<eGenericSuperTypes eClassifier="#/1/Field"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="package_name">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Dependancy">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="package_descriptions">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Script_descriptions">
</eClassifiers>
lowerBound="1" eOpposite="#/1/Deb/control"/>
upperBound="-1" containment="true" eOpposite="#/1/Script/archscript"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Archcontrol/scripts"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Deb/data"/>
upperBound="-1" containment="true" eOpposite="#/1/File/data"/>
</eClassifiers>
lowerBound="1" eOpposite="#/1/Archdata/fil"/>
</eClassifiers>
</ecore:EPackage>
</ecore:EPackage>
lowerBound="1" containment="true" eOpposite="#/3/Databin/debpm"/>
lowerBound="1" containment="true" eOpposite="#/3/Archcontrol/debc"/>
lowerBound="1" containment="true" eOpposite="#/3/Archdata/debd"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Deb/metadata"/>
upperBound="-1" containment="true" eOpposite="#/3/Bloc/meta"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Databin/blocs"/>
upperBound="-1" containment="true" eOpposite="#/3/Field/blocs"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Bloc/field"/>
</eClassifiers>
<eGenericSuperTypes eClassifier="#/3/Field"/>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Deb/control"/>
upperBound="-1" containment="true" eOpposite="#/3/Script/archscript"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Archcontrol/scripts"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Deb/data"/>
upperBound="-1" containment="true" eOpposite="#/3/File/data"/>
</eClassifiers>
lowerBound="1" eOpposite="#/3/Archdata/fil"/>
</eClassifiers>
</ecore:EPackage>
</ecore:EPackage>
lowerBound="1" containment="true" eOpposite="#/5/Databin/debpm"/>
lowerBound="1" containment="true" eOpposite="#/5/Archcontrol/debc"/>
lowerBound="1" containment="true" eOpposite="#/5/Archdata/debd"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Deb/metadata"/>
upperBound="-1" containment="true" eOpposite="#/5/Bloc/meta"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Databin/blocs"/>
upperBound="-1" containment="true" eOpposite="#/5/Field/blocs"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Bloc/field"/>
</eClassifiers>
<eGenericSuperTypes eClassifier="#/5/Field"/>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Deb/control"/>
upperBound="-1" containment="true" eOpposite="#/5/Script/archscript"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Archcontrol/scripts"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Deb/data"/>
upperBound="-1" containment="true" eOpposite="#/5/File/data"/>
</eClassifiers>
lowerBound="1" eOpposite="#/5/Archdata/fil"/>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
Content-Type: text/x-java;
name="addget.java"
filename="addget.java"
package test;
import java.io.IOException;
import java.util.Collections;
import java.util.Properties;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.annotations.pannotation.InheritanceTyp e;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.eclipse.emf.teneo.hibernate.HbSessionDataStore;
import org.eclipse.emf.teneo.hibernate.resource.HibernateResource;
import org.hibernate.Query;
import org.hibernate.Session;
import org.hibernate.SessionFactory;
import org.hibernate.Transaction;
import org.hibernate.cfg.Environment;
import org.hibernate.event.InitializeCollectionEventListener;
public class addget {
// work folder
public static String loc = "/home/doux/temp/";
// work resourceSet
private static ResourceSet resTeneo;
private static ResourceSet resourceSet;
// name of the database
private static String dbname = "test";
// the datastore
private static HbDataStore hbds;
// the name of the datastore
private static String hbName = "MySF";
public static void main(String[] args){
resTeneo = new ResourceSetImpl();
resTeneo.getResourceFactoryRegistry().getExtensionToFactoryM ap().put( "ecore",
new EcoreResourceFactoryImpl());
resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "ecore",
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "doux");
props.setProperty(Environment.URL, "jdbc:mysql://127.0.0.1:3306/" + dbname);
props.setProperty(Environment.PASS, "provisoiredoux");
props.setProperty(Environment.DIALECT, org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, InheritanceType.SINGLE_TABLE_LITERAL.getName());
// create the HbDataStore
hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
// set the relational database to use and other properties
hbds.setHibernateProperties(props);
EPackage[] tpack = new EPackage[]{EcorePackage.eINSTANCE};
// configure EPackage used in this datastore
hbds.setEPackages(tpack);
hbds.initialize();
final EMFInitializeCollectionEventListener eventListener = new EMFInitializeCollectionEventListener();
((HbSessionDataStore)hbds).getConfiguration().getEventListen ers().setInitializeCollectionEventListeners
(new InitializeCollectionEventListener[] { eventListener });
try {
//loading a meta-model from an ecore file
String uri = loc+"deb.ecore";
Resource res = resourceSet.createResource(URI.createFileURI(uri));
res.load(null);
//making it persistent with Teneo
String uristr = "hibernate://?" + HibernateResource.DS_NAME_PARAM + "=" + hbName;
Resource resourceT = resTeneo.createResource(URI.createURI(uristr));
resourceT.getContents().addAll(res.getContents());
resourceT.save(null);
//retrieve this package from Teneo
String uristr2 = "hibernate://?" + HibernateResource.DS_NAME_PARAM + "=" + hbName+"&query1 =FROM EPackage";
Resource resout = resTeneo.createResource(URI.createURI(uristr));
resout.load(null);
//Serialization of this resource into an ecore file
String uri_res = loc+"resulting_deb.ecore";
Resource result = resourceSet.createResource(URI.createFileURI(uri_res));
result.getContents().addAll(resout.getContents());
result.save(null);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
--------------050800070506060004000300--
Re: [Teneo] another problems: my datas are modified by Teneo [message #89412 is a reply to message #89396] |
Thu, 12 July 2007 11:15   |
--------------010809090604000405000103
Sorry I have post a bad output file...
This is the good one...
Guillaume
doux guillaume wrote:
> Hi again,
> deleted...
> Guillaume
> </ecore:EPackage>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
> package test;
> // work folder
> // work resourceSet
> // the datastore
> hbds.initialize();
> try {
> res.load(null);
> resout.load(null);
> result.save(null);
</ecore:EPackage>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
--------------010809090604000405000103--
Re: [Teneo] another problems: my datas are modified by Teneo [message #89429 is a reply to message #89412] |
Thu, 12 July 2007 11:30   |
It is probably this:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg02748.html
This is solved in cvs.
See the first post in this thread (see hyperlink) for a workaround.
gr. martin
> Guillaume
>> Hi again,
>> Teneo.
>> the "instanceClassName" attributes of the "eClassifiers" elements have
>> been deleted...
>> Guillaume
>> nsPrefix="ptyp">
>> </ecore:EPackage>
>> nsPrefix="deb">
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> </ecore:EPackage>
>> </xmi:XMI>
>> package test;
>> // work folder
>> // work resourceSet private static ResourceSet resTeneo;
>> // the datastore
>> hbds.initialize();
>> eventListener });
>> try {
>> Resource res =
>> res.load(null);
>> Resource resout =
>> resout.load(null);
>> Resource result =
>> result.save(null);
> </ecore:EPackage>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] another problems: my datas are modified by Teneo [message #89863 is a reply to message #89444] |
Mon, 16 July 2007 08:12   |
I have updated my Teneo plugin this morning with the new version 0.8 and
I have a new problem, my package are modified again.
If I serialize them to ecore files, I see that they differs from the
originals.
The eSuperType attribute from my eClassifiers elements are replaced by
an <eGenericSuperTypes eClassifier="eClassifier="#/1/mysupertype"/> element.
What can I do to solve this ?
Thanks.
doux guillaume.
> Yes, it was this, and now I have find a solution with your link.
> Thanks a lot !
> Guillaume
>> gr. martin
>>> Guillaume
>>>> Hi again,
>>>> Teneo.
>>>> have been deleted...
>>>> Guillaume
Re: [Teneo] another problems: my datas are modified by Teneo [message #89877 is a reply to message #89863] |
Mon, 16 July 2007 09:36   |
Ed,
Is this maybe the difference between a pre-emf 2.3 ecore and a 2.3 ecore (with generic types)?
gr. Martin
> originals.
> element.
> Thanks.
> doux guillaume.
>> Thanks a lot !
>> Guillaume
>>> gr. martin
>>>> Guillaume
>>>>> Hi again,
>>>>> Teneo.
>>>>> and the "instanceClassName" attributes of the "eClassifiers"
>>>>> elements have been deleted...
>>>>> Guillaume
The Netherlands
Re: [Teneo] another problems: my datas are modified by Teneo [message #89894 is a reply to message #89877] |
Mon, 16 July 2007 09:58   |
--------------010005040109000002070109
Martin,
If things are working properly, then as long as you don't do anything
specific that requires generics, the eSuperTypes reference would be
serialized the old way. More specifically, you'll only get
eGenericSuperTypes if the following returns true:
public boolean isSet()
for (EGenericType eGenericType : this)
if (eGenericType.getETypeParameter() != null ||
!eGenericType.getETypeArguments().isEmpty())
return true;
return false;
A super type being based on a type parameter is actually a constraint
violation, but the case that one of the super types has a type argument
is valid and in that case, we must serialize the generic types because
we'd lose the information about the type arguments if we serialized them
as just eSuperTypes.
The logic for whether to serialize instanceClassName verses
instanceTypeName is similarly gated by the use of type arguments in the
string (and of course ETypedElement.eType verses eGenericType is
similarly affected while EOperation.eExceptions verses
eGenericExceptions work just like EClass.eSuperTypes verses
eGenericSuperTypes).
Martin Taal wrote:
> Ed,
> gr. Martin
>> and I have a new problem, my package are modified again.
>> originals.
>> by an <eGenericSuperTypes
>> Thanks.
>> doux guillaume.
>>> Hi,
>>> Thanks a lot !
>>> Guillaume
>>>> gr. martin
>>>>> Guillaume
>>>>>> Hi again,
>>>>>> with Teneo.
>>>>>> this package has been modified.
>>>>>> Guillaume
<html>
<head>
</head>
Martin,<br>
<br>
eGenericSuperTypes if the following returns true:<br>
<br>
<small> public boolean isSet()<br>
{<br>
for (EGenericType eGenericType : this)<br>
{<br>
!eGenericType.getETypeArguments().isEmpty())<br>
{<br>
return true;<br>
}<br>
}<br>
return false;<br>
}</small><br>
<br>
them as just eSuperTypes.<br>
<br>
eGenericSuperTypes).<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mid:f7fs99$b1m$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
originals.
<br>
<br>
<br>
<br>
<br>
Thanks.
<br>
<br>
doux guillaume.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks a lot !
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
Martin Taal wrote:
<br>
<blockquote type="cite">It is probably this:
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg02748.html"> http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg02748.html</a>
<br>
<br>
<br>
<br>
<br>
<br>
gr. martin
<br>
<br>
<br>
<blockquote type="cite">Sorry I have post a bad output file...
<br>
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi again,
<br>
<br>
Teneo.
<br>
<br>
<br>
<br>
been deleted...
<br>
<br>
<br>
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------010005040109000002070109--
Re: [Teneo] another problems: my datas are modified by Teneo [message #89922 is a reply to message #89894] |
Mon, 16 July 2007 16:49   |
Guillaume,
I must say that (even after the description of Ed) I am in the dark why it happens and if it is even
a problem. Can you make a (small) testcase which illustrates the issue?
gr. Martin
Ed Merks wrote:
> Martin,
> return true;
> return false;
> Martin Taal wrote:
>> Ed,
>> gr. Martin
>>> Hi,
>>> originals.
>>> Thanks.
>>> doux guillaume.
>>>> Hi,
>>>> Thanks a lot !
>>>> Guillaume
>>>>> gr. martin
>>>>>> Guillaume
>>>>>>> Hi again,
>>>>>>> with Teneo.
>>>>>>> Guillaume
The Netherlands
Re: [Teneo] another problems: my datas are modified by Teneo [message #89937 is a reply to message #89922] |
Tue, 17 July 2007 03:28   |
--------------030401010605000908040700
My problem is that I must use meta-model persisted with Teneo to load
model conforming to the previous meta-model.
In the code that I joined to this mail I persist a model with Teneo,
retrieve it and then try to deserialized a model with it.
This code throw me an Exception when the XML parser try to find "val"
which is the first inherited attribute of my model.
I join the java program, the meta-model and the model.
guillaume doux
Martin Taal wrote:
> Guillaume,
> it happens and if it is even a problem. Can you make a (small) testcase
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> return true;
>> return false;
>> argument is valid and in that case, we must serialize the generic
>> types because we'd lose the information about the type arguments if we
>> serialized them as just eSuperTypes.
>> the string (and of course ETypedElement.eType verses eGenericType is
>> Martin Taal wrote:
>>> Ed,
>>> gr. Martin
>>>> Hi,
>>>> originals.
>>>> Thanks.
>>>> doux guillaume.
>>>>> Hi,
>>>>> Thanks a lot !
>>>>> Guillaume
>>>>>> gr. martin
>>>>>>> Guillaume
>>>>>>>> Hi again,
>>>>>>>> with Teneo.
>>>>>>>> Guillaume
name="deb.ecore"
</ecore:EPackage>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
name="deb_res_thunderbird.ecore"
filename="deb_res_thunderbird.ecore"
<deb:Deb xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:deb="my.model.of.debian.package" name="thunderbird.deb">
<metadata>
<blocs>
<field xsi:type="deb:Script_descriptions" val="Nom du trigger" type="Script_descriptions"/>
<field xsi:type="deb:package_descriptions" val="Descriptionnompaquet" type="package_descriptions"/>
<field xsi:type="deb:Version" val="0.10.1 0.1.0.rh7.test" type="version"/>
<field xsi:type="deb:Dependancy" val="dependance" type="Dependancy"/>
<field xsi:type="deb:package_name" val="thunderbird" type="name"/>
</blocs>
</metadata>
<control>
<scripts script_name="Nom du trigger" code="un script du paquet"/>
</control>
<data name="data.tar.gz">
<fil filename="libgtkembedmoz.so" location="/usr/lib/thunderbird"/>
<fil filename="bloaturls.txt" location="/usr/lib/thunderbird"/>
<fil filename="libgtkxtbin.so" location="/usr/lib/thunderbird"/>
<fil filename="libplds4.so" location="/usr/lib/thunderbird"/>
<fil filename="libbjsj.so" location="/usr/lib/thunderbird"/>
<fil filename="thunderbird-config" location="/usr/lib/thunderbird"/>
<fil filename="libplc4.so" location="/usr/lib/thunderbird"/>
<fil filename="thunderbird-bin" location="/usr/lib/thunderbird"/>
<fil filename="thunderbird-rebuild-database" location="/usr/lib/thunderbird"/>
<fil filename="thunderbird" location="/usr/lib/thunderbird"/>
<fil filename="libnss3.so" location="/usr/lib/thunderbird"/>
<fil filename="elf-dynstr-gc" location="/usr/lib/thunderbird"/>
<fil filename="libnspr4.so" location="/usr/lib/thunderbird"/>
<fil filename="ligkgfx.so" location="/usr/lib/thunderbird"/>
<fil filename="ligtksuperwin.so" location="/usr/lib/thunderbird"/>
<fil filename="libmozjs.so" location="/usr/lib/thunderbird"/>
</data>
</deb:Deb>
name="addget.java"
package test;
// work folder
// work resourceSet
private static String usr = "root";
private static String pass = "root"
// the datastore
props.setProperty(Environment.USER, usr);
props.setProperty(Environment.PASS, pass);
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, InheritanceType.SINGLE_TABLE.getLiteral());
hbds.initialize();
try {
res.load(null);
resout.load(null);
// //Serialization of this resource into an ecore file to see the difference
// String uri_res = loc+"resulting_deb.ecore";
// Resource result = resourceSet.createResource(URI.createFileURI(uri_res));
// result.getContents().addAll(resout.getContents());
// result.save(null);
// Then I will try to deserialize a model conforms to the model previously retrived
// registering meta model packages
for(int i = 0; i<resout.getContents().size(); ++i){
resTeneo.getPackageRegistry().put(((EPackage)(resout.getCont ents().get(i))).getNsURI(),
((EPackage)(resout.getContents().get(i))));
String uristr3 = loc+"deb_res_thunderbird.ecore";
Resource M = resTeneo.createResource(URI.createFileURI(uristr3));
M.load(null);
--------------030401010605000908040700--
Re: [Teneo] another problems: my datas are modified by Teneo [message #608724 is a reply to message #89396] |
Guillaume
> Hi again,
> deleted...
> Guillaume
> </ecore:EPackage>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
> package test;
> // work folder
> // work resourceSet
> // the datastore
> hbds.initialize();
> try {
> res.load(null);
> resout.load(null);
> result.save(null);
</ecore:EPackage>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
Re: [Teneo] another problems: my datas are modified by Teneo [message #608725 is a reply to message #89412] |
gr. martin
> Guillaume
>> Hi again,
>> Teneo.
>> been deleted...
>> Guillaume
>> nsPrefix="ptyp">
>> </ecore:EPackage>
>> nsPrefix="deb">
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> ordered="false"
>> ordered="false"
>> ordered="false"
>> </eClassifiers>
>> </ecore:EPackage>
>> </xmi:XMI>
>> package test;
>> // work folder
>> // the datastore
>> hbds.initialize();
>> eventListener });
>> try {
>> Resource res =
>> res.load(null);
>> Resource resout =
>> resout.load(null);
>> Resource result =
>> result.save(null);
> </ecore:EPackage>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
The Netherlands
Re: [Teneo] another problems: my datas are modified by Teneo [message #608726 is a reply to message #89429] |
Thu, 12 July 2007 11:44  |
Thanks a lot !
Guillaume
> gr. martin
>> Guillaume
>>> Hi again,
>>> Teneo.
>>> Guillaume
Re: [Teneo] another problems: my datas are modified by Teneo [message #608752 is a reply to message #89444] |
originals.
Thanks.
doux guillaume.
> Thanks a lot !
> Guillaume
>> gr. martin
>>> Guillaume
>>>> Hi again,
>>>> Teneo.
>>>> Guillaume
Re: [Teneo] another problems: my datas are modified by Teneo [message #608753 is a reply to message #89863] |
Ed,
gr. Martin
> originals.
> element.
> Thanks.
> doux guillaume.
>> Thanks a lot !
>> Guillaume
>>> gr. martin
>>>> Guillaume
>>>>> Hi again,
>>>>> Teneo.
>>>>> Guillaume
The Netherlands
Re: [Teneo] another problems: my datas are modified by Teneo [message #608754 is a reply to message #89877] |
Martin,
return true;
return false;
Martin Taal wrote:
> Ed,
> gr. Martin
>> originals.
>> Thanks.
>> doux guillaume.
>>> Hi,
>>> Thanks a lot !
>>> Guillaume
>>>> gr. martin
>>>>> Guillaume
>>>>>> Hi again,
>>>>>> with Teneo.
>>>>>> Guillaume
<html>
<head>
</head>
Martin,<br>
<br>
<br>
{<br>
{<br>
{<br>
return true;<br>
}<br>
}<br>
return false;<br>
}</small><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<br>
<br>
<br>
originals.
<br>
<br>
<br>
<br>
<br>
Thanks.
<br>
<br>
doux guillaume.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks a lot !
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
Martin Taal wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. martin
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
<br>
<br>
<br>
Teneo.
<br>
<br>
<br>
<br>
been deleted...
<br>
<br>
<br>
<br>
<br>
<br>
Guillaume
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: [Teneo] another problems: my datas are modified by Teneo [message #608756 is a reply to message #89894] |
Guillaume,
gr. Martin
Ed Merks wrote:
> Martin,
> return true;
> return false;
> Martin Taal wrote:
>> Ed,
>> gr. Martin
>>> Hi,
>>> originals.
>>> Thanks.
>>> doux guillaume.
>>>> Hi,
>>>> Thanks a lot !
>>>> Guillaume
>>>>> gr. martin
>>>>>> Guillaume
>>>>>>> Hi again,
>>>>>>> with Teneo.
>>>>>>> Guillaume
The Netherlands
Re: [Teneo] another problems: my datas are modified by Teneo [message #608757 is a reply to message #89922] |
guillaume doux
Martin Taal wrote:
> Guillaume,
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> return true;
>> return false;
>> Martin Taal wrote:
>>> Ed,
>>> gr. Martin
>>>> Hi,
>>>> originals.
>>>> Thanks.
>>>> doux guillaume.
>>>>> Hi,
>>>>> Thanks a lot !
>>>>> Guillaume
>>>>>> gr. martin
>>>>>>> Guillaume
>>>>>>>> Hi again,
>>>>>>>> with Teneo.
>>>>>>>> Guillaume
name="deb.ecore"
</ecore:EPackage>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
<metadata>
<blocs>
</blocs>
</metadata>
<control>
</control>
</data>
</deb:Deb>
name="addget.java"
package test;
// work folder
// work resourceSet
// the datastore
hbds.initialize();
try {
res.load(null);
resout.load(null);
M.load(null);
Current Time: Mon Jul 21 21:46:48 EDT 2025
Powered by FUDForum. Page generated in 0.27169 seconds
