Has anyone gotten images to work? [message #89359] |
Wed, 09 November 2005 14:48  |
Originally posted by: mlorenz.nc.rr.com
I've tried embedded and URL. Both ways the image shows up, but both give
me an error also:
There are errors on the report page:
+ There are error(s) in Image:null
Error0 : Failed to evaluate CMBP.bmp(1 time)detail: Failed to evaluate
CMBP.bmpReferenceError: "CMBP" is not defined. (#1)
(my image is named CMBP.bmp)
Re: Has anyone gotten images to work? [message #89963 is a reply to message #89359] |
Thu, 10 November 2005 18:25  |
Mark,
You do'nt need to use the Master Page to put an image in your report.
Try this:
1. Drag an Image object to your reports layout.
2. In the Image Builder window, select the Embedded Image radio button.
3. Click on Add Image button
4. Select your image from four file system. It will be added to your list
of images.
5. Select the image you want to include, from the list of images.
6. Click on Insert button.
Now, This is a piece of advise: Try to do this with several types of
images (.png, .ico, .bmp, .jpeg, .git, etc)
Use only those types that display correctly on your layout, HTML previewer
and PDF previewer. Stck to those that have a good display!!
FUDForum. Page generated in 0.24797 seconds
