subversive will not install [message #8063] |
Sat, 14 July 2007 08:48  |
Originally posted by: hansm.science.uva.nlDELETE
Installed Eclipse 3.3
Downloaded Subversive_1.1.3-LocalUpdateSite.zip
Got following error message on installing in eclipse through the installer:
Subversive Integration for the CSC Project Set Project (Optional) (1.0.4)
requires feature "com.csc.dip.projectset.feature".
What is this? I cannot imagine the full eclipse 3.3 download (rcp version) is
incomplete. So is this subversive localupdatesite.zip incomplete? Why then?
I have worked with subversive before on older eclipse versions, but if it now
will not install I have no choice but to drop its usage.
Hans van der Meer
Re: subversive will not install [message #8316 is a reply to message #8284] |
Wed, 18 July 2007 08:19  |
Thanks Igor.
Just now I found out that the install has several subitems and then found the
one that must be disabled in order to remove the error message. Glad to here
noninstalling that option does not restrict svn usage. However, could you
consider some explaining comment about this in the install dialog? Perhaps
others like me do not suspect that deselecting a subfeature will make the evil
looking error message go away and, like me, might be intimidated by it.
As for the javaHL problem I encountered: downloading and installing svnkit as
eclipse plugin from its homesite and selecting it in the eclipse team-svn
preferences solved that.
Hans van der Meer
In article <f7kli7$8j4$1@build.eclipse.org>,
"Igor Vinnykov" <igor.vinnykov@polarion.org> wrote:
> Dear Hans,
> Like I mentioned in the post - Subversive Project Set integration is an
> optional feature, which should be installed only if you use CSC Project Set
> plugin and want to have it integrated with Subversive. I all other cases you
> don't need to install this instagretion. It doesn't have influence to the
> Subversive functionality.
> Best regards,
> Igor Vinnykov
> "dr. Hans van der Meer" <hansm@science.uva.nlDELETE>
FUDForum. Page generated in 0.03340 seconds
