Hanging on exit, not saving workspace [message #89316] |
Fri, 09 January 2009 18:35  |
Since upgrading to PDT 2, (while loving the many new features) I've often
had a problem when trying to shutdown eclipse - it will pretend to exit,
but a "eclipse.exe" program will remain lingering in the task manager. I
can kill this, and then restart eclipse, but it won't have my workspace
settings from the previous session saved.
It doesn't happen every time, but it seems if I work long enough, it will
consistently happen when I go to exit.
Anyone know how to fix this issue?
Paul
Here is the last stacktrace from the error log when I went to exit:
!ENTRY org.eclipse.ui.workbench 4 0 2009-01-09 18:21:54.187
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.php.internal.ui.outline.PHPOutlineContentProvide r$ElementChangedListener$1.run(PHPOutlineContentProvider.jav a:187)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:382)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. disconnectFromWorkspace(IDEWorkbenchAdvisor.java:398)
org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. postShutdown(IDEWorkbenchAdvisor.java:315)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:27 08)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 21)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 38)
at org.eclipse.ui.internal.Workbench$23.run(Workbench.java:1082 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1080)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1052)
org.eclipse.ui.internal.handlers.QuitHandler.execute(QuitHan dler.java:41)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
FUDForum. Page generated in 0.11597 seconds
