deploying/running RAP: get NoClassDefFoundError: org/xml/sax/SAXException [message #89302] |
Wed, 21 May 2008 23:07  |
Hello! I followed Elias' excellent instructions on deploying a standalone
RAP application (with Jetty) here:
http://rapblog.innoopract.com/2007/11/rap-deployment-part-1- deploying-your.html
It works great for Windows. The trouble is, how to deploy & run on Linux
or Mac? Inside cygwin, I run this on the command line
java -jar org.eclipse.osgi_3.3.2.R33x_v20080105.jar -configuration
config-linux -consoleLog -debug -clean -dev -console
and I get the below error. I find this error to be a common problem
plaguing deployment of Eclipse ECP and RAP applications.
David
!ENTRY org.eclipse.rwt.widgets.upload 4 0 2008-05-21 22:57:36.685
!MESSAGE Could not register themeable widget
'org.eclipse.rwt.widgets.Upload'.
!STACK 0
java.lang.NoClassDefFoundError: org/xml/sax/SAXException
org.eclipse.ui.internal.servlet.EngineConfigWrapper.register Themeable
Widgets(EngineConfigWrapper.java:261)
org.eclipse.ui.internal.servlet.EngineConfigWrapper.<init>(EngineConf
igWrapper.java:83)
org.eclipse.ui.internal.servlet.RequestHandler.init(RequestH andler.ja
va:40)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.init(Se
rvletRegistration.java:64)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.regis terServle
t(ProxyServlet.java:142)
org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.re gisterSer
vlet(HttpServiceImpl.java:50)
org.eclipse.ui.internal.servlet.HttpServiceTracker.addingSer vice(Http
ServiceTracker.java:41)
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTrack
er.java:1064)
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.jav
a:1042)
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTr
acker.java:967)
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serv
iceChanged(FilteredServiceListener.java:94)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEv
ent(BundleContextImpl.java:1224)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventM
anager.java:195)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchr
onous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEven
tPrivileged(Framework.java:1603)
t(Framework.java:1578)
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl. <ini
t>(ServiceRegistrationImpl.java:103)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServ
iceRegistration(BundleContextImpl.java:657)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterSe
rvice(BundleContextImpl.java:609)
rvice(BundleContextImpl.java:675)
org.eclipse.equinox.http.servlet.internal.Activator.register HttpServi
ce(Activator.java:78)
org.eclipse.equinox.http.servlet.internal.Activator.addProxy Servlet(A
ctivator.java:57)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.init( ProxyServ
let.java:39)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHtt
pServiceServlet.init(HttpServerManager.java:247)
org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletH older.jav
a:383)
org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder. java:243)
org.mortbay.jetty.servlet.ServletHandler.initializeServlets( ServletHa
ndler.java:446)
org.mortbay.jetty.servlet.ServletHandler.doStart(ServletHand ler.java:
415)
at org.mortbay.util.Container.start(Container.java:72)
org.mortbay.http.HttpContext.startHandlers(HttpContext.java: 1704)
at org.mortbay.http.HttpContext.doStart(HttpContext.java:1675)
at org.mortbay.http.HttpServer.doStart(HttpServer.java:708)
org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated(Htt
pServerManager.java:94)
org.eclipse.equinox.http.jetty.internal.Activator.start(Acti vator.jav
a:53)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(Bund
leContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActiv
ator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(Bund
leContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(Bundl
eHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(Abstra
ctBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Frame
work.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBund
les(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(St
artLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStart
Level(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEv
ent(StartLevelManager.java:468)
anager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(Even
tManager.java:297)
ERROR: Could not register themeable widget
'org.eclipse.rwt.widgets.Upload'. Rea
son: org/xml/sax/SAXException
!ENTRY org.eclipse.osgi 4 0 2008-05-21 22:57:36.776
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
org.eclipse.ui.internal.servlet.EngineConfigWrapper.register Themes(En
gineConfigWrapper.java:288)
igWrapper.java:84)
va:40)
er.java:1064)
a:1042)
acker.java:967)
anager.java:195)
ctivator.java:57)
let.java:39)
a:383)
ndler.java:446)
415)
a:53)
eHost.java:346)
ctBundle.java:350)
work.java:1118)
anager.java:195)
tManager.java:297)
Re: deploying/running RAP: get NoClassDefFoundError: org/xml/sax/SAXException [message #89452 is a reply to message #89302] |
Thu, 22 May 2008 17:46  |
I had to do this to get RAP (standalone with Jetty) to run in cygwin. I
hope & assume this means it will run on Linux (and Mac?)
(1) I copied bundle org.eclipse.osgi_3.3.2.R33x_v20080105.jar to my root
(2) To the root directory, I added a Linux-specific config folder, which I
call config-linux. I added a config.ini file inside this folder, with
this text:
osgi.bundles=plugins/org.eclipse.equinox.common@2:start,plugins/org.eclipse.update.configurator@3:start,plugins/org.eclipse.rap.ui@4:start,plugins/org.eclipse.equinox.http.jetty@4:start
# do not run an eclipse application
eclipse.ignoreApp=true
# don't shutdown osgi after exiting (or not running) the application
osgi.noShutdown=true
# incoming port for the server
org.osgi.service.http.port=7070
(3) In the root folder, I created run.sh, with this text:
java -Dorg.osgi.framework.bootdelegation=* -jar
org.eclipse.osgi_3.3.2.R33x_v20080105.jar -configuration config-linux
(4) So to run the app on cygwin or Linux, you go to the root folder and
type
sh run.sh
and this runs the application without any SAXException errors
David Donohue
FUDForum. Page generated in 0.02784 seconds
