unable to load class ProfileJUnitShortcut [message #89277] |
Sun, 03 December 2006 21:20  |
I recently upgraded to Windows Vista, and since Eclipse 3.2.1 isn't
compatible with Vista I had to install 3.3M3 (the latest stable beta
milestone release). Now I would like to be able to use TPTP, but when I
try to run the menu command "Profile As, JUnit Test" I get this error
dialog box.
Error
Unable to use launch shortcut
Reason:
Plug-in org.eclipse.hyades.trace.ui was unable to load class
org.eclipse.hyades.trace.ui.internal.launcher.ProfileJUnitSh ortcut
The Eclipse error log shows some more detail.
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
Exception Stack Trace:
java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/junit/launcher/JUnitMainTab
org.eclipse.hyades.trace.ui.internal.launcher.ProfileJUnitTa bGroup.createTabs(ProfileJUnitTabGroup.java:31)
So, can anyone suggest where to obtain that JUnitMainTab class? When I
installed TPTP I did everything through Update Manager, so if there really
is a missing class then I suspect that TPTP may have a dependency that
isn't properly listed.
FUDForum. Page generated in 0.02748 seconds
