Home » Archived » Test and Performance Tools Platform (TPTP) » unable to load class ProfileJUnitShortcut
unable to load class ProfileJUnitShortcut [message #89277] Sun, 03 December 2006 21:20 Go to next message
I recently upgraded to Windows Vista, and since Eclipse 3.2.1 isn't
compatible with Vista I had to install 3.3M3 (the latest stable beta
milestone release). Now I would like to be able to use TPTP, but when I
try to run the menu command "Profile As, JUnit Test" I get this error
dialog box.
Error
Unable to use launch shortcut
Reason:
Plug-in org.eclipse.hyades.trace.ui was unable to load class
org.eclipse.hyades.trace.ui.internal.launcher.ProfileJUnitSh ortcut
The Eclipse error log shows some more detail.
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
Exception Stack Trace:
java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/junit/launcher/JUnitMainTab
org.eclipse.hyades.trace.ui.internal.launcher.ProfileJUnitTa bGroup.createTabs(ProfileJUnitTabGroup.java:31)
So, can anyone suggest where to obtain that JUnitMainTab class? When I
installed TPTP I did everything through Update Manager, so if there really
is a missing class then I suspect that TPTP may have a dependency that
isn't properly listed.
Re: unable to load class ProfileJUnitShortcut [message #89388 is a reply to message #89277] Mon, 04 December 2006 14:34 Go to previous messageGo to next message
TPTP is not yet compatible with Eclipse 3.3. The latest development release
(4.3.0), which will soon GA runs on Eclipse 3.2.1.
"Nick Radov" <nradov@axolotl.com> wrote in message
news:8fb4910f2606adce90aead18dad16e23$1@www.eclipse.org...
>milestone release). Now I would like to be able to use TPTP, but when I try
>to run the menu command "Profile As, JUnit Test" I get this error dialog
>box.
> Error
> Reason:
> at
Re: unable to load class ProfileJUnitShortcut [message #89403 is a reply to message #89388] Mon, 04 December 2006 23:45 Go to previous message
Yes, I understand that it isn't officially released or supported yet. I
was just wondering if someone has a suggestion on how to make it work
anyway.
Previous Topic:ccessing AGR *.execution data inside and outside of eclipse
Next Topic:Sequence diagram as html
Current Time: Thu Nov 20 19:41:10 EST 2025
Powered by FUDForum. Page generated in 0.04002 seconds
