Home » Archived » Test and Performance Tools Platform (TPTP) » ccessing AGR *.execution data inside and outside of eclipse
ccessing AGR *.execution data inside and outside of eclipse [message #89257] Fri, 01 December 2006 15:35 Go to next message
I've noticed that running an AGR generated testcase creates a test log in
a corresponding timestamped *.execution object.
Opening a *.execution object shows "some" of the information contained in
this test log. Some searching around leads me to believe that this
*.execution object is a TPFExecutionResult, which seems to contain
significantly more information than is displayed in the "Test Log" editor.
Has anybody devised a utility that can view the entire contents of a
execution object from either inside or outside of the eclipse environment?
Thanks in advance for any insights?
Jim
Re: ccessing AGR *.execution data inside and outside of eclipse [message #89373 is a reply to message #89257] Mon, 04 December 2006 14:32 Go to previous message
TPTP provides the ability for contributors to add custom reports. I suppose
you can expose the content by generating a contributed report.
"Jim Hayko" <jim_hayko@ca.ibm.com> wrote in message
news:10a015d382f6978fb0d288b644ed6e03$1@www.eclipse.org...
> Jim
Previous Topic:HTTP Test: error converting .rec file in .testsuite file
Next Topic:unable to load class ProfileJUnitShortcut
Current Time: Thu Jul 17 19:37:03 EDT 2025
Powered by FUDForum. Page generated in 0.26704 seconds
