Home » Language IDEs » C / C++ IDE (CDT) » Cannot save a file after merge using C Compare
Cannot save a file after merge using C Compare [message #89174] Fri, 12 December 2003 21:47 Go to next message
Originally posted by: agrewal.inkra.com
I am using C Compare to merge some specific changes to an old version of=
a =
file.
After I am done with the selection of changes to merge I am not able to =
find the
option to save the merged file.
Closing the compare windows prompts for saving the changes but accepting=
that does
not write anything to the original file.
Is compare supposed to make changes to the same file that I selected or =
is =
it going to
create a third file output file.
-Avi
Re: Cannot save a file after merge using C Compare [message #89543 is a reply to message #89174] Mon, 15 December 2003 11:41 Go to previous message
Originally posted by: alain.nowhere.ca
Avi wrote:
> I am using C Compare to merge some specific changes to an old version of a
> file.
> find the
> that does
> Is compare supposed to make changes to the same file that I selected or is
> it going to
It should change/save the same file. Hit CTRL-S or File -> Save all
If there is an error, create a PR and append the .log file
so We can trace this.
Previous Topic:build problem
Next Topic:Needing some assistance w/plugin on Linux
Current Time: Mon Jul 14 19:15:56 EDT 2025
Powered by FUDForum. Page generated in 0.04339 seconds
