Shell titlebar minimize button [message #88836] |
Tue, 20 May 2008 09:49  |
I have problem with minimize button in shell's title bar.
Scenario for snippet:
1. click at button "Open". Shell is correctly open and show to user.
2. click at SWT.MIN button in top right corner (titlebar) in opened
shell. Shell correctly disappear.
3. click at button "Show". Nothing happens. BUG. I analyze why shell do
not show at this moment and I think that shell have bad setting
attributes (minimize, visible and maybe others) because it was not set
in scenario step 2.
addition:
4. click at button "Hide". Nothing happens. Correct. This step I make
only for correct minimize attribute on shell.
5. click at button "Show". Shell is visible.
Snippet:
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.part.ViewPart;
public class TestView extends ViewPart{
public void createPartControl(Composite parent) {
final Shell shell = new
Shell(Display.getCurrent().getActiveShell(), SWT.SHELL_TRIM);
shell.setBounds(50, 50, 200, 200);
Button btnOpen = new Button(parent, SWT.PUSH);
btnOpen.setText("Open");
btnOpen.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent e) {
shell.open();
Button btnHide = new Button(parent, SWT.PUSH);
btnHide.setText("Hide");
btnHide.addSelectionListener(new SelectionAdapter(){
shell.setMinimized(true);
Button btnShow = new Button(parent, SWT.PUSH);
btnShow.setText("Show");
btnShow.addSelectionListener(new SelectionAdapter(){
shell.setMinimized(false);
public void setFocus() {
//nothing
Re: Shell titlebar minimize button [message #88917 is a reply to message #88836] |
Tue, 20 May 2008 14:55   |
Originally posted by: rherrmann.innoopract.com
thanks for pointing this out, which version of RAP did you use?
Rüdiger
> in scenario step 2.
> addition:
> Snippet:
> import org.eclipse.swt.widgets.Display;
> @Override
> shell.open();
> @Override
> //nothing
FUDForum. Page generated in 0.04585 seconds
