Home » Eclipse Projects » Remote Application Platform (RAP) » Prevent user from closing view
Prevent user from closing view [message #88821] Tue, 20 May 2008 08:28 Go to next message
Is there any way for preventing a user to close a view?
Tiago
Re: Prevent user from closing view [message #88902 is a reply to message #88821] Tue, 20 May 2008 14:48 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Tiago,
apart from writing your own presentation, the only way I know of is
to use a standalone view.
For details please search for 'eclipse standalone view' or consult
that JavaDoc of org.eclipse.ui.IPageLayout#addStandaloneView.
Rüdiger
Tiago wrote:
> Thanks
> Tiago
Re: Prevent user from closing view [message #89363 is a reply to message #88902] Thu, 22 May 2008 06:03 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
You can prevent views from being closable programmatically in your
Perspective implementation. This is an example code snippet:
private void makeNotCloseable( final IPageLayout layout,
final String[] viewIds ) {
for( int i = 0; i < viewIds.length; i++ ) {
layout.getViewLayout( viewIds[ i ] ).setCloseable( false );
Jochen
Rüdiger Herrmann wrote:
> Tiago,
> apart from writing your own presentation, the only way I know of is to
> For details please search for 'eclipse standalone view' or consult that
> Cheers,
> Rüdiger
> Tiago wrote:
>> Thanks
>> Tiago
Re: Prevent user from closing view [message #89422 is a reply to message #88821] Thu, 22 May 2008 10:48 Go to previous message
If you use org.eclipse.ui.perspectiveExtensions / perspectiveExtension to define your perspective, you can define your
views there, and set if they are closeable or not.
<perspectiveExtension
targetID=" com.example.ui.eclipse.perspectives.FranqusDefaultPerspectiv e ">
<view
closeable="false"
id="com.example.ui.eclipse.ve.views.NomenclatureView"
ratio="0.30"
relationship="left"
relative="org.eclipse.ui.editorss"
showTitle="true"
visible="true">
</view>
</perspetiveExtension>
Patrick
Tiago wrote:
> Thanks
> Tiago
Previous Topic:custom widgets - google maps
Next Topic:Shell titlebar minimize button
Current Time: Tue Jul 22 02:35:44 EDT 2025
Powered by FUDForum. Page generated in 0.07485 seconds
