HTML Reports as a result of profiling JUnit tests Headless [message #88745] |
Mon, 27 November 2006 04:56  |
Hi All,
I like to profile JUnit tests in headless way using TPTP, which is said to
produce 'tarce.trcxml' file as a result of tests. My question is that is it
also possible to generate the HTML reports for 'trace.trcxml' in headless
way too ? Is such feature supported in TPTP ?
I would appreciate any help provided in this direction!
Ravi.
Re: HTML Reports as a result of profiling JUnit tests Headless [message #96442 is a reply to message #89013] |
Thu, 19 April 2007 06:36  |
Hi Ravi,
TPTP does not provide an API to create HTML reports from Trace file.
However, you can import the Trace file (File >> Import... >> Profiling and
Logging >> Profiling File) and generate HTML reports from the TPTP
workbench.
Paul
"Ravi Roy" <ravi.aroy@gmail.com> wrote in message
news:ekjnvv$ad5$1@utils.eclipse.org...
> Could somebody give a pointer on converting 'trace.trcxml' to HTML Reports
> using headless way please ?
> Thanks.
> Ravi.
> news:ekecoh$vhb$1@utils.eclipse.org...
>> Hi All,
>> to produce 'tarce.trcxml' file as a result of tests. My question is that
>> is it also possible to generate the HTML reports for 'trace.trcxml' in
>> headless way too ? Is such feature supported in TPTP ?
>> Thanks,
>> Ravi.
FUDForum. Page generated in 0.03163 seconds
