Home » Eclipse Projects » Equinox » Possible to deduce plugin from object instance
Possible to deduce plugin from object instance [message #88711] Sat, 26 May 2007 22:01 Go to next message
Originally posted by: expires07.logular.com
Is it possible to deduce the Eclipse plugin that is associated with an
object instance? If so, how?
Background: I'd like to enhance my tracing routine (shown below) to avoid
passage of the plugin parameter. A new implementation would determine
the correct plugin ID internally.
Thanks for any tips,
Jason.
* Return true if the passed object (or an ancestor) is currently being
traced.
public static boolean isTracing(Plugin plugin, Object tracer) {
if (plugin == null || plugin.getBundle() == null || !
plugin.isDebugging()) {
return false;
String className = getClassName(tracer);
Boolean enabled = (Boolean)classNameFlagMap.get(className);
if (enabled == null) {
String pluginId = plugin.getBundle().getSymbolicName()
String name = className;
while (name.length() > 0) {
String option = Platform.getDebugOption(pluginId
+name);
// ascend the outer class and package hierarchy
to see if one of these
// "parents" is enabled.
if (option == null) {
int index = name.lastIndexOf('.');
if (index > 0) {
name = name.substring(0, index);
else {
break;
else {
enabled = Boolean.valueOf(option);
break;
System.err.println("Tracing is not configured for
"+className+"\n" +
"The project's .options file needs an entry
like: \n "+
pluginId + className + " = false");
enabled = Boolean.FALSE;
classNameFlagMap.put(className, enabled);
return enabled.booleanValue();
Re: Possible to deduce plugin from object instance [message #88727 is a reply to message #88711] Sun, 27 May 2007 07:33 Go to previous messageGo to next message
Jason,
One way would be to keep a map of all the bundle classloaders and their
symbolic names. When your bundle is started you can find all the loaded
bundles via the BundleContext.getBundles() method. You would have to
also listen for bundle events to be notified when bundles are added and
removed. The symbolic name of the bundle is the plugin id. You could
then use :
obj.getClass().getClassLoader();
to obtain the classloader for the object being logged. Finding the
plugin id would then be a lookup on the classloader against the map.
Richard
> Jason.
> traced.
> return false;
> +name);
> if (index > 0) {
> else {
> break;
> else {
> break;
> "+className+"\n" +
> like: \n "+
Re: Possible to deduce plugin from object instance [message #88741 is a reply to message #88711] Sun, 27 May 2007 13:36 Go to previous message
Take a look at the PackageAdmin service.
I think what you're looking for is the getBundle method.
http://www2.osgi.org/javadoc/r4/org/osgi/service/packageadmi n/PackageAdmin.html#getBundle
HTH
-Simon
"Jason Grant" <expires07@logular.com> wrote in message
news:f3aoqc$qfn$1@build.eclipse.org...
> Jason.
> traced.
> return false;
> +name);
> if (index > 0) {
> else {
> break;
> else {
> break;
> "+className+"\n" +
> like: \n "+
Previous Topic:ProxyServlet finds registered servlet for invalid url!?
Next Topic:Bundle Activator packaged in embedded jar
Current Time: Wed Jul 16 07:56:10 EDT 2025
Powered by FUDForum. Page generated in 0.05417 seconds
