Text element expressions [message #88710] |
Tue, 08 November 2005 09:31  |
Originally posted by: mlorenz.nc.rr.com
Hi all...I was reading the spec for the text element
(http://www.eclipse.org/birt/ref/ROM_Text_SPEC.pdf) and in section 5.1 it
says:
The value-of tag identifies a value to insert into the text for a Text
element. The value-of
tag contains the expression to evaluate to obtain the data. Value-of tags
cannot be
inserted into text returned from the value expression property (i.e., it
can not be used
with data and multi-line data items).
For example:
Dear <value-of>
if [Sex] = M then Mr.
else if [Sex] = F then Ms.
</value-of> <value-of>row.firstName</value-of>
<value-of>row.lastName</value-of >,
<p>
<b>Thank you</b> for your purchase of an exciting new
<value-of> row.productName</value-of > on
<value-of> row.purchaseDate</value-of>.
The above shows that the value-of tag can encapsulate either a simple
value/expression, or a script.
My question is: what does the bracketed expression mean (if [Sex] = M
then Mr.)? What object/value does this use? (I understand brackets to
get script object properties or array elements, but this doesn't look like
either of those.)
Re: Text element expressions [message #89902 is a reply to message #88710] |
Thu, 10 November 2005 14:34  |
This spec was written before the implementation was fully decided. You must
use a valid JavaScript expression. I was unable to get the if, then, else
syntax to perform, so I checked the JavaScript documentation for valid
expression formats. After doing that, I successfully used the following:
<VALUE-OF>(row["custID"] > 200) ? row["Issues"] : "Customer level does not
permit an issue" </VALUE-OF>
I am using the 2.0 stable build 20051110.
Jane Tatchell
BIRT documentation lead
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:42e7b7f6f90c7331848416ddcd6d12c8$1@www.eclipse.org...
> says:
> cannot be
> can not be used
> For example:
> Dear <value-of>
> if [Sex] =
FUDForum. Page generated in 0.79768 seconds
