Home » Newcomers » Newcomers » getting build path to create package directories
getting build path to create package directories [message #8019] |
Wed, 19 January 2005 08:12  |
Originally posted by: marc.esher.cablespeed.com
Greetings. New to eclipse and have what has to be a really easy problem to
solve.
I have a project whose file system structure is
[project]/src/AllFiles.java. So...all source files are listed in src, even
though they are different packages.
and then the build path is [project]/classes/
When we compile, we tell the compiler to build the output path based on
the packages, so that the output path might have
[project]/classes/com/blah/beans/
[project]/classes/com/blah/db/
[project]/classes/com/blah/andsoforth/
It's been this way for some time and has worked OK. Now, I want to give
eclipse a shot, but I'm having trouble getting it set up to compile the
files into the respective output paths based on package names. From what
I can tell, it looks like eclipse will only do that if my source folders
are set up by package names, and that's unlikely at this point.
So...is there a way to for me to keep my current source structure, but
still have eclipse build the files into package-specific directories?
Thanks.
Re: getting build path to create package directories [message #8429 is a reply to message #8144] |
Wed, 19 January 2005 17:46   |
Thanks for responding, Daniel. So...I've got to create a source directory
structure like so:
/src/com/blah/blah/db
/src/com/blah/blah/beans
and so forth, correct?
Daniel Megert wrote:
>> problem to solve.
>> even though they are different packages.
>> on the packages, so that the output path might have
>> give eclipse a shot, but I'm having trouble getting it set up to
>> compile the files into the respective output paths based on package
>> names. From what I can tell, it looks like eclipse will only do that
>> if my source folders are set up by package names, and that's unlikely
>> at this point.
> Eclipse supports packages that are stored according to JLS2 7.2.1. If
> you put all your files into one directory the built-in compiler will not
> work and with it most of the coding features.
> Dani
>> Thanks.
Re: getting build path to create package directories [message #8550 is a reply to message #8429] |
Thu, 20 January 2005 03:41   |
Originally posted by: daniel.megert.gmx.net
> directory structure like so:
Yes. For more info I suggest to read the JLS2 7.2.1 which explains it in
detail.
Dani
>>> problem to solve.
>>> src, even though they are different packages.
>>> that if my source folders are set up by package names, and that's
>>> but still have eclipse build the files into package-specific
>>> directories?
>> not work and with it most of the coding features.
>> Dani
>>> Thanks.
Re: getting build path to create package directories [message #9731 is a reply to message #8550] |
Thu, 20 January 2005 07:10   |
Thanks Daniel. That did the trick.
> detail.
> Dani
>>>> problem to solve.
>>>> directories?
>>> Dani
>>>> Thanks.
Re: getting build path to create package directories [message #112413 is a reply to message #9731] |
Wed, 26 October 2005 15:34  |
Originally posted by: mdos.verizon.net
Hello Dani (and all):
I've got a similar issue, but at the opposite end of the spectrum.
An existing project of significant size is broken down into eclipse
projects, and has the following directory structure:
basedir/
com.myco.myproject1/src/com/myco/mypackage1/*.java
/bin/com/myco/mypackage1/*.class
com.myco.myproject2/src/com/myco/mypackage2/*.java
/bin/com/myco/mypackage2/*.class
com.myco.myproject3/src/com/myco/mypackage3/*.java
/bin/com/myco/mypackage3/*.class
com.myco.myproject4/src/com/myco/mypackage4/*.java
/bin/com/myco/mypackage4/*.class
.. and so on
All the code gets packaged up into a single jar. I believe the team
is currently generating the jar from within eclipse by using the jar
tool and 'checking off' which projects they want included in the jar.
We're using project dependencies in eclipse to build everything. I
guess the original developers felt that this structure kept the
different parts of the project neatly isolated. It makes things much
harder when attempting to jar up a release with ant, though.
JLS3 7.2.1 states that: "As an extremely simple example, all packages
and source and binary code on a system *might* be stored in a single
directory and its subdirectories." This wording seems more like a
potential example, or perhaps a suggestion, than a requirement. Does
the compiler and jar tool expect this layout?
Should I recommend that the team put forth the effort of consolidating
all our projects under a single project directory like this:
basedir/
/mypackage2/*.java
/mypackage3/*.java
/mypackage4/*.java
/mypackage2/*.class
/mypackage2/*.class
/mypackage3/*.class
/mypackage4/*.class
It seems more 'standards conforming', but will be a bit of an effort
given the size of the project.
Is there some way to maintain the current directory layout and build the
jar with ant, or should I push for the layout change? Is it worth it?
Thanks.
-Marc
>> in detail.
>> Dani
>>>>> problem to solve.
>>>>> based on the packages, so that the output path might have
>>>>> directories?
>>>> If you put all your files into one directory the built-in compiler
>>>> will not work and with it most of the coding features.
>>>> Dani
>>>>> Thanks.
Current Time: Sat Jun 07 19:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.08430 seconds
