Home » Eclipse Projects » Equinox » ProxyServlet finds registered servlet for invalid url!?
ProxyServlet finds registered servlet for invalid url!? [message #88590] Tue, 22 May 2007 07:53 Go to next message
Hi Simon,
(me again :)), I registered a servlet to the HttpService with the alias,
say "foo". Now, when I write "http://localhost:8080/mycontext/foo", as
exptected, my servlet gets initialized correctly and all works fine.
But when I add a "/" or an invalid path at the end of the url, the request
should result in a HTTP 404 error (that's the way, tomcat handles such
invalid url's).
However, the ProxyServlet finds my registered servlet for the path-info
"foo/", since the processAlias()-method just looks for the mapped alias,
which it finds in the "/"-seperated path and then delegates the request to
my own servlet.
Is there any reason, why my own servlet should deal with such invalid
requests?
I solved this problem, by parsing the path-info in the
handleSecurity()-method of my own HttpContext and processing invalid paths
with a 404 error (dirty), - I think, that should be something for the
ProxyServlet!?
- teos
Re: ProxyServlet finds registered servlet for invalid url!? [message #88620 is a reply to message #88590] Tue, 22 May 2007 13:01 Go to previous messageGo to next message
Hi Teos,
Despite being "/" terminated the request is still a valid URL.
There are lots of cases where we really do want to handle requests that are
'/' terminated or otherwise want to interpret path_info.
The mapping rules for the OSGi HttpService are slightly different than those
used in web.xml and matching is done by longest prefix so "/foo" is in some
senses treated like " /foo/*". In your case where you don't want to treat
the request as valid you're doing the right thing as your servlet has to
handle it or potentially ignore it.
You've used a custom HttpContext in your case however if you're trying to
avoid adding aditional logic another approach you might consider is wrapping
your real Servlet in another that looks after the path_info parsing and
returns a 404 (or other code) for what your application does not want to
handle.
That said your approach valid and it's really up to you.
-Simon
"teos" <sasa.teofanovic@gmx.at> wrote in message
news:1471dbdd8023b2891ebbfde9ff9b1607$1@www.eclipse.org...
> Hi Simon,
> exptected, my servlet gets initialized correctly and all works fine. But
> invalid url's).
> my own servlet.
> requests?
> ProxyServlet!?
> - teos
Re: ProxyServlet finds registered servlet for invalid url!? [message #88635 is a reply to message #88620] Wed, 23 May 2007 05:41 Go to previous messageGo to next message
Hi Simon,
just for curiosity. Why does HttpService not work as web.xml where /foo
only does a strict matching and in cases where you also want
/foo/something* to match your servlet you would register the alias '/foo/*'?
regards
christian campo
Simon Kaegi schrieb:
> Hi Teos,
> handle.
> -Simon
>> Hi Simon,
>> invalid url's).
>> my own servlet.
>> requests?
>> ProxyServlet!?
>> - teos
Re: ProxyServlet finds registered servlet for invalid url!? [message #88681 is a reply to message #88635] Wed, 23 May 2007 10:32 Go to previous message
The HttpService was originally created in the Servlet 2.1 time frame which
predated standardization of web.xml's mapping semantics.
I invite you to take a look at the advanced mapping err... suggestions in
the Servlet 2.1 spec (page 14). :)
http://java.sun.com/products/servlet/2.1/servlet-2.1.pdf
-Simon
"Christian Campo" <christian.campo@compeople.de> wrote in message
news:f3127h$cpj$1@build.eclipse.org...
> Hi Simon,
> '/foo/*'?
> regards
> christian campo
>> Hi Teos,
>> are
>> those
>> some
>> wrapping your real Servlet in another that looks after the path_info
>> parsing and returns a 404 (or other code) for what your application does
>> not want to handle.
>> -Simon
>>> Hi Simon,
>>> invalid url's).
>>> to
>>> my own servlet.
>>> requests?
>>> paths
>>> ProxyServlet!?
>>> - teos
Previous Topic:Starting the server
Next Topic:Possible to deduce plugin from object instance
Current Time: Sun Aug 31 23:46:35 EDT 2025
Powered by FUDForum. Page generated in 0.05283 seconds
