Home » Archived » M2M (model-to-model transformation) » transformation ATL
transformation ATL [message #88582] Tue, 19 August 2008 22:55 Go to next message
Hi Friends
I'm trying to run an atl transformation over uml2 model but I cannot
generate all classes into yours respective packages.
rule MergeClass {
from s : UML2!Class (
to t : UML2!Class mapsTo s (
isAbstract <- s.isAbstract,
name <- s.name,
namespace <- s.namespace (? in uml2 ?)
oes anyone know how I can assign the element namaspace in uml2?
In uml1.4 , I just set: namespace <- s.namespace!
Best Regards
Re: transformation ATL [message #88598 is a reply to message #88582] Wed, 20 August 2008 05:58 Go to previous messageGo to next message
Geam Carlos schrieb:
> Hi Friends
> rule MergeClass {
> name <- s.name,
> oes anyone know how I can assign the element namaspace in uml2? In
> Best Regards
You don't have to, namespace computed.
greetings, urs.
Re: transformation ATL [message #88613 is a reply to message #88598] Wed, 20 August 2008 19:00 Go to previous messageGo to next message
Hi urs,
When I run an uml2 atl transformation programmatically the generated model
don't has the MODEL element as root element of tree. There are elements
(packages and classes) at the same level of the MODEL element.
I expected a document with this hierarch:
-Model
-Package1
-class1
-class2
-package2
-class3
But I obtain an document with this hierach:
-Model
-Package1
-class1
-class2
-Package2
-class3
Best Regards
Re: transformation ATL [message #88628 is a reply to message #88613] Thu, 21 August 2008 02:40 Go to previous messageGo to next message
Originally posted by: me.urszeidler.de
packagedElement <- invar.packagedElement,
Is the important statement to get the package hierarchy right.
Here are the examples of the rules for model and package :
rule ModelRule {
from invar : UML2!"uml::Model" (thisModule.ModelGuard(invar))
to Modelvar : UML2!Model (
name <- invar.name,
visibility <- invar.visibility,
viewpoint <- invar.viewpoint,
eAnnotations <- invar.eAnnotations,
ownedComment <- invar.ownedComment,
clientDependency <- invar.clientDependency,
nameExpression <- invar.nameExpression,
elementImport <- invar.elementImport,
packageImport <- invar.packageImport,
ownedRule <- invar.ownedRule,
owningTemplateParameter <-invar.owningTemplateParameter,
templateParameter <- invar.templateParameter,
templateBinding <- invar.templateBinding,
ownedTemplateSignature <- invar.ownedTemplateSignature,
--ownedType <- invar.ownedType,
packageMerge <- invar.packageMerge,
--nestedPackage <- invar.nestedPackage,
nestingPackage <- invar.nestingPackage,
profileApplication <- invar.profileApplication
do {
invar.debug('ModelRule');
for (p in invar.getAllAppliedProfiles()){
--p.debug();
thisModule.findProfile(p.getQualifiedName()).debug('profile' );
Modelvar.applyProfile(thisModule.findProfile(p.getQualifiedN ame()));
thisModule.copyStereoType(invar,Modelvar);
rule PackageRule {
from invar : UML2!"uml::Package" (thisModule.PackageGuard(invar))
to Packagevar : UML2!Package (
name <- invar.name,
-- nestedPackage <- invar.nestedPackage,
do {
thisModule.copyStereoType(invar,Packagevar);
-- invar.debug('PackageRule');
greetings urs.
Re: transformation ATL [message #88657 is a reply to message #88628] Thu, 21 August 2008 08:19 Go to previous messageGo to next message
Hi urs,
Very much thanks your attention!
I used the transformation rule that you cited, but released the following
errors:
****** BEGIN Stack Trace
message: feature owningTemplateParameter does not exist on UML2!Model
message: feature packagedElement does not exist on UML2!Model
message: feature nestingPackage is not changeable
message: feature profileApplication does not exist on UML2!Model
I am using the follow eclipse-uml2-1.1.1 API. Will be this the problem?
I have a dependency with this API (eclipse-uml2-1.1.1), because I am using
the repository andromda-repository-emf-3.2
( http://galaxy.andromda.org/docs-3.2/andromda-repository-emf/ index.html)
to persist the uml models. Do you know some repository else?
The rule below:
rule Model {
from s : UML2!Model(thisModule.inElements->includes(s))
to
t : UML2!Model mapsTo s(
name <- s.name,
visibility <- s.visibility,
viewpoint <- s.viewpoint,
eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
clientDependency <- s.clientDependency,
nameExpression <- s.nameExpression,
elementImport <- s.elementImport,
packageImport <- s.packageImport,
ownedRule <- s.ownedRule,
-- owningTemplateParameter <-s.owningTemplateParameter,
templateParameter <- s.templateParameter,
templateBinding <- s.templateBinding,
ownedTemplateSignature <- s.ownedTemplateSignature,
--ownedType <- s.ownedType,
packageMerge <- s.packageMerge,
-- packagedElement <- s.packagedElement,
-- nestedPackage <- s.nestedPackage,
-- nestingPackage <- s.nestingPackage,
-- profileApplication <- s.profileApplication
grateful for your help! Geam Carlos.
Re: transformation ATL [message #88673 is a reply to message #88657] Thu, 21 August 2008 10:19 Go to previous messageGo to next message
> Hi urs,
> following errors:
It looks like.
This rules are for "http://www.eclipse.org/uml2/2.1.0/UML",
and not for the 1.xx version. And I'm really sorry, i did not work with
the 1.xx version of uml2 and ATL.
> using the repository andromda-repository-emf-3.2
I do not have any experience with andromda.
Sorry.
Greeting, urs.
Re: transformation ATL [message #88688 is a reply to message #88673] Thu, 21 August 2008 12:27 Go to previous message
Hi urs,
You're right! It really is version uml2 1.x.
But, I am search any implentation of repository to version uml2 2.x. I use
the ATL transfornations of mode programmatically.
Do you know some implementation of repository, to persist the elements
version uml2 2.x?
grateful.
Previous Topic:Programatical launch of an ATL transformation from Ecore to Ecore
Next Topic:[QVTO] Parser error using ParameterDirectionKind enumeration
Current Time: Mon Jul 14 04:07:21 EDT 2025
Powered by FUDForum. Page generated in 0.26902 seconds
