Home » Language IDEs » ServerTools (WTP) » WTP Server settings/metadata...
WTP Server settings/metadata... [message #88486] Tue, 29 March 2005 16:30
Originally posted by: jeff.duska_removethis.noaa.gov
I'm working with my project I created by hand for the flexible project.
I'm having all kinds of fun. I have some questions.
* Does a web project need to be unique across all workspaces? For
example, if I have project myWebProject in workspace1 and workspace2.
Will the system see these as two different projects.
* Can the system clean up an existing project? I bounce around from Ant,
Intellij and Eclipse. It is possible that the same project would by
installed by any these tools. As such, when the system runs a web app it
need to clean out this over version if it is there. It should warn the
user, of course, and give them the option to abort.
* The deployment builder appears to be broken. I think this is a known
issue, so I wasn't sure if I should add bug report.
I cannot edit JSP when tomcat is running, because it doesn't recompile
and deploy the JSP. Nor does it update xml or .property files. I tried
to force a clean project. This fails with a cannot delete .deploy files
system error. Thus, you have stop tomcat. Then clean the project. Just
updating and editing the files does seem to always update the
..deployment directory.
Previous Topic:org.w3.www_2001.XMLSchema.Any?
Next Topic:Problems with Data Source in Tomcat v5.0.28
Current Time: Sun Aug 31 07:04:21 EDT 2025
Powered by FUDForum. Page generated in 0.06342 seconds
