Home » Eclipse Projects » Equinox » How to register a HttpSessionListener
How to register a HttpSessionListener [message #88302] Thu, 17 May 2007 21:54 Go to next message
Originally posted by: kedar.sadekar.ca.com
I have seen workarounds for registering ServletContextListener classes.
How do I register HttpSessionListener's?
Are there any workarounds or extension points available.
Thanks.
Re: How to register a HttpSessionListener [message #88320 is a reply to message #88302] Thu, 17 May 2007 23:02 Go to previous messageGo to next message
Depending on what you're trying to do you might be able to do something
clever with an HttpSessionBindingListener.
Eventually I'm hoping we'll be able to support a regular SessionListener
scoped by the HttpContext, but that's not for the current release.
HTH
-Simon
"Kedar" <kedar.sadekar@ca.com> wrote in message
news:6b0b76992b7c3fb43aaf75099a468bea$1@www.eclipse.org...
>I have seen workarounds for registering ServletContextListener classes. How
> Thanks.
Re: How to register a HttpSessionListener [message #88366 is a reply to message #88320] Fri, 18 May 2007 12:32 Go to previous messageGo to next message
Originally posted by: kedar.sadekar.ca.con
Right now I am interested in the sessionCreated and sessionDestroyed
events alone - Could you please explain further what could be done with
the BindingListener?
Re: How to register a HttpSessionListener [message #88398 is a reply to message #88320] Fri, 18 May 2007 13:40 Go to previous messageGo to next message
I am currenty just interested in the session created / destroyed events.
Could you please explain what is possible with the
/kedar
> HTH
> -Simon
>> Thanks.
Re: How to register a HttpSessionListener [message #88439 is a reply to message #88398] Sat, 19 May 2007 13:28 Go to previous messageGo to next message
Maybe something like this...
import javax.servlet.http.*;
public class HttpSessionListenerAdaptor implements
HttpSessionBindingListener {
private HttpSessionListener delegate;
public HttpSessionListenerAdaptor(HttpSessionListener delegate) {
this.delegate = delegate;
public void valueBound(HttpSessionBindingEvent event) {
delegate.sessionCreated(event);
public void valueUnbound(HttpSessionBindingEvent event) {
delegate.sessionDestroyed(event);
The idea is to always check and register this in your session as you
get/create it. The valueUnbound event iwll get sent if either the session is
explicitly invalidated or if the container times it out.
HTH
-Simon
news:b00c5b0bb88c7bc0adc41f014c4beba3$1@www.eclipse.org...
> /kedar
>> HTH
>> -Simon
>>> Thanks.
Re: How to register a HttpSessionListener [message #88514 is a reply to message #88439] Mon, 21 May 2007 16:33 Go to previous message
Thanks Simon,
Will definitely try that.
/kedar
> HTH
> -Simon
>> Thanks,
>> /kedar
>>> HTH
>>> -Simon
>>>> Thanks.
Previous Topic:Works in Knopflerfish but NoClassDefFoundError in Eqinox
Next Topic:tomcat deploy error
Current Time: Tue Jul 01 12:42:22 EDT 2025
Powered by FUDForum. Page generated in 0.03526 seconds
