Home » Language IDEs » PHP Development Tools (PDT) » XDebug JIT Debugging Issue
XDebug JIT Debugging Issue [message #88146] Sat, 03 January 2009 05:58 Go to next message
This is mainly for you Dave as you seem to be doing most of the fixing
up of XDebug stuff within PDT. I noticed a problem today with the JIT
debugging and how it figures out which file to use.
The problem occurs around how the file is loaded into the Eclipse editor
once you specify the path mapping. Hopefully this will be clear when I
show you my scenario.
1. New PDT project (PDT 2.0GA) for a fresh Drupal install (not really
important other than it is a PHP web application)
2. Firefox plugin for XDebug (just used to set the cookies so that a
remote debug session can start)
3. Eclipse is running with the project open. Start a remote debug
session and an Eclipse dialog pops up saying a file within the servers
path of /home/testing/wwwroot/index.php is needing to be mapped. By
default it shows the index.php from within my project.
4. I select it and the file opens up and stops on line 1.
Here is where there is problems. The files being opened are absolute
paths within my local machine. In this case my local machine has the
file at e:\testing\wwwroot\index.php. The Eclipse project is at the
wwwroot level. I can step through the code and step into functions and
do some of the basic debugging. The thing is because the file is opened
absolutely (as if it isn't part of the eclipse project) I am not able to
F3 when selecting a function and I can make breakpoints properly because
the breakpoint shows the full path in the breakpoint view. Now if I am
to open the same file within the project and set a breakpoint there then
the code will stop and show in the absolute pathed file that is open.
Not sure how I can explain it other than that so let me know if you need
more information. From what I can tell the JIT for XDebug needs to
somehow open the files as if they are within the Eclipse project and not
absolutely or else they loose some of the PDT functionality.
Shawn Clark
P.S. sorry if my grammar is bad tonight. Typing this up late before
calling it a night as I didn't want to forget to post it. :)
Re: XDebug JIT Debugging Issue [message #88292 is a reply to message #88146] Mon, 05 January 2009 10:46 Go to previous messageGo to next message
Hi Shawn, this behaviour is due to the Remote Session initiation only having a dummy source locator
defined to it. The source locator is used to locate and open the appropriate source file and it
fails to find the file (because it is only a dummy source locator for this session) so falls back on
the remapped file (by the path mapper) and opens that absolutely instead.
Could you raise a bugzilla, https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDT , to request an
enhancement to this ?
Many thanks for looking into this, your explanation and determination of the cause were spot on.
Cheers
Dave Kelsey
> Shawn Clark
Re: XDebug JIT Debugging Issue [message #88338 is a reply to message #88292] Mon, 05 January 2009 14:36 Go to previous message
For Reference:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259988
Shawn Clark
> having a dummy source locator defined to it. The source locator is used
> to locate and open the appropriate source file and it fails to find the
> falls back on the remapped file (by the path mapper) and opens that
> absolutely instead.
> Cheers
> Dave Kelsey
>> editor once you specify the path mapping. Hopefully this will be clear
>> when I show you my scenario.
>> opened absolutely (as if it isn't part of the eclipse project) I am
>> not able to F3 when selecting a function and I can make breakpoints
>> properly because the breakpoint shows the full path in the breakpoint
>> view. Now if I am to open the same file within the project and set a
>> breakpoint there then the code will stop and show in the absolute
>> need more information. From what I can tell the JIT for XDebug needs
>> to somehow open the files as if they are within the Eclipse project
>> and not absolutely or else they loose some of the PDT functionality.
>> Shawn Clark
Previous Topic:PDT 2.0, Hiding .svn folders
Next Topic:Where can I download ZendDebugger v5.2.15 ?
Current Time: Mon Jul 14 15:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.04783 seconds
