Home » Language IDEs » ServerTools (WTP) » Missing libraries
Missing libraries [message #88103] Tue, 29 March 2005 09:21 Go to next message
Originally posted by: kthuno.gmail.com
When trying to make a web service I get an error complaining about the
external libraries that needs to be added. Only problem is that I have
already added them and restarted eclipse with -clean.
I have checked and doublechecked that I have put them in their right
places.
Anyone tried this??
/Kasper
Re: Missing libraries [worksforme] [message #88321 is a reply to message #88103] Tue, 29 March 2005 12:21 Go to previous messageGo to next message
> places.
> Anyone tried this??
> /Kasper
Yes, I did. Followed the docs, downloaded all the files (some in other places), ran the ant script with additional
params and everything works
Ronald
Re: Missing libraries [message #88350 is a reply to message #88103] Tue, 29 March 2005 12:27 Go to previous messageGo to next message
Hi Kasper,
Which external libraries does the dialog say you need? Does it still list
all of them?
Lawrence
>places.
>Anyone tried this??
>/Kasper
Re: Missing libraries [worksforme] [message #88626 is a reply to message #88321] Wed, 30 March 2005 01:20 Go to previous messageGo to next message
>> places.
>> Anyone tried this??
>> /Kasper
Last time I installed the libraries I used the ant script but for some
reason it won't run now. This is what I get:
C:\Temp\eclipse-install>c:\apache-ant-1.6.2\bin\ant
-DlocalDownloads=C:\Temp\eclipse-install\wtp-libs -DbuildDirectory="C:\Program
Files\eclipse\plugins" -f fetchVendorContent.xml
Buildfile: fetchVendorContent.xml
run:
extractAllBinary:
extractAll:
[unzip] Expanding:
C:\Temp\eclipse-install\${build.home}\${build.drivers}\axis- 1_1.zip into
BUILD FAILED
C:\Temp\eclipse-install\fetchVendorContent.xml:171: The following error
occurred while executing this line:
C:\Temp\eclipse-install\fetchVendorContent.xml:8: The following error
C:\Temp\eclipse-install\fetchVendorContent.xml:28: Error while expanding
Total time: 0 seconds
Any ideas for that??
/Kasper
Re: Missing libraries [message #88641 is a reply to message #88350] Wed, 30 March 2005 01:25 Go to previous messageGo to next message
Lawrence Mandel wrote:
> Hi Kasper,
> all of them?
It doesnt specify which excact libraries are missing. The dialog says:
"Missing third party files. Refer to
http://www.eclipse.org/webtools/wst/components/ws/download_i nstructions_for_jars.html"
As I posted earlier, I've tried the ant script but it fails on me.
/Kasper
Re: Missing libraries [message #88656 is a reply to message #88641] Wed, 30 March 2005 01:38 Go to previous messageGo to next message
That same dialog should contain a list of plugins, missing files, and the
location where missing files can be downloaded. Are there any plugins in
the list?
Lawrence
>/Kasper
Re: Missing libraries [message #88685 is a reply to message #88103] Wed, 30 March 2005 02:03 Go to previous messageGo to next message
Reinstalling everything worked. Now I'm back with the axis problem when
deploying to tomcat:
(IWAB0489E Error when deploying Web service to Axis runtime
java.lang.NullPointerException)
Using eclipse3.1m5 , wtp/xsd/gef/jem etc. from wtp-prereqs-sdk-2.0M3.zip,
and tomcat 4.1.31
Any workarounds for this?
I tried waiting a few seconds after this error occurs and then pressing
next again, but it doesnt help no matter how many times I do this.
/Kasper
Re: Missing libraries [message #88699 is a reply to message #88656] Wed, 30 March 2005 02:07 Go to previous message
The dialog you mean is the one that is shown when eclipse is started up
and the libraries arent there. But this error-dialog is shown when trying
to make a webservice from an existing class.
I've got that working though after reinstalling all. So I must have had
missed something or something else must have gone wrong.
I'm back with the axis problem now...
/Kasper
Previous Topic:Problems with Data Source in Tomcat v5.0.28
Next Topic:Is there any Complete free jsp+struts plugin for eclipse-3.0
Current Time: Tue Jul 22 02:42:02 EDT 2025
Powered by FUDForum. Page generated in 0.05028 seconds
