EPP Nightly Build. What is "Replacing feature version"? [message #7955] |
Thu, 10 April 2008 06:07  |
Hey,
I downloaded 20080410-0540_eclipse-modeling-ganymede-M6-linux.gtk.x86.tar .gz
from the EPP Nighly build site. As the page says, the nighly builds
are made from the Ganymede Staging Update Site.
Surprisingly the zip includes:
Eclipse Modeling Framework (EMF)
Version: 2.4.0.v200802090050
Build id: 200802090050
This confuses me, I thought It'd contain the M6 Packages, as these are already available at the
Staging Update site. In the build log, these lines are suspicious:
!ENTRY org.eclipse.update.core 4 0 2008-04-10 02:37:27.748
!MESSAGE Digest could not be parsed:Element type "includes" must be followed by either attribute specifications, ">" or "/>".
Replacing feature version of org.eclipse.platform with version 3.4.0.v20080324a-9F94EjREj_pBVPliz-q3jhrqxLcUuo66usz00mM
Replacing feature version of org.eclipse.sdk with version 3.4.0.v20080328-7M7Q_7BI5lpaYWEcz04kOkMCucvDSaaFWc1V9KoCK2ZP 7
Replacing feature version of org.eclipse.emf with version 2.4.0.v200802090050
Replacing feature version of org.eclipse.gef with version 3.4.0.v20080115-677-8082A5655G2337
Replacing feature version of org.eclipse.uml2.sdk with version 2.2.0.v200802201645
Replacing feature version of org.eclipse.emf.transaction with version 1.2.0.v200711141947-23-8s733H464D5EAG
Replacing feature version of org.eclipse.emf.validation with version 1.2.0.v200711071738-35-9oA55P898H9MBK
Replacing feature version of org.eclipse.emf.workspace with version 1.2.0.v200711141947-23-8s733H464D5EAG
Replacing feature version of org.eclipse.emf.query with version 1.2.0.v200711141856-11-7w311823172914
Replacing feature version of org.eclipse.ocl with version 1.2.0.v200711121858-34-9oA55R696J8AFA
Replacing feature version of org.eclipse.emf.ocl with version 1.1.100.v200710171842-108Y7w311823172739
Replacing feature version of org.eclipse.gmf.sdk with version 2.0.1.v20071003-0000-7f7BEAVEMnXQGKPLmcKJkkUIF--J
Replacing feature version of org.eclipse.uml2tools.sdk with version 0.7.1.v200802180622
Replacing feature version of org.eclipse.ocl.all.sdk with version 1.2.0.v200709211511-67_8Y_-NQOaOSTWJqiy-urjWGamY
Replacing feature version of org.eclipse.emf.emfqtv.all.sdk with version 1.2.0.v200710032115-7A7J-DjlSb7SveltvElLGf4JRlDE
Replacing feature version of org.eclipse.m2m.qvt.oml.sdk with version 1.0.0.v20080215-1734-79--A7JC0m3ljfa8HufpLDQkBsSU
Replacing feature version of org.eclipse.epp.usagedata.feature with version 0.5.2.N200802202215
It would be cool if someone could explain. It's really confusing...
Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #7974 is a reply to message #7955] |
Fri, 11 April 2008 03:56   |
Originally posted by: mknauer.innoopract.com
Hi Felix,
the short answer: If there is no specific version of a feature defined in
the EPP configuration file, the available update sites will be searched and
the version 'replaced' by the highest version.
But I'll have a look if everything works as expected. You are right that
this looks a bit strange.
Markus
Felix Dorner wrote:
> Hey,
> I downloaded
> 20080410-0540_eclipse-modeling-ganymede-M6-linux.gtk.x86.tar .gz from the
> EPP Nighly build site. As the page says, the nighly builds are made from
> already available at the Staging Update site. In the build log, these
> followed by either attribute specifications, ">" or "/>". Replacing
> 3.4.0.v20080324a-9F94EjREj_pBVPliz-q3jhrqxLcUuo66usz00mM Replacing feature
> 3.4.0.v20080328-7M7Q_7BI5lpaYWEcz04kOkMCucvDSaaFWc1V9KoCK2ZP 7 Replacing
> 3.4.0.v20080115-677-8082A5655G2337 Replacing feature version of
> org.eclipse.uml2.sdk with version 2.2.0.v200802201645 Replacing feature
> 1.2.0.v200711141947-23-8s733H464D5EAG Replacing feature version of
> 1.2.0.v200711071738-35-9oA55P898H9MBK Replacing feature version of
> 1.2.0.v200711121858-34-9oA55R696J8AFA Replacing feature version of
> 2.0.1.v20071003-0000-7f7BEAVEMnXQGKPLmcKJkkUIF--J Replacing feature
> 1.2.0.v200709211511-67_8Y_-NQOaOSTWJqiy-urjWGamY Replacing feature version
> 1.2.0.v200710032115-7A7J-DjlSb7SveltvElLGf4JRlDE Replacing feature version
> 1.0.0.v20080215-1734-79--A7JC0m3ljfa8HufpLDQkBsSU Replacing feature
> 0.5.2.N200802202215
> Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #8008 is a reply to message #7974] |
Fri, 11 April 2008 05:04   |
Thanks for spotting this... in the EPP configuration file the 'stable' and
not the 'staging' Ganymede update site was referenced.
Well, the result is... that the build is failing now. :(
Markus
Markus Knauer wrote:
> Hi Felix,
> and the version 'replaced' by the highest version.
> Markus
> Felix Dorner wrote:
>> Hey,
>> I downloaded
>> 0.5.2.N200802202215
>> Thanks,
>> Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576462 is a reply to message #7955] |
Hi Felix,
Markus
Felix Dorner wrote:
> Hey,
> I downloaded
> 0.5.2.N200802202215
> Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576517 is a reply to message #7974] |
Markus
> Hi Felix,
> Markus
> Felix Dorner wrote:
>> Hey,
>> I downloaded
>> 0.5.2.N200802202215
>> Thanks,
>> Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576531 is a reply to message #8008] |
Fri, 11 April 2008 06:30  |
Not a terribly bad thing, imagine we think that all's fine, but
really isn't.
Greetings,
Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576544 is a reply to message #8008] |
Fri, 11 April 2008 06:34  |
I looked into the log, it seems there are some unresolved dependencies
from GMF examples to EMF examples. I also got these errors at startup
time after installing the per-project builds manually.
Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576586 is a reply to message #8073] |
Fri, 11 April 2008 07:12  |
Felix,
We don't ship EMF's examples as plugins that would be installed into the
running IDE, so it doesn't make sense for any downstream builds to
expect otherwise. We have
https://bugs.eclipse.org/bugs/show_bug.cgi?id=188989 open to ship them
in a form that would allow the user to "unzip" them into their workspace
via a wizard. That's probably the most sensible for all examples, so
perhaps it makes sense that GMF should be planning the same thing.
>> 'stable' and
> Felix
Re: EPP Nightly Build. What is "Replacing feature version"? [message #576612 is a reply to message #8103] |
Fri, 11 April 2008 08:09  |
We're planning to build an M6a that removes the examples from our SDK to
resolve this issue ASAP. Sorry for the trouble.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226511#c4
- Rich
On 4/11/08 7:12 AM, in article 47FF4790.3010407@ca.ibm.com, "Ed Merks"
<merks@ca.ibm.com> wrote:
> Felix,
>>> 'stable' and
>> Felix
FUDForum. Page generated in 0.05455 seconds
