Home » Eclipse Projects » Remote Application Platform (RAP) » Dynamic dialog modality
Dynamic dialog modality [message #87922] Fri, 16 May 2008 04:28 Go to next message
i make modal (SWT.APPLICATION_MODAL) dialog and then i open it. Work
fine. But i need programatically change this modal dialog to unmodal and
back. I need this because i want make dockable dialogs.
scenario:
1. user open modal dialog
2. user write any data to text fields in modal dialog.
3. user can not remember same information which he need for insertion to
modal dialog.
4. user choose "dock modal dialog". Dialog will be hide and user have
all application in READ-ONLY mode for search additional info for
insertion to modal dialog.
5. user found what he needed
6. user undock workout modal dialog
I think that i must do something on qooxdoo side. Maybe same new
component what know address modal window and dynamic change modality.
I don't know Qooxdoo well, but i think that qooxdoo prove this.
(according to documentation)
Re: Dynamic dialog modality [message #88033 is a reply to message #87922] Fri, 16 May 2008 09:09 Go to previous message
Originally posted by: rsternberg.innoopract.com
Hi Michael,
First of all, "dynamic modality" is not possible with SWT. Modality is a
static property of the Shell (and I think for good reasons).
Your use case is quite common, thus it is often recommended not to
overuse modality. If users should be able to access the lower shells
e.g. to lookup or c&p information, why does this dialog have to be modal
at all? If the reason was to keep it above other shells, you might be
interested in the latest Shell bugfixes [1]. Dialog shells stay always
on top of their parents now.
Although the qooxdoo Window provide a setModal function I would not
recommend to use this in RAP because our Shell implementation uses a
slightly different approach which will probably interfere.
Ralf
[1] http://dev.eclipse.org/mhonarc/lists/rap-dev/msg00292.html
Michal NkD Nikodím wrote:
> scenario:
> modal dialog.
Previous Topic:Set background on compisite with theme.properties
Next Topic:org.eclipse.ui.editorss
Current Time: Thu Jul 17 04:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.13373 seconds
