Home » Language IDEs » C / C++ IDE (CDT) » gdb 5.0/Red Hat Linux 7.2/switch error
gdb 5.0/Red Hat Linux 7.2/switch error [message #87898] Fri, 28 November 2003 21:03 Go to next message
Originally posted by: hay.amazon.com
I just installed eclipse/cdt and have got HelloWorld to run with very little
trouble. However when I try debug it gdb complains about an unknown -i
switch. I was able to look at the command line, and sure enough eclipse is
passing -i mi1. When I run the command from the command line it complains
about an unknown switch, so my gdb doesn't know about -i.
I assume that the command line parameters are configurable either through
one of the menus or in one of the xml configuration files, but I have not
been able to find how to set the command line. I would appreciate any help
in fixing this.
Bill Hay.
Re: gdb 5.0/Red Hat Linux 7.2/switch error [message #88004 is a reply to message #87898] Sat, 29 November 2003 12:37 Go to previous message
Originally posted by: mikhailkhod.rogers.com
You need gdb 5.2.1 or higher.
"bill hay" <hay@amazon.com> wrote in message
news:bq8ukt$bj8$1@eclipse.org...
little
> in fixing this.
> Bill Hay.
Previous Topic:CDT forget a little
Next Topic:Multiple targets in standard project
Current Time: Sun Jul 27 11:08:33 EDT 2025
Powered by FUDForum. Page generated in 0.02810 seconds
