Home » Newcomers » Newcomers » hibernatedoclet does not work in eclipse directory
hibernatedoclet does not work in eclipse directory [message #87493] Mon, 18 July 2005 15:54 Go to next message
Originally posted by: siegfried.heintze.com
I downloaded the source code from the book Pro Hibernate 3. The ant file
below worked: it generated a little message for each hbm file it created. I
then chheck the hbm2 directory and confirm the hbm files are there..
However, when I create a new empty eclipse project (v3.1) and run ant from
the cygwin command prompt, it does generate the hbm files. No error
messages, no hbm files, no messages saying it generated the files.
Can someone tell me what is going on ?
<project name="Blog" default="generate-hibernate" basedir=".">
<property name="xdoclet.lib.dir" value="C:\Documents and
Settings\Siegfried\My Documents\dev\XDoclet\xdoclet-1.2.3\lib" />
<property name="lib.dir" value="C:\Documents and Settings\Siegfried\My
Documents\dev\hibernate\hibernate-3.0" />
<property name="hibernate.dir" value="hbm2" />
<property name="src.dir" value="com/puregamesinc/dao/src" />
<property name="merge.dir" value="merge" />
<path id="xdoclet.lib.path">
<fileset dir="${xdoclet.lib.dir}">
<include name="*.jar"/>
</fileset>
<fileset dir="${lib.dir}">
</fileset>
</path>
<target name="generate-hibernate">
<taskdef name="hibernatedoclet"
classname="xdoclet.modules.hibernate.HibernateDocletTask"
classpathref="xdoclet.lib.path" />
<!-- Generate Hibernate mapping files -->
<hibernatedoclet destdir="${hibernate.dir}"
mergeDir="${merge.dir}">
<fileset dir="com/puregamesinc/dao/src">
<include name="**/Blog.java" />
</fileset>
<hibernate version="2.0" />
</hibernatedoclet>
</target>
</project>
Re: hibernatedoclet does not work in eclipse directory [message #87594 is a reply to message #87493] Mon, 18 July 2005 18:41 Go to previous messageGo to next message
Critical typo above!
Here is what I meant to say:
the cygwin command prompt, it does NOT generate the hbm files. Same java
files, almost the same build.xml file, no error
Re: hibernatedoclet does not work in eclipse directory [message #87624 is a reply to message #87594] Tue, 19 July 2005 00:14 Go to previous messageGo to next message
"Siegfried Heintze" <siegfried@heintze.com> wrote in message
news:dbhb7b$t0s$2@news.eclipse.org...
Siegfried, you may try your luck on the webtools newsgroup?
Re: hibernatedoclet does not work in eclipse directory [message #88137 is a reply to message #87624] Thu, 21 July 2005 01:08 Go to previous message
Philippe Ombredanne:
No luck so far. Why web tools? This is not specific to the web.
Sieg
Previous Topic:java.lang.UnsatisfiedLinkError
Next Topic:Where does Update Manager temporarily save files?
Current Time: Wed Jul 16 17:48:00 EDT 2025
Powered by FUDForum. Page generated in 0.06545 seconds
