Home » Archived » M2M (model-to-model transformation) » [ATL] Run ATL Ant Script Programmatically
[ATL] Run ATL Ant Script Programmatically [message #87485] Wed, 06 August 2008 08:48 Go to next message
Hi all,
I would like to trigger the ant script which controls my ATL
transformations using an eclipse plugin. To do this I have created a
plugin which calls the ant script as follows:
public void runAnt() throws CoreException{
AntRunner runner = new AntRunner();
runner.setBuildFileLocation("/home/mmelia/workspace2/mikael2.trans.coordinator/build.xml ");
runner.setArguments("-Dmessage=Building -verbose");
runner.run();
The ant script is run, but has problems with the line which loads in a
model using AM3 - <am3.loadModel modelHandler="EMF" name="MIKAELMETA"
metamodel="MOF" path="/metamodels/MIKAEL2.ecore"/>
stating the path is incorrect for the above (error below). Does anyone
know how to solve this? Does anyone have any experience doing this?
Mark
INFO: Adding AM3 ant log handler
INFO: Removed AM3 ant log handler
org.eclipse.core.runtime.CoreException:
/home/mmelia/workspace2/mikael2.trans.coordinator/build.xml: 6: The path is
incorrect.
org.eclipse.ant.core.AntRunner.handleInvocationTargetExcepti on(AntRunner.java:452)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:384)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:475)
mikael2.trans.coordinator.handlers.SampleHandler.runAnt(Samp leHandler.java:50)
mikael2.trans.coordinator.handlers.SampleHandler.execute(Sam pleHandler.java:35)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:619)
org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:605)
org.eclipse.ui.menus.CommandContributionItem$4.handleEvent(C ommandContributionItem.java:595)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3401)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: /home/mmelia/workspace2/mikael2.trans.coordinator/build.xml: 6:
The path is incorrect.
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.findFile ToURI(AM3AntToolKit.java:169)
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.loadMode l(AM3AntToolKit.java:104)
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.loadMode l(AM3AntToolKit.java:361)
org.eclipse.gmt.am3.tools.ant.tasks.LoadModelTask.execute(Lo adModelTask.java:59)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
... 36 more
Re: [ATL] Run ATL Ant Script Programmatically [message #87561 is a reply to message #87485] Wed, 06 August 2008 12:11 Go to previous message
Hi all,
Just to let you know the problem was that I needed to explicitly state the
project in the build.xml
metamodel="MOF" path="/projectTransformation/metamodels/MIKAEL2.ecore"/>
Mark
Mark Melia wrote:
> Hi all,
> runner.run();
> Mark
> incorrect.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
Previous Topic:[ATL] UML2Copy
Next Topic:[ATL] allowInterModelReferences = true by code
Current Time: Mon Jul 21 23:55:39 EDT 2025
Powered by FUDForum. Page generated in 0.03484 seconds
