Home » Language IDEs » PHP Development Tools (PDT) » XDebug base64 encoded variables
XDebug base64 encoded variables [message #7886] Wed, 21 March 2007 10:11 Go to next message
Originally posted by: alejandro.gonzalez.nemogroup.net
Hi!, first of all thanks to this great plugin.
I would like to know if someone has a compiled version of the plugin
with the variable encoding issue fixed.
Thanks!
Alejandro
Re: XDebug base64 encoded variables [message #8884 is a reply to message #7886] Wed, 21 March 2007 15:00 Go to previous messageGo to next message
Which version of PDT are you using ?, do you need path mapper support ?
what types of variable are you having problems with ?
If you are using PDT 0.7rc2 and don't need path mapper support then the
original 0.1.3 version should suite your needs. However it is possible
that some resources will display as encoded under certain conditions.
Dave Kelsey
> Thanks!
> Alejandro
Re: XDebug base64 encoded variables [message #8913 is a reply to message #8884] Wed, 21 March 2007 18:14 Go to previous messageGo to next message
--------------000606040602000201090501
Content-Type: text/plain; charset=ISO-8859-1
I'm using the I20070226 build + XDebug Support 0.1.4, I need path mapper
support and all the strings values are shown encoded. This happens on
Ubuntu Edgy (php 5.1.6) and Windows XP.
I've attached the phpinfo() xdebug section and a screenshot.
Thanks and sorry for my poor english!
Alejandro Gonz
Re: XDebug base64 encoded variables [message #8952 is a reply to message #8913] Wed, 21 March 2007 20:37 Go to previous messageGo to next message
You might try returning to the stable rc2 build and using the 0.1.3 version
with the path mapper support as that version should handle decoding of strings.
Dave Kelsey
> Alejandro González
>> Dave Kelsey
>>> Thanks!
>>> Alejandro
Re: XDebug base64 encoded variables [message #11943 is a reply to message #8952] Sun, 01 April 2007 08:54 Go to previous message
Originally posted by: yched.drupal.free.fr
It worked for me - thanks !
Dave Kelsey a ecrit le 22/03/2007 01:37:
> strings.
> Dave Kelsey
Previous Topic:occurrences feature not working for variables/functions
Next Topic:Changing Title of Editor Window
Current Time: Sun Jun 08 09:28:30 EDT 2025
Powered by FUDForum. Page generated in 0.06445 seconds
