Creating connections [message #87433] |
Tue, 15 July 2003 18:06  |
Originally posted by: rahul.dhar.intel.com
I think I have everything working in my application except for connection
creation. I'm using the Logic diagram example as start code. For some
reason, I always get a diagonal line from the upper right corner of my
drawing window, regardless of where I click for the source anchor. I
think that my anchors aren't being recognized, so the connection line just
grabs some default values for its start and end points. Is there any way
to check this? If they aren't being recognized, how do I register my
anchors? Is there a simple method for creating connections?
-Rahul
Re: Creating connections [message #87698 is a reply to message #87668] |
Wed, 16 July 2003 20:31  |
> My next question is can I have multiple connections from the same anchor?
> I would like to be able to do something like (aplogies if the ascii art
> doesn't come out nicely) this. The anchors are the '#'. I'd like to
> avoid having to create multiple anchors, since that would things very
> messy, at least from a usability standpoint.
Yes, you can do this. The logic example allows you to have multiple outputs
using the same anchor. Inputs are restricted to one per anchor only because it
doesn't make sense to have multiple inputs to one terminal.
FUDForum. Page generated in 0.03393 seconds
