Home » Eclipse Projects » Eclipse Platform » sleak
sleak [message #87286] Wed, 02 July 2003 09:11 Go to next message
Can someone tell me how to use SLEAK to test for resource leaks? The web
site only says that
org.eclipse.ui/trace/graphics=true
has to be added to Eclipse's .options file. Problem is, that I have
around 18 of them throughout my Eclipse install. Do I have to add this
to each one?
And do I then have to run the SLEAK.java class? Or will some kind of
output automagically be created?
Andy
Re: sleak [message #87572 is a reply to message #87286] Wed, 02 July 2003 12:27 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Eclipse only uses the .options file that is located in the eclipse
install directory (it should be a sibling of the "plugins" directory).
The .options files included with various plugins are just examples.
Just create a new .options file in the eclipse install directory with
the line you mentioned. Then, restart Eclipse in debug mode:
eclipse -debug -data ...
Andy Yang wrote:
> site only says that
> to each one?
> Andy
Previous Topic:maybe a (very) minor bug?
Next Topic:ILightweightLabelDecorator problem
Current Time: Tue Jul 22 14:43:20 EDT 2025
Powered by FUDForum. Page generated in 0.03073 seconds
