[EMF Compare] text compare instead of emf compare [message #86965] |
Thu, 21 June 2007 05:28  |
--------------090302090409000501020701
Hi!
I just had a look to the new EMF-compare. I am using the latest I-Build
(emft-compare-SDK-I200706191242).
I tried to compare two files (default.itv, default2.itv) (see
attachment) The files contain instances of a ecore-model (itv.ecore).
But when comparing, I only get the text compare. Any idea? BTW: I can
open both files with the reflective emf editor. So the ecore file was found.
Bernd
Content-Type: application/octet-stream;
name="emft-compare.zip"
Content-Disposition: attachment;
filename="emft-compare.zip"
UEsDBBQACAAIAMZa1TYAAAAAAAAAAAAAAAAzAAAAb3JnLm9wZW5hcmNoaXRl Y3R1cmV3YXJl
LmRlbW8uaXR2LmV4YW1wbGUxLy5wcm9qZWN0vZPNTsMwEITPIPEOVe7Y9MbB TSVA3EBIhQfY
2kvqyH+ynbSPj+0mQFRacah680x29I2zCVvutJr16IO0ZlHNyV01Q8OtkKZZ VB/vz7f31bK+
uWbO2xZ5fMLAvXQxTSf3ihnQWFvfEOvQgOcbGdNU53ELHolAbYmMPcEdaKdw zmgJ5CS3WqOJ
NaPjKbsDJhRBJ2rdSSVWDnlWg3xMUTCiOL/KIFfSBSStiITbVKSFHkoA/U+F lADfdJkdBk2n
BqMHlH9xnUDyAkZ+YogPl8Wu+AY1XAD658LXkGpY2J6FPzjjyhM6c4bpvTi+ 7f3zXKDMHcvk
V/amukaa19OBk9c9zI7n3Pb7O57+PF9QSwcIVFdyzAoBAAB7AwAAUEsDBBQA CAAIAMZa1TYA
AAAAAAAAAAAAAAA1AAAAb3JnLm9wZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8u aXR2LmV4YW1w
bGUxLy5jbGFzc3BhdGidjz0LwjAURWcF/0PIbqqbQ2sRqaBDlVJnqcmjjcaX mA/Rf29Vii46
uL17OZzLi9PrSZELWCc1JnTMRpQAci0k1gndlovhhKbTQT/mqnLOVL5pQ++d AL29kaNEkVBn
OSWP8nVG30musSO1rRlwJY0DdhCeqSogb9p1tiqy3Xydl7NlnhV/2IwAxrUF ZuEcpAWxUaGW
6H6pdPAm+M62l/iE4+jz+ztQSwcI1Ryc0qUAAAAzAQAAUEsDBBQACAAIAMZa 1TYAAAAAAAAA
AAAAAAA6AAAAb3JnLm9wZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8uaXR2LmV4 YW1wbGUxL3Ny
Yy9kZWZhdWx0Lml0dpVV227aQBB9r9R/GPkplcDGEKIUQXNrSVGDGgmaVnnb rAe8yl6s3XUc
3voP/cN+SccGU5IWQiT8wO45M3OOZ8b9k0cl4QGtE0YPgjhsBYCam0To+SD4 Nh02j4OTD2/f
9IV/6J1lmRSceYLCoxK9Na1d0iiQdj06HwSp91kvioqiCI2ah8bOox/j0Rri nkKKToVot1ox
wa4mPEXFmkI7zzTHmkUFrFmGFRWFzsqHIE70XMW7MssCt2EhDCP60UloMtTM 8lR45D63WDCL
YYLKhIQLlYqc5c056pIWIjeWatFM4SAYNac3AbkC0FdM6NXpxHCOFr4bKxOe Z0CCjhpwiVYx
vVjCiWCysjxXlewXGfFKa0d6ZtbRPZMLEA4KIxPgKVMZMegWH/0giKLTMmd0 ugoUxgH46maa
IniT2zKK9lCwMoKGuwVUERvgUxQWZgTxKV3ZjeguFVkDEpwhuafnMLSl99D9 /fNXB0ghg9Is
6RfgUmMoiwc286SWMlsGXiiEmdDCpZgs8TFRY0gs2R9Eu8WPUee1+ImnApwX 3G0V3K693MvN
KTK1PVb8Hx87bYCDmTUK4vfHNA0kUHv3bq1ir7SfjfP7ZG3XWes+eVWWi/r1 7ZOqU6daNtjB
IXWBF17iK6WdeY86Wc7myrFGp9tpHHW7ZByjrcDm1DrtxmErpraxoJjn6d8k /WiVY/+u+CRp
RCudLxV6Y/x6TM/RebiWbIF2ezNtNsA6OIXnqREc3SrUWFjjJHuAL9I43PDr H+St0EjbE+FW
kEc7oZeCaZmLuYDzfDajEd+BvcrvaZ6vTWKkuxebL+yZm/s7U6/KHbLP0Uqh G/BVLqjPGG3k
ROyu89J4LwXeNT8yoSTa5uRlznA0PFuuTbigvVkxctWAca4FT3doffq/H5Wv tvxYRc++VnT2
B1BLBwg6AvvWsgIAAOkGAABQSwMEFAAIAAgAxlrVNgAAAAAAAAAAAAAAADsA AABvcmcub3Bl
bmFyY2hpdGVjdHVyZXdhcmUuZGVtby5pdHYuZXhhbXBsZTEvc3JjL2RlZmF1 bHQyLml0dpVV
227aQBB9r9R/GPkplcDGEKIUQXNrSVGDGgmaVnnbrAe8yl6s3XUc3voP/cN+ SccGU5IWQiT8
wO45M3OOZ8b9k0cl4QGtE0YPgjhsBYCam0To+SD4Nh02j4OTD2/f9IV/6J1l mRSceYLCoxK9
Na1d0iiQdj06HwSp91kvioqiCI2ah8bOox/j0RrinkKKToVot1oxwa4mPEXF mkI7zzTHmkUF
rFmGFRWFzsqHIE70XMW7MssCt2EhDCP60UloMtTM8lR45D63WDCLYYLKhIQL lYqc5c056pIW
IjeWatFM4SAYNac37YBsAegrJvTqeGI4RwvfjZUJzzMgRUcNuESrmF4s4UQw WVmfq2r2i4x4
pbcjPTPr8J7JBQgHhZEJ8JSpjBh0i49+EETRaZkzOl0FCuMAfHUzTRG8yW0Z RXsoWBlBw90C
qogN8CkKCzOC+JSu7EZ0l4qsAQnOkOzTcxja0nzo/v75qwOkkEHplvQLcKkx lMUDm3lSS5kt
Ay8Uwkxo4VJMlviYqDEklvwPot3ix6jzWvzEUwHOC+62Cm7XXu7l5hSZ2h4r /o+PnTbAwcwa
BfH7YxoHEqi9e7dWsVfaz8b5fbK266x1n7wqy0X9+vZJ1alTLRvs4JC6wAsv 8ZXSzrxHnSyH
c+VYo9PtNI66XTKO0Vpgc2qdduOwFVPbWFDM8/Rvkn60yrF/V3ySNKOVzpcK vTF+Pafn6Dxc
S7ZAu72ZNhtgHZzC89QIjm4VaiyscZI9wBdpHG749Q/yVmik9YlwK8ijndBL wbTMxVzAeT6b
0YjvwF7l9zTP1yYx0t2LzRf2zM39nal35Q7Z52il0A34KhfUZ4xWciJ213lp vJcC75ofmVAS
bXPyMmc4Gp4t1yZc0N6sGLlqwDjXgqc7tD7934/KV1t+raJnnys6+wNQSwcI Ujg/PLMCAADq
BgAAUEsDBBQACAAIAMZa1TYAAAAAAAAAAAAAAAAtAAAAb3JnLm9wZW5hcmNo aXRlY3R1cmV3
YXJlLmRlbW8uaXR2Lm1tLy5wcm9qZWN0vVPNTgMhGDxr4js0exfqzQPdJmq8 1ZhUH+ArfG7Z
LD8BduvjC5RVN7WNh6Y3ZpjJDHzAlp+qmw3ovDR6Ud2ReTVDzY2QullU72/P t/fVsr65ZtaZ
Fnl4Qs+dtCGqI3vFNCisjWuIsajB8a0MUdU73IFDIlAZIsNAlGI0S5OHG6VQ h5rRcZXYEuAz
oBO06WUn1hZ5QgU+RitokZlfNZB30nokrQiEm1ihhQGyAd1PhegA1/Qp2xdM pwSjByn/yrUC
yQq0/EAfHi4bu+ZbVHCB0D9HvYFYw8DuLPmFGUceo1NOUe/B8Wnv91OBrDvm SVf22vWN1C+n
DSePe+gd16nt9zuefpsvUEsHCDHllO8FAQAAdQMAAFBLAwQUAAgACADGWtU2 AAAAAAAAAAAA
AAAALwAAAG9yZy5vcGVuYXJjaGl0ZWN0dXJld2FyZS5kZW1vLml0di5tbS8u Y2xhc3NwYXRo
nZA9C8IwEIZnBf9Dyd5UN4fWIlJBhyqlzlKTI43GS82H6L+3UopORdzuPR4e 7t44fVxVcAdj
pcaEzOiUBIBMc4kiIYdyHc5JupiMY6Yqa5vK1W0YfRKgM8/gIpEnxBpGgvey G6NfyVAADtFM
Y09rIygwJRsL9MwdVZVHVre30m2RHVe7vFxu8qz4w9ZwoEwboAZuXhrge+WF RDuk0t413vW2
k+y+iKPvrl5QSwcI++vsBaoAAABhAQAAUEsDBBQACAAIAMZa1TYAAAAAAAAA AAAAAAA2AAAA
b3JnLm9wZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8uaXR2Lm1tL3NyYy1nZW4v aXR2LmVjb3Jl
3VVNT8JAEL2b8B826xkKeDENaBAxIdGEiBivyzqFje3uZndq8d87W0sF8eAH JMYmbZPZeW/e
vJmmvfNVlrJncF4Z3eedVpsz0NI8Kr3o89ndVfOUn581jnogjYN4NBHySSyA rTIV16guoRpH
jC4i0z6mwz5fIto4ioqiaJls0TJuET3cjPk6xW+nFCdlRrfd7lDa9VQuIRNN pT0KLWGLvVSy
BQaZKuuhZIAsCSzdaBTSONMio2SFzxWH9rPbcY02oihRdB5uSvcTB4lavUHO AqYHw1R4rxJF
/TISHuOLJc7KkfJwXWdgbaqkQLLlDRzgU3S5xNyJ9AoEveETlgGiU/Mca8Xh SaO420y6FChC
gH2p9+MoGlFpGiSPvqXlFhJwEGyvtGRCac5SU4C7MLl+pD2ppVGVG9B55W64 pNFIgAw09jmV
g6p8L9o08tvWToRDzsTcoxNyzfx/PNawwk1Ty3b3Ylw5HgbT3IIL9P6d/3eS jQ177j9uxvsm
5NbW8WZnp7tDbcpYJ2YfDe/sC27OaD/78stW701Qd4DZyqVREn4022EJPdh0 K/o/9+XvtEWB
rX8mhV4BUEsHCF6CUFO2AQAAbgcAAFBLAQIUABQACAAIAMZa1TZUV3LMCgEA AHsDAAAzAAAA
AAAAAAAAAAAAAAAAAABvcmcub3BlbmFyY2hpdGVjdHVyZXdhcmUuZGVtby5p dHYuZXhhbXBs
ZTEvLnByb2plY3RQSwECFAAUAAgACADGWtU21Ryc0qUAAAAzAQAANQAAAAAA AAAAAAAAAABr
AQAAb3JnLm9wZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8uaXR2LmV4YW1wbGUx Ly5jbGFzc3Bh
dGhQSwECFAAUAAgACADGWtU2OgL71rICAADpBgAAOgAAAAAAAAAAAAAAAABz AgAAb3JnLm9w
ZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8uaXR2LmV4YW1wbGUxL3NyYy9kZWZh dWx0Lml0dlBL
AQIUABQACAAIAMZa1TZSOD88swIAAOoGAAA7AAAAAAAAAAAAAAAAAI0FAABv cmcub3BlbmFy
Y2hpdGVjdHVyZXdhcmUuZGVtby5pdHYuZXhhbXBsZTEvc3JjL2RlZmF1bHQy Lml0dlBLAQIU
ABQACAAIAMZa1TYx5ZTvBQEAAHUDAAAtAAAAAAAAAAAAAAAAAKkIAABvcmcu b3BlbmFyY2hp
dGVjdHVyZXdhcmUuZGVtby5pdHYubW0vLnByb2plY3RQSwECFAAUAAgACADG WtU2++vsBaoA
AABhAQAALwAAAAAAAAAAAAAAAAAJCgAAb3JnLm9wZW5hcmNoaXRlY3R1cmV3 YXJlLmRlbW8u
aXR2Lm1tLy5jbGFzc3BhdGhQSwECFAAUAAgACADGWtU2XoJQU7YBAABuBwAA NgAAAAAAAAAA
AAAAAAAQCwAAb3JnLm9wZW5hcmNoaXRlY3R1cmV3YXJlLmRlbW8uaXR2Lm1t L3NyYy1nZW4v
aXR2LmVjb3JlUEsFBgAAAAAHAAcAsQIAACoNAAAAAA==
--------------090302090409000501020701--
Re: [EMF Compare] text compare instead of emf compare [message #87101 is a reply to message #86965] |
Fri, 22 June 2007 05:21  |
Bernd Kolb wrote:
> Hi!
> found.
> Thanks
> Bernd
You have to go to Preferences/General/Content Types , Click on "Model
File" & add *.itv" as a file association.
Adam
Re: [EMF Compare] text compare instead of emf compare [message #607033 is a reply to message #86965] |
Thu, 21 June 2007 07:56  |
Hi Bernd !
The emf comparison will be launched if you add the "*.itv" extension in
the "Model File" content-type. You can do that with the preference pannel
in "General" then "Content types".
Do not hesitate to give feedback through this newsgroup.
Cédric
Bernd Kolb wrote:
> Hi!
> found.
> Thanks
> Bernd
Re: [EMF Compare] text compare instead of emf compare [message #607034 is a reply to message #87026] |
Thu, 21 June 2007 08:39  |
Thanks, Cédric
Bernd
Cédric Brun wrote:
> Hi Bernd !
> Cédric
> Bernd Kolb wrote:
>> Hi!
>> found.
>> Thanks
>> Bernd
Re: [EMF Compare] text compare instead of emf compare [message #607038 is a reply to message #86965] |
Bernd Kolb wrote:
> Hi!
> found.
> Thanks
> Bernd
Adam
FUDForum. Page generated in 0.24474 seconds
