Home » Newcomers » Newcomers » Maximum Line Width do not seem to work
Maximum Line Width do not seem to work [message #86948] Fri, 15 July 2005 14:32 Go to next message
I set the maximum line width to 132, but Eclipse still seems to wrap the
lines at about 80 in the Java editor. I Google'd for this problem but
couldn't find anything.
What am I doing wrong?
Re: Maximum Line Width do not seem to work [message #86964 is a reply to message #86948] Fri, 15 July 2005 14:35 Go to previous messageGo to next message
> What am I doing wrong?Sorry.
I forgot to mention that I am running Eclipse 3.1 (Build id:
I20050627-1435) on Fedora 4 Linux (GTK).
Re: Maximum Line Width do not seem to work [message #93491 is a reply to message #86964] Tue, 09 August 2005 09:11 Go to previous messageGo to next message
>> the lines at about 80 in the Java editor. I Google'd for this
>> problem but couldn't find anything.
There is no such preference and the Java editor provided by Eclipse SDK
does not support auto-wrapping. Are you talking about the formatter?
Dani
Re: Maximum Line Width do not seem to work [message #824887 is a reply to message #93491] Tue, 20 March 2012 03:34 Go to previous messageGo to next message
I am using Indigo 3.7 and I am using 'ctrl + shift + F' but it wrap lines. In Formatter I have set max line width to 100. but it is not working.
Re: Maximum Line Width do not seem to work [message #869771 is a reply to message #824887] Fri, 04 May 2012 05:24 Go to previous message
> working.
If it is not working using 3.7.2, then please file a bug report against
JDT Text with an example and attach your formatter settings.
Dani
Previous Topic:Java syntax colors
Next Topic:Edit Context Menu
Current Time: Sun Aug 31 18:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.19308 seconds
