Home » Archived » M2M (model-to-model transformation) » [ATL] error in debugger?
[ATL] error in debugger? [message #86929] Wed, 23 July 2008 05:19
Originally posted by: r.c.ladan.tue.nl
while debugging a transformation, this error popped up:
Problems occurred when invoking code from plug-in: "org.eclipse.debug.core".
java.lang.ClassCastException: java.lang.String cannot be cast to org.eclipse.m2m.atl.engine.vm.adwp.Value
at org.eclipse.m2m.atl.engine.vm.adwp.ADWPDebugger.realSendComm and(ADWPDebugger.java:48)
at org.eclipse.m2m.atl.engine.vm.adwp.ADWPDebugger.sendCommand( ADWPDebugger.java:39)
at org.eclipse.m2m.atl.adt.debug.core.AtlDebugTarget.breakpoint Removed(AtlDebugTarget.java:390)
at org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.run(BreakpointManager.java:879)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.notify(BreakpointManager.java:902)
at org.eclipse.debug.internal.core.BreakpointManager.fireUpdate (BreakpointManager.java:816)
at org.eclipse.debug.internal.core.BreakpointManager.removeBrea kpoints(BreakpointManager.java:427)
at org.eclipse.debug.internal.ui.actions.breakpoints.RemoveBrea kpointAction$2.run(RemoveBreakpointAction.java:125)
This was after a rule was invoked for the second time, while according to the input model it can only be invoked once
(since the model only contains one such element, and the rule calls oclIsTypeOf() )
This is with Eclipse 3.4.0 I20080617-2000, EMF 2.4.0 20080609-1234 and ATL 2.0.0 20080610-1117
(i.e. the "Eclipse Modeling Tools (includes Incubating components)" package).
Rene
Previous Topic:[ATL] java.lang.reflect.InvocationTargetException while launching transformation
Next Topic:[ATL]2 target objects from one source object
Current Time: Fri Jul 11 21:49:53 EDT 2025
Powered by FUDForum. Page generated in 0.03609 seconds
