Re: Error whilst creating a web service - ClassNotFoundException: javax.activation.DataSource [message #87444 is a reply to message #86903] |
Fri, 25 March 2005 15:56  |
When I ran into this problem before, I found another activiation.jar in
my classpath. After removing it, the problem went away.
Maybe, you could try doing a search for "activation.jar" with windows
explorer.
Also, make sure the activiation.jar file is in the 'lib' directory of
"<wtpInstallDirectory>/eclipse/plugins/org.eclipse.wst.ws.apache.soap_1.0.0/
". In fact, all the jars need to be in a "lib" directory, so create the
folder if one doesn't already exist.
And finally, you could try starting up eclipse with "-clean".
If after more tinkering and none of my suggestions work, maybe we should
start tracking this problem through a bugzilla bug. Please feel free to
open one.
https://bugs.eclipse.org/bugs/enter_bug.cgi
-seng
SuiteJ wrote:
> I'm getting the above error whilst following the top-down tutorial
> ( http://www.eclipse.org/webtools/jst/components/ws/tutorials/ TopDownWebService.html).
> I have set up a Tomcat 4.1 runtime. My project properties lists Tomcat
> 4.1 as the default server and its entry exists in my project. In fact,
> it is possible to see javax.activation.DataSource by expanding the
> Tomcat 4.1 runtime project entry!
> I have followed the instructions at
> http://www.eclipse.org/webtools/wst/components/ws/download_i nstructions_for_jars.html
> and started eclispe with the -clean option.
> In general terms this is a classpath error, but as I'm a newbie to
> eclipse I don't know where else to look.
> There is a similar posting to this (NoClassDefFoundError when creating
> web service from wsdl) but no solution!
> Ideas anyone? Thanks in advance for your help.
FUDForum. Page generated in 0.46318 seconds
