Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Create table fails in Integration Build I200704230019
[Teneo] Create table fails in Integration Build I200704230019 [message #86732] |
Mon, 18 June 2007 14:24 |
Originally posted by: bsu.bergauer.ch
Hello Martin,
Maybe this could be of any help to you...?
I upgraded my development enviroment from Eclipse 3.3M5 to Eclipse 3.3RC3
today. As I anyway was retrieving newer builds I thought I might as well
update Teneo. Until now I have successfully been using Integration Build
I200702130950. Now I downloaded and installed Integration Build
I200704230019.
As I started up a new project (where a new Derby database gets created) I
encountered the following problem while creating the tables:
[start extract console log]
10594 [ModalContext] DEBUG org.hibernate.tool.hbm2ddl.SchemaUpdate - create
table "connectable" ("id" integer not null unique, "dtype" varchar(255) not
null, "version" integer not null, "name" varchar(255),
"environment_connectables_id" integer, "environment_connectables_idx"
integer, econtainer_class varchar(255), e_container varchar(255),
e_container_featureid integer, primary key ("id")) (SchemaUpdate.java:149)
10625 [ModalContext] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate -
Unsuccessful: create table "connectable" ("id" integer not null unique,
"dtype" varchar(255) not null, "version" integer not null, "name"
varchar(255), "environment_connectables_id" integer,
"environment_connectables_idx" integer, econtainer_class varchar(255),
e_container varchar(255), e_container_featureid integer, primary key ("id"))
(SchemaUpdate.java:155)
Constraints 'SQL070618024717651' and 'SQL070618024717650' have the same set
of columns, which is not allowed. (SchemaUpdate.java:156)
10625 [ModalContext] DEBUG org.hibernate.tool.hbm2ddl.SchemaUpdate - create
table "connection" ("id" integer not null unique, "dtype" varchar(255) not
null, "version" integer not null, "connectable_source_id" integer,
"connectable_target_id" integer, "description" varchar(255), "port" integer,
"connectable_connections_id" integer, "connectable_connections_idx" integer,
econtainer_class varchar(255), e_container varchar(255), e_container_feature
Unsuccessful: create table "connection" ("id" integer not null unique,
"connectable_source_id" integer, "connectable_target_id" integer,
"description" varchar(255), "port" integer, "connectable_connections_id"
integer, "connectable_connections_idx" integer, econtainer_class
varchar(255), e_container varchar(255), e_container_featureid integer,
primary key ("id")) (SchemaUpdate.java:155)
Constraints 'SQL070618024717671' and 'SQL070618024717670' have the same set
[end extract console log]
Needless to say, the application failed to start, so I used Integration
Build I200702130950 again, and the application started as expected.
Attached you will find both console logs. I used the same model and
generated code and tested this both with code that was generated before and
after upgrading EMF and Teneo.
It is basically no problem for me, as I can continue to use Integration
Build I200702130950, but it might indicate that something has got broken?
Kind regards
Bjoern
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #86752 is a reply to message #86732] |
Mon, 18 June 2007 21:10 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Björn,
Some questions:
Can you see which columns are present in the constraints of which the creation fails?
Can you also post the mapping of the "connection" type?
gr. Maritn
Björn Sundin wrote:
> Hello Martin,
> I200704230019.
> Kind regards
> Bjoern
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #86827 is a reply to message #86752] |
Wed, 20 June 2007 08:50 |
Hi Martin
As far as I can see does this error occur for those tables where I don't use
a synthetic id.
I have defined a DataType AmsetId:
<eClassifiers xsi:type="ecore:EDataType" name="AmsetId"
instanceClassName="int">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Id
@GeneratedValue(strategy="AUTO")"/>
</eAnnotations>
</eClassifiers>
This DataType is used in i.e. Connectable:
<eClassifiers xsi:type="ecore:EClass" name="Connectable"
abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="connections"
upperBound="-1"
eType="#//Connection" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id"
unique="false" eType="ecore:EDataType
.../../ch.bergauer.rcp.amset.system.attributes/model/systemd atatypes.ecore#//
AmsetId"
iD="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="version"
AmsetVersion"/>
</eClassifiers>
The exception is thrown by the
org.apache.derby.impl.sql.compile.TableElementList.validate( DDLStatementNode
ddlStmt, DataDictionary dd, TableDescriptor td) method:
//check if there are multiple constraints with same set of columns
if (columnsMatch(cdn.getColumnList().getColumnNames(),
destColumnNames))
throw
StandardException.newException(SQLState.LANG_MULTIPLE_CONSTRAINTS_WITH_SAME_
COLUMNS,
cdn.getConstraintMoniker(), destName);
The parameters in columnsMatch have the following values:
cdn.getColumnList().getColumnNames(): (java.lang.String[]) [id]
destColumnNames: (java.lang.String[]) [id]
The DDLStatementNode parameters in TableElementList.validate looks like
this:
connectablestatementType: CREATE TABLE
tableElementList:
constraintName: null
constraintType: 3
properties: null
dataTypeServices: INTEGER NOT NULL
defaultValue: null
dataTypeServices: VARCHAR(255) NOT NULL
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
constraintType: 2
properties: null
properties:
null
lockGranularity:
R
[/ddlStmt]
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #86861 is a reply to message #86827] |
Wed, 20 June 2007 12:53 |
Hi Bjorn,
And how does the hbm look like for the Connectable class?
gr. Martin
Björn Sundin wrote:
> Hi Martin
> a synthetic id.
> </eAnnotations>
> </eClassifiers>
> abstract="true">
> upperBound="-1"
> AmsetId"
> iD="true"/>
> AmsetVersion"/>
> </eClassifiers>
> destColumnNames))
> throw
> COLUMNS,
> this:
> tableElementList:
> constraintType: 3
> properties: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> constraintType: 2
> properties: null
> properties:
> null
> lockGranularity:
> R
> [/ddlStmt]
> Regards
> Björn
> "Martin Taal" <mtaal@elver.org> schrieb im Newsbeitrag
> news:f56sc0$eml$1@build.eclipse.org...
>> Hi Björn,
>> Some questions:
> creation fails?
>> gr. Maritn
>> Björn Sundin wrote:
>>> Hello Martin,
> 3.3RC3
> well
>>> I200704230019.
> I
> create
> not
> ("id"))
> set
> create
> not
> integer,
> integer,
> e_container_feature
> set
> and
> broken?
>>> Kind regards
>>> Bjoern
>> The Netherlands
The Netherlands
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #86904 is a reply to message #86861] |
Wed, 20 June 2007 15:20 |
Hi Martin,
The hbm for the Connectable class looks like this:
<class
name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Connecta bleImpl "
entity-name="Connectable" abstract="true" lazy="false"
discriminator-value="Connectable" table="`connectable`">
<meta attribute="eclassName">Connectable</meta>
<meta
attribute="epackage">http://www.bergauer.ch/Nodeprojectdata.xmi</meta>
<id name="id" type="int">
<column not-null="true" unique="true" name="`id`"/>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="version" type="int">
<column not-null="true" unique="false" name="`version`"/>
</version>
<property name="name" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
<list name="connections" lazy="true"
cascade="delete,merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`connectable_connections_id`" not-null="false"
unique="false"/>
</key>
<list-index column="`connectable_connections_idx`"/>
<one-to-many entity-name="Connection"/>
</list>
</class>
In the two console output files I sent as attachment in the first post you
can see the complete hbm mapping (generated in memory).
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #92885 is a reply to message #86904] |
Thu, 09 August 2007 14:19 |
Hi Martin,
I think I have pinned down the problem that I (still) have with "create
table" to the following:
In Teneo 0.8.0.v200702130950 the id tags in the hbm mapping for classes
using annotated id (@Id) looks like following:
<column not-null="true" unique="false" name="`id`"/>
</id>
When I started to use Teneo 0.8.0.v200704230019 and later versions the id
element looks like this:
</id>
The difference is that the unique attribute was earlier false and in the
latest versions it is true.
The generated DDL then looks like this and the table doesn't get created due
to that there are two constraints that have the same set of columns (the ID
column):
create table "attributevaluedefinition" (
"name" varchar(255) not null,
"value" varchar(255) not null,
" datapointpredefinedattributedefinition_attributevaluedefinit ions_id "
integer,
" datapointpredefinedattributedefinition_attributevaluedefinit ions_idx "
integer,
primary key ("id")
The older version generated the following DDL:
"id" integer not null,
integer,
integer,
primary key ("id")
So the conflict seems to come from that there is an explicit "unique" for
the "id" column (unique constraint number one) and another implicit unique
constraint in 'primary key ("id")' (unique constraint number two). Thus the
same constraint twice for the id column and create table fails.
I assume that this is either a bug or that the configuration somewere has to
be changed. Could you give me an advice how I can go on to solve this
problem?
Kind regards!
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #92990 is a reply to message #92885] |
Fri, 10 August 2007 10:59 |
Hi Björn,
Yes this extra unique="true" does not seem required. I checked and the old hbm's of the testcases
all had unique="false". I have corrected this. Can you enter a bugzilla for this (then it ends up in
the release notes)?
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> </id>
> </id>
> column):
> integer,
> integer,
> primary key ("id")
> integer,
> integer,
> primary key ("id")
> problem?
> Kind regards!
> Björn
> PS. I've attached the in memory hibernate.hbm.xml for the different versions
> as well as the teneo debug output
> "Björn Sundin" <bsu@bergauer.ch> schrieb im Newsbeitrag
> news:f5bgjb$o40$1@build.eclipse.org...
>> Hi Martin,
>> <class
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
> not-null="false"
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> Regards
>> Björn
>> news:f5b80o$h1a$1@build.eclipse.org...
>>> Hi Bjorn,
>>> gr. Martin
>>> Björn Sundin wrote:
>>>> Hi Martin
> don't
>> use
>>>> a synthetic id.
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> abstract="true">
>> name="connections"
>>>> upperBound="-1"
> ..../../ch.bergauer.rcp.amset.system.attributes/model/system datatypes.ecore#/
>>>> AmsetId"
>>>> iD="true"/>
> name="version"
>>>> AmsetVersion"/>
>>>> </eClassifiers>
> columns
>>>> destColumnNames))
>>>> throw
>>>> COLUMNS,
> like
>>>> this:
>>>> tableElementList:
>>>> constraintType: 3
>>>> properties: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> constraintType: 2
>>>> properties: null
>>>> properties:
>>>> null
>>>> lockGranularity:
>>>> R
>>>> [/ddlStmt]
>>>> Regards
>>>> Björn
>>>>> Hi Björn,
>>>>> Some questions:
>>>> creation fails?
>>>>> gr. Maritn
>>>>> Björn Sundin wrote:
>>>>>> Hello Martin,
>>>> 3.3RC3
>>>> well
>> Build
>>>>>> I200704230019.
>> created)
>>>> I
>>>> create
>> varchar(255)
>>>> not
>> unique,
> varchar(255),
>>>> ("id"))
>> same
>>>> set
>>>> create
> varchar(255)
>>>> not
>>>> integer,
>>>> integer,
>>>> e_container_feature
> unique,
> integer,
>> same
>>>> set
>> Integration
>> before
>>>> and
>> Integration
>>>> broken?
>>>>>> Kind regards
>>>>>> Bjoern
>>>>> The Netherlands
>>> The Netherlands
> <!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
> <!-- Generated by Teneo on Thu Aug 09 15:22:20 CEST 2007 -->
> <hibernate-mapping auto-import="false">
> <class name=" ch.bergauer.rcp.amset.model.project.attributes.amset.impl.Pr ojectAttributesImpl " entity-name="ProjectAttributes" abstract="false" lazy="false" discriminator-value="ProjectAttributes" table="`projectattributes`">
> <meta attribute="eclassName">ProjectAttributes</meta>
> <meta attribute="epackage">http://www.bergauer.ch/Projectattributes.xmi</meta>
> <id type="long" name="id" column="id" access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
> <meta attribute="syntheticId">true</meta>
> </id>
> <many-to-one name="UserGroups" entity-name="UserGroupCollection" cascade="delete,merge,persist,save-update,lock,refresh" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name="`usergroupcollection_usergroups_e_id`"/>
> </many-to-one>
> <many-to-one name="UserPersons" entity-name="UserPersonCollection" cascade="delete,merge,persist,save-update,lock,refresh" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name="`userpersoncollection_userpersons_e_id`"/>
> </many-to-one>
> </class>
> <class name=" ch.bergauer.rcp.amset.model.project.attributes.amset.impl.Us erGroupCollectionImpl " entity-name="UserGroupCollection" abstract="false" lazy="false" discriminator-value="UserGroupCollection" table="`usergroupcollection`">
> <meta attribute="eclassName">UserGroupCollection</meta>
> </id>
> <list name="UserGroupRef" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`usergroupcollection_usergroupref_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`usergroupcollection_usergroupref_idx`"/>
> <one-to-many entity-name="UserGroup"/>
> </list>
> </class>
> <class name=" ch.bergauer.rcp.amset.model.project.attributes.amset.impl.Us erPersonCollectionImpl " entity-name="UserPersonCollection" abstract="false" lazy="false" discriminator-value="UserPersonCollection" table="`userpersoncollection`">
> <meta attribute="eclassName">UserPersonCollection</meta>
> </id>
> <list name="UserPersonRef" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`userpersoncollection_userpersonref_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`userpersoncollection_userpersonref_idx`"/>
> <one-to-many entity-name="UserPerson"/>
> </list>
> </class>
> <class name=" ch.bergauer.rcp.amset.model.project.attributes.amset.impl.Us erGroupImpl " entity-name="UserGroup" abstract="false" lazy="false" discriminator-value="UserGroup" table="`usergroup`">
> <meta attribute="eclassName">UserGroup</meta>
> </id>
> </version>
> <property name="name" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
> <column not-null="true" unique="false" name="`name`"/>
> </property>
> <property name="description" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`description`"/>
> </property>
> <many-to-one name="userTypeRef" entity-name="UserType" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name="`usertype_usertyperef_id`"/>
> </many-to-one>
> </class>
> <class name=" ch.bergauer.rcp.amset.model.project.attributes.amset.impl.Us erPersonImpl " entity-name="UserPerson" abstract="false" lazy="false" discriminator-value="UserPerson" table="`userperson`">
> <meta attribute="eclassName">UserPerson</meta>
> </id>
> </version>
> </property>
> <property name="firstname" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`firstname`"/>
> </property>
> <property name="username" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
> <column not-null="true" unique="false" name="`username`"/>
> </property>
> <property name="password" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
> <column not-null="true" unique="false" name="`password`"/>
> </property>
> <many-to-one name="userGroupRef" entity-name="UserGroup" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name="`usergroup_usergroupref_id`"/>
> </many-to-one>
> </class>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Environm entImpl " entity-name="Environment" abstract="false" lazy="false" discriminator-value="Environment" table="`environment`">
> <meta attribute="eclassName">Environment</meta>
> <meta attribute="epackage">http://www.bergauer.ch/Nodeprojectdata.xmi</meta>
> </id>
> </version>
> <list name="connectables" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`environment_connectables_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`environment_connectables_idx`"/>
> <one-to-many entity-name="Connectable"/>
> </list>
> <property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> </property>
> </property>
> </class>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Connecti onImpl " entity-name="Connection" abstract="true" lazy="false" discriminator-value="Connection" table="`connection`">
> <meta attribute="eclassName">Connection</meta>
> </id>
> </version>
> <many-to-one name="source" entity-name="Connectable" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`connectable_source_id`"/>
> </many-to-one>
> <many-to-one name="target" entity-name="Connectable" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`connectable_target_id`"/>
> </many-to-one>
> </property>
> <property name="port" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
> <column not-null="false" unique="false" name="`port`"/>
> </property>
> </class>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.IdcConne ctionImpl " entity-name="IdcConnection" abstract="false" lazy="false" extends="Connection" discriminator-value="IdcConnection">
> <meta attribute="eclassName">IdcConnection</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.AmBusCon nectionImpl " entity-name="AmBusConnection" abstract="false" lazy="false" extends="Connection" discriminator-value="AmBusConnection">
> <meta attribute="eclassName">AmBusConnection</meta>
> </subclass>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Connecta bleImpl " entity-name="Connectable" abstract="true" lazy="false" discriminator-value="Connectable" table="`connectable`">
> </id>
> </version>
> </property>
> <list name="connections" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`connectable_connections_id`" not-null="false" unique="false"/>
> </key>
> </list>
> </class>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.AmBusImp l " entity-name="AmBus" abstract="false" lazy="false" extends="Connectable" discriminator-value="AmBus">
> <meta attribute="eclassName">AmBus</meta>
> </subclass>
> <subclass name="ch.bergauer.rcp.amset.project.data.nodes.amset.AbstractNode " entity-name="AbstractNode" abstract="true" lazy="false" extends="Connectable" discriminator-value="AbstractNode">
> <meta attribute="eclassName">AbstractNode</meta>
> <list name="ownedDatapoints" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`abstractnode_owneddatapoints_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`abstractnode_owneddatapoints_idx`"/>
> <one-to-many entity-name="Datapoint"/>
> </list>
> <list name="foreignDatapoints" lazy="true" table="`abstractnode_foreigndatapoints`">
> <key update="true">
> <column name="`abstractnode_id`" not-null="true" unique="false"/>
> </key>
> <list-index column="`abstractnode_foreigndatapoints_idx`"/>
> <many-to-many entity-name="Datapoint" unique="false">
> <column name="`datapoint_id`" not-null="true" unique="false"/>
> </many-to-many>
> </list>
> </subclass>
> <subclass name="ch.bergauer.rcp.amset.project.data.nodes.amset.SimpleNode " entity-name="SimpleNode" abstract="true" lazy="false" extends="AbstractNode" discriminator-value="SimpleNode">
> <meta attribute="eclassName">SimpleNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.AmNodeIm pl " entity-name="AmNode" abstract="false" lazy="false" extends="AbstractNode" discriminator-value="AmNode">
> <meta attribute="eclassName">AmNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Illumina tionNodeImpl " entity-name="IlluminationNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="IlluminationNode">
> <meta attribute="eclassName">IlluminationNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.FireDete ctorNodeImpl " entity-name="FireDetectorNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="FireDetectorNode">
> <meta attribute="eclassName">FireDetectorNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.ElsNodeI mpl " entity-name="ElsNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="ElsNode">
> <meta attribute="eclassName">ElsNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.PowerNod eImpl " entity-name="PowerNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="PowerNode">
> <meta attribute="eclassName">PowerNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.RadioNod eImpl " entity-name="RadioNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="RadioNode">
> <meta attribute="eclassName">RadioNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.BlackIce WarningNodeImpl " entity-name="BlackIceWarningNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="BlackIceWarningNode">
> <meta attribute="eclassName">BlackIceWarningNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.GeneralC ommunicationNodeImpl " entity-name="GeneralCommunicationNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="GeneralCommunicationNode">
> <meta attribute="eclassName">GeneralCommunicationNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.RadioCom municationNodeImpl " entity-name="RadioCommunicationNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="RadioCommunicationNode">
> <meta attribute="eclassName">RadioCommunicationNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Communic ationProcessorNodeImpl " entity-name="CommunicationProcessorNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="CommunicationProcessorNode">
> <meta attribute="eclassName">CommunicationProcessorNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Ventilat ionNodeImpl " entity-name="VentilationNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="VentilationNode">
> <meta attribute="eclassName">VentilationNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Auxiliar yNodeImpl " entity-name="AuxiliaryNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="AuxiliaryNode">
> <meta attribute="eclassName">AuxiliaryNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Emergenc yTelephoneNodeImpl " entity-name="EmergencyTelephoneNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="EmergencyTelephoneNode">
> <meta attribute="eclassName">EmergencyTelephoneNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.PumpingS tationNodeImpl " entity-name="PumpingStationNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="PumpingStationNode">
> <meta attribute="eclassName">PumpingStationNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Security NodeImpl " entity-name="SecurityNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="SecurityNode">
> <meta attribute="eclassName">SecurityNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.TestNode Impl " entity-name="TestNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="TestNode">
> <meta attribute="eclassName">TestNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.TrafficN odeImpl " entity-name="TrafficNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="TrafficNode">
> <meta attribute="eclassName">TrafficNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.VideoNod eImpl " entity-name="VideoNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="VideoNode">
> <meta attribute="eclassName">VideoNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.VideoMan agementSystemNodeImpl " entity-name="VideoManagementSystemNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="VideoManagementSystemNode">
> <meta attribute="eclassName">VideoManagementSystemNode</meta>
> </subclass>
> <subclass name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.CentralF acilityNodeImpl " entity-name="CentralFacilityNode" abstract="false" lazy="false" extends="SimpleNode" discriminator-value="CentralFacilityNode">
> <meta attribute="eclassName">CentralFacilityNode</meta>
> </subclass>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Datapoin tImpl " entity-name="Datapoint" abstract="false" lazy="false" discriminator-value="Datapoint" table="`datapoint`">
> <meta attribute="eclassName">Datapoint</meta>
> </id>
> </version>
> </property>
> <many-to-one name="owner" entity-name="AbstractNode" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`abstractnode_owner_id`"/>
> </many-to-one>
> <list name="datapoints" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`datapoint_datapoints_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`datapoint_datapoints_idx`"/>
> </list>
> <list name="foreignNodes" lazy="true" table="`datapoint_foreignnodes`">
> <key update="true">
> </key>
> <list-index column="`datapoint_foreignnodes_idx`"/>
> <many-to-many entity-name="AbstractNode" unique="false">
> </many-to-many>
> </list>
> <list name="predefinedAttributeValues" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`datapoint_predefinedattributevalues_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`datapoint_predefinedattributevalues_idx`"/>
> <one-to-many entity-name="PredefinedAttributeValue"/>
> </list>
> <list name="textAttributeValues" lazy="true" cascade="delete,merge,persist,save-update,lock,refresh">
> <key update="true">
> <column name="`datapoint_textattributevalues_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`datapoint_textattributevalues_idx`"/>
> <one-to-many entity-name="TextAttributeValue"/>
> </list>
> </class>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.TextAttr ibuteValueImpl " entity-name="TextAttributeValue" abstract="false" lazy="false" discriminator-value="TextAttributeValue" table="`textattributevalue`">
> <meta attribute="eclassName">TextAttributeValue</meta>
> </id>
> </version>
> </property>
> <many-to-one name="datapointAttributeDefinitionRef" entity-name="DatapointAttributeDefinition" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name=" `datapointattributedefinition_datapointattributedefinitionre f_id` "/>
> </many-to-one>
> </class>
> <class name=" ch.bergauer.rcp.amset.project.data.nodes.amset.impl.Predefin edAttributeValueImpl " entity-name="PredefinedAttributeValue" abstract="false" lazy="false" discriminator-value="PredefinedAttributeValue" table="`predefinedattributevalue`">
> <meta attribute="eclassName">PredefinedAttributeValue</meta>
> </id>
> </version>
> <many-to-one name="attributeValueDefinition" entity-name="AttributeValueDefinition" lazy="false" insert="true" update="true" not-null="true">
> <column not-null="true" unique="false" name="`attributevaluedefinition_attributevaluedefinition_id` "/>
> </many-to-one>
> </class>
> <class name=" ch.bergauer.rcp.amset.model.system.attributes.amset.impl.Sys temAttributesImpl " entity-name="SystemAttributes" abstract="false" lazy="false" discriminator-value="SystemAttributes" table="`systemattributes`">
> <meta attribute="eclassName">SystemAttributes</meta>
> <meta attribute="epackage">http://www.bergauer.ch/Systemattributes.xmi</meta>
> </id>
> <many-to-one name="dataTypes" entity-name="DataTypeCollection" cascade="del
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #607012 is a reply to message #86732] |
Hi Björn,
Some questions:
gr. Maritn
Björn Sundin wrote:
> Hello Martin,
> I200704230019.
> Kind regards
> Bjoern
The Netherlands
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #607019 is a reply to message #86752] |
Hi Martin
a synthetic id.
</eAnnotations>
</eClassifiers>
abstract="true">
upperBound="-1"
AmsetId"
iD="true"/>
AmsetVersion"/>
</eClassifiers>
destColumnNames))
throw
COLUMNS,
this:
tableElementList:
constraintType: 3
properties: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
defaultValue: null
constraintType: 2
properties: null
properties:
null
lockGranularity:
R
[/ddlStmt]
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #607022 is a reply to message #86827] |
Hi Bjorn,
gr. Martin
Björn Sundin wrote:
> Hi Martin
> a synthetic id.
> </eAnnotations>
> </eClassifiers>
> abstract="true">
> upperBound="-1"
> AmsetId"
> iD="true"/>
> AmsetVersion"/>
> </eClassifiers>
> destColumnNames))
> throw
> COLUMNS,
> this:
> tableElementList:
> constraintType: 3
> properties: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> defaultValue: null
> constraintType: 2
> properties: null
> properties:
> null
> lockGranularity:
> R
> [/ddlStmt]
> Regards
> Björn
>> Hi Björn,
>> Some questions:
> creation fails?
>> gr. Maritn
>> Björn Sundin wrote:
>>> Hello Martin,
> 3.3RC3
> well
>>> I200704230019.
> I
> create
> not
> ("id"))
> set
> create
> not
> integer,
> integer,
> e_container_feature
> set
> and
> broken?
>>> Kind regards
>>> Bjoern
>> The Netherlands
The Netherlands
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #607025 is a reply to message #86861] |
Hi Martin,
<class
<meta
</id>
</version>
</property>
<key update="true">
unique="false"/>
</key>
</list>
</class>
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #609442 is a reply to message #86904] |
Hi Martin,
</id>
</id>
column):
integer,
integer,
primary key ("id")
integer,
integer,
primary key ("id")
problem?
Kind regards!
Bj
Re: [Teneo] Create table fails in Integration Build I200704230019 [message #609447 is a reply to message #92885] |
Hi Björn,
the release notes)?
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> </id>
> </id>
> column):
> integer,
> integer,
> primary key ("id")
> integer,
> integer,
> primary key ("id")
> problem?
> Kind regards!
> Björn
>> Hi Martin,
>> <class
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
> not-null="false"
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> Regards
>> Björn
>>> Hi Bjorn,
>>> gr. Martin
>>> Björn Sundin wrote:
>>>> Hi Martin
> don't
>> use
>>>> a synthetic id.
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> abstract="true">
>> name="connections"
>>>> upperBound="-1"
>>>> AmsetId"
>>>> iD="true"/>
> name="version"
>>>> AmsetVersion"/>
>>>> </eClassifiers>
> columns
>>>> destColumnNames))
>>>> throw
>>>> COLUMNS,
> like
>>>> this:
>>>> tableElementList:
>>>> constraintType: 3
>>>> properties: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> defaultValue: null
>>>> constraintType: 2
>>>> properties: null
>>>> properties:
>>>> null
>>>> lockGranularity:
>>>> R
>>>> [/ddlStmt]
>>>> Regards
>>>> Björn
>>>>> Hi Björn,
>>>>> Some questions:
>>>> creation fails?
>>>>> gr. Maritn
>>>>> Björn Sundin wrote:
>>>>>> Hello Martin,
>>>> 3.3RC3
>>>> well
>> Build
>>>>>> I200704230019.
>> created)
>>>> I
>>>> create
>> varchar(255)
>>>> not
>> unique,
> varchar(255),
>>>> ("id"))
>> same
>>>> set
>>>> create
> varchar(255)
>>>> not
>>>> integer,
>>>> integer,
>>>> e_container_feature
> unique,
> integer,
>> same
>>>> set
>> Integration
>> before
>>>> and
>> Integration
>>>> broken?
>>>>>> Kind regards
>>>>>> Bjoern
>>>>> The Netherlands
>>> The Netherlands
> </id>
> </many-to-one>
> </many-to-one>
> </class>
> </id>
> <key update="true">
> </key>
> </list>
> </class>
> </id>
> <key update="true">
> </key>
> </list>
> </class>
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </class>
> </id>
> </version>
> </property>
> </property>
> </property>
> </property>
> </many-to-one>
> </class>
> </id>
> </version>
> <key update="true">
> </key>
> </list>
> </property>
> </property>
> </class>
> </id>
> </version>
> </many-to-one>
> </many-to-one>
> </property>
> </property>
> </class>
> </subclass>
> </subclass>
> </id>
> </version>
> </property>
> <key update="true">
> </key>
> </list>
> </class>
> </subclass>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </many-to-many>
> </list>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </subclass>
> </id>
> </version>
> </property>
> </many-to-one>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </many-to-many>
> </list>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> </class>
> </id>
> </version>
> </property>
> </many-to-one>
> </class>
> </id>
> </version>
> </many-to-one>
> </class>
> </id>
Current Time: Fri Apr 26 18:02:06 GMT 2024
Powered by FUDForum. Page generated in 0.04245 seconds
