Home » Modeling » GMF (Graphical Modeling Framework) » Adding multiple Icons
Adding multiple Icons [message #86664] Wed, 20 December 2006 08:53 Go to next message
I m using GMF2.0M2. Can any of u plz help me to solve the following problem?
Can we add multiple icons vertically in an Editpart which could be able to
be double clicked to give a Dialog as well as can have individual property
sheet corresponds to the icons? Also we should be able to have default icons
in the header of Editpart one on left and another on right corner.
Thanks in advance.
Sandip
Re: Adding multiple Icons [message #86733 is a reply to message #86664] Wed, 20 December 2006 10:28 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Sure! Add a number of labels to node and use toolbar layout.
> Thanks in advance.
> Sandip
Re: Adding multiple Icons [message #86836 is a reply to message #86733] Thu, 21 December 2006 02:26 Go to previous messageGo to next message
Can you refer me any example where to use ToolbarLayout? I tried this one
before in Editpart. But It wont work. Probably I m not able to find out
where to use this exactly.
If you have any sample code it can help me lot.
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:embkr6$tg4$1@utils.eclipse.org...
> > Hi,
problem?
to
property
icons
> > Thanks in advance.
> > Regards,
> > Sandip
Re: Adding multiple Icons [message #86923 is a reply to message #86836] Thu, 21 December 2006 05:09 Go to previous message
org.eclipse.gmf.examples.taipan.gmf.editor.edit.parts.LargeI temEditPart
>>> Hi,
> problem?
> to
> property
> icons
>>> Thanks in advance.
>>> Regards,
>>> Sandip
Previous Topic:How to add Widgets to the Palette
Next Topic:Transformation Rule Model
Current Time: Tue Jul 22 12:00:47 EDT 2025
Powered by FUDForum. Page generated in 0.03961 seconds
